05-30-2022, 01:45 AM | #441 | |
Rep 7,543
But imo active ride height would be the best solution, and it would make these cars tremendously fast and stable. Too bad the FIA is for some reason anti innovation, maybe cost? idk.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
Artemis30017.00 |
05-30-2022, 01:48 AM | #442 |
General
61916
Rep 19,993
Sainz holding up Chas slightly in the pit with the 'stacking' can happen,Sainz was second after all and Chas was held up momentarily letting his feelings flow with some expletives and easy to blame Ferrari for another b@ls up but there was not a lot they could do under those circumstances in the tight confines of that track where you can't swing a cat.
///M Power-Belgium64773.00 NYG11054.50 |
05-30-2022, 03:33 AM | #443 | |
#buildnotbought
11141
Rep 4,934
I hinted in the "First 2022 Regulations F1 car revealed" topic that maybe a flap that bends might be used to control the buildup of underpressure that causes porpoising. Like a reed valve. This could be made as part of the floor; incorporating a piece of carbon in the floor that bends through underpressure, opening an equalizing hole. I wonder if this would count as an 'aperture', as it is closed when stationairy. (from what I've read and understood from the rules, apertures are not allowed in the floor other than to cool things) https://www.zpost.com/forums/showpos...&postcount=754 But the regulations are quite complex to understand fully....
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
05-30-2022, 03:36 AM | #444 | |
#buildnotbought
11141
Rep 4,934
Active ride heigth was banned in ~1995. (no active suspension parts) The FIA doesn't want the cars to get too fast.
05-30-2022, 08:20 AM | #445 | |
Rep 7,543
Edit- it would also really help with low speed performance, something these cars struggle with alot .
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 05-30-2022 at 09:36 AM.. |
05-30-2022, 08:36 AM | #446 | |
Moderator
30017
Rep 13,167
Or a less complex solution of gateways/channels in different materials: those heading to the back structurally molded in a very stiff compound (virtually no flexibility, as is the case now) while those gateways/channels heading sideways in a very flexible, expendable compound (for example flexible fins integrated in a channel). This way, those channeling sideways will flex/widen/expand at high(er) speed, unlike the sturdy ones channeling airflow to the back. A marginal alleviation of the back could already make a big difference. Brief, dynamically generating a different ground effect at high speed (that's when the porpoising effect happens). No electronics involved. Just using the laws of phyics at play on stiff and flexible materials. This may all sound crazy, but teams got to think out of the box to come up with smart solutions to remedy porpoising. It could get them an advantage over the competition. Remember: porpoising is inspired by dolphins bouncing around. But dolphins can also simply stay under water. All it takes is dynamically operating their tail, fins and force differently during the high speed movement. https://academic.oup.com/icb/article/42/5/1071/659889
///M is art ↔ Artemis
NYG11054.50 |
05-30-2022, 09:04 AM | #447 | |
General
64773
Rep 24,965
"Hannah Schmitz"
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 05-30-2022 at 09:11 AM.. |
05-30-2022, 09:37 AM | #449 |
Rep 4,672
Drives: BMW
This is so frustrating. Would LEC be guaranteed a win if Ferrari didn't double stack? Who knows but the win was lost when they did. And the fact that LEC fell behind and finished behind SAI was just the bitch slap just because. Ferrari doing Ferrari things I guess.
F87source7368.50 ///M Power-Belgium64773.00 Killed by Death13231.50 Blindside_1376755.00 Robin_NL8784.00 NYG11054.50 |
05-30-2022, 10:22 AM | #450 | |
#buildnotbought
11141
Rep 4,934
I don't think you understand the FIA mindset. An accident at higher speed has more risc of injury than an accident at lower speed. Why do you think suspensions were made more basic this year? (and like I wrote, it was already planned for earlier implementation, but at some point postponed a year) And active suspension control are considered drivers aids. Another thing that the FIA don't want. You're starting a discussion already held in 1993
NYG11054.50 |
05-30-2022, 10:32 AM | #451 |
General
64773
Rep 24,965
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-30-2022, 10:46 AM | #452 | |
Rep 7,543
If they want it to be safer they could limit adaptive ride height to benefit aero at low speed and just switch to anti porpoising for high speed, it'll save drivers from concussions from all the bouncing.
05-30-2022, 10:56 AM | #453 |
#buildnotbought
11141
Rep 4,934
You still don't understand the FIA's mindset.
It's not their goal to make the cars faster. It's about making racing exciting while keeping the speeds down. This year it's more exciting than last year. So they're on the right path Trust me, they're not gonna introduce active ride height control. Or ANY other active suspension tech. They've banned that almost 30(!) years ago. And Brawn said it himself in the video I posted: It's for the teams to solve and handle. The FIA has a very clear view on that.
05-30-2022, 11:18 AM | #454 | |
General
64773
Rep 24,965
05-30-2022, 11:40 AM | #455 | |
Rep 3,677
05-30-2022, 01:06 PM | #456 |
Rep 927
While on delay...
05-30-2022, 01:51 PM | #457 | |
Rep 7,543
If they wanted to make racing even better then low speed needs to be addressed because that's where these cars are struggling.
05-30-2022, 02:01 PM | #458 | ||
Rep 4,672
Drives: BMW
Killed by Death13231.50 |
05-30-2022, 03:13 PM | #459 |
#buildnotbought
11141
Rep 4,934
There are probably just as many opinions about that as there are persons
NYG11054.50 |
05-30-2022, 04:26 PM | #460 |
General
61916
Rep 19,993
05-30-2022, 04:49 PM | #461 | |
Rep 7,543
Literally ferrari ordered a double stack at the start of the lap while the gap between charles and carlos was 3ish seconds, by the end of the lap the gap evaporated to almost nothing so they screwed over charles and he had to wait for carlos. So pretty much ferrari screwed up so hard redbull benefitted, redbull didn't have some master class strategy that put them in the lead they just inherited it.
minn1914078.00 |
05-30-2022, 05:36 PM | #462 |
General
61916
Rep 19,993
How it all came together for Checo.
