01-24-2014, 02:24 PM | #5589 | ||
General
10539
Rep 41,178
01-24-2014, 02:29 PM | #5590 | |
General
10539
Rep 41,178
01-25-2014, 06:42 AM | #5591 | |
Rep 31
VCM Update: Write FA to backup. [C189] VCM Update: finished with error. [C196] Error in VCM Update: Write FA to the Backup Partner failed. Possibly there is no connection to the Backup Partner. [C097] negative response error: code: TIMEOUT P2/T2 occurred description: T2 timeout on Service WDBI_FA1 has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2008][VendorCodeDescription=T2 timeout occured]; ECU: VCM_BACKUP_ETHERNET severity: ERROR [2130765072] - SYSTEM_ERROR Abarbeitung beendet |
01-25-2014, 08:16 AM | #5592 | |
General
10539
Rep 41,178
01-25-2014, 01:45 PM | #5593 |
Amateur Brain Surgeon & Olympic Knitting Champion
18
Rep 178
ShawnS - Muchos gracias for all your help. I have neatly everything coded I wanted...
But of course I want more! Is it possible to enable the internet option? |
01-25-2014, 01:54 PM | #5594 | ||
General
10539
Rep 41,178
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-25-2014 at 02:05 PM.. |
01-25-2014, 04:47 PM | #5595 |
Rep 31
01-25-2014, 04:54 PM | #5596 | |
General
10539
Rep 41,178
If you can't VO Code it with either FA, then it is something else.
01-25-2014, 08:04 PM | #5597 |
35
Rep 205
Hey guys. Took my car in and I think the files updated. I can't go back and recode what I had. I'm getting the following two errors when running esys 3.23.4
Can anyone help? What files do I need to be updating/where do I download it?
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats |
01-25-2014, 08:42 PM | #5598 |
35
Rep 205
ok i found another post on here that has the same error, and it's recommended that I use the "Detect CAF for SWE" functionality to fix the corrupt CAF file...can someone give me a little bit more guidance before / after that step? I'm a little confused here...
'13 328xi M-Sport
01-26-2014, 03:45 AM | #5599 |
Rep 414
Hi Shawn
Can I too have a link to the software files etc Thanks in advance Paulf
Driving - 330e M Sport 2020
Previous - 2017 F32 420d M Sport, 2014 F30 330d M Sport, 2011 E90 320d Efficient Dynamics |
01-26-2014, 05:36 AM | #5600 | |
Rep 31
I've also done some coding on KOMBI and CMB_Media and there Coding is finishing successfully. Even creating Backups on VCM pages work fine. The backup error doesn't influence FDL coding. FDL coding is proceeding fine and change settings become effective. Is it possible to exclude Backup step from Coding procedure? Last edited by stealth98; 01-26-2014 at 06:17 AM.. |
01-26-2014, 02:38 PM | #5603 | |
General
10539
Rep 41,178
01-26-2014, 02:38 PM | #5604 |
General
10539
Rep 41,178
01-26-2014, 02:39 PM | #5605 | |
General
10539
Rep 41,178
v.51.3_PSdZData_Lite.part1.rar v.51.3_PSdZData_Lite.part2.rar
01-26-2014, 03:08 PM | #5607 |
Rep 23
First experience. Please, help
Bought cable, loaded ESys, data, bought patched token solution.
First connection windows 7: 1. Disabled WIFI connection 2. Stopped antivirus (Avira) 3. Connected enet 4. Connected OBD II 5. Local network connection rolling, then yelow triangle Starting by instruction with ESys. Here what I see: 1. ZGW Search Blank 2. E-Sys 3.24.3 Connect - F020 Connect via VIN is gray, so connecting via ateway URL - connected 3. Expert Mode/Coding/Read Read FA failed! Possibly there is no FA stored in the VCM. [C060] negative response error: code: the result contains an error description: Service RDBI_FA has error in result: [Severity=2051][ErrorCode=53311][ErrorCodeDescription=Module offline][VendorCode=20039][VendorCodeDescription=connect finally failed, reconnectCount= 1, firstStart= 14-01-26 14:49:12,855, reconnectWaitPeriod= 1000, maxReconnectTime= 10000, will not retry any longer]; ECU: VCM_ETHERNET severity: ERROR [2130759743] Is it correct to have in _EDIABAS.ini ? : Interface = STD:FUNK |
01-26-2014, 03:21 PM | #5609 | |
General
10539
Rep 41,178
You must Connect via VIN, so forget about your error with Connect via Gateway URL. Make sure: 1) Car has adequate voltage (motor running). 2) Windows Firewall is disabled 3) All Antivirus Programs are disabled 4) Lan Adapter has a 169.254.xxx.xxx IP Address.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-26-2014 at 09:56 PM.. |
01-26-2014, 03:27 PM | #5610 |
General
10539
Rep 41,178
PM sent.
