BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 10 HU discussion
proTUNING Freaks
      03-23-2024, 09:40 PM   #6183
NORAGRETS
NORAGRETS's Avatar
462
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
Originally Posted by RedErik View Post
You have to select somewhere is the settings to always boot in the "OEM mode". Otherwise you can switch between modes by pressing and holding the menu button.
Not really my business, but I completely don't get what you're doing. Why don't you buy an OEM screen instead? The are superior quality to Chinese shite anyways.
Don’t think BMW makes any that will fit in the F80 without modification any ideas?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021
      03-23-2024, 09:43 PM   #6184
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
F80 is just F30 on steroids and screens are interchangeable. But F80 comes with a screen already, so what's the issue?
      03-23-2024, 09:57 PM   #6185
NORAGRETS
NORAGRETS's Avatar
462
It comes w a 8.8” non touch screen I’m going for a 10.25” touch
      03-23-2024, 10:06 PM   #6186
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Couple of things:
1. If you get an Android screen, touch will not work on the OEM side - it just doesn't and there is nothing you can do about it without reverse engineering and reprogramming the microcontroller on the Android screen.
2. Depending on your iDrive version, you could get an OEM 10.25" touchscreen and code it to your car. But bear in mind that only iDrive 6 and higher support touch inputs.
NORAGRETS462.00
      03-24-2024, 02:28 PM   #6187
xandercage2k9
Drives: BMW 1 series E87
Originally Posted by Kri View Post
I updated the rooting tool, now it should work more stable, and that annoying CTRL+C bug from the old version should also be gone.
It is now one download containing all files necessary.
Attachment 2336745
The tool should work with PX6 and Snapdragon 625 Units on Android 9 and 10.
As always use at your own risk
Download can be found at Github.
To download click on the green "Code" icon and select "Download ZIP" and download to your Laptop or computer.
Unzip the File into the root of your System for example in a folder called "root", do not unzip it into your Userprofile folder or Desktop !
Connect your Android headunit to the same wireless network as your laptop/computer is connected to.
Start "install-root.bat" and enter the IP adress of your headunit.
Info: do NOT start the batch file ad Administrator, start it normally !
Kri
Hello, I have an Android 13 SD 665 unit, do you have a rooting guide for it maybe?
      03-25-2024, 11:30 AM   #6188
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
Originally Posted by marco_mu View Post
same problem!!! I'm stuck at 3.0.5. How did you solve it???
I upgraded to a bit of a newer version, then from that one to the newest version. It didn't like going straight from my old firmware to the brand new one, so I had to upgrade 2x.
F30 335i
Melbourne Red Metallic
M-Sport Package
      04-01-2024, 02:50 PM   #6189
S24rrt
Drives: E89
Just purchased a car with the following unit, what’s the latest update I can install? I’m on a later version to what is shown on page 1 so assume that’s incorrect now?
MCU version: 615095dALS-C&C-KTL-DC-211208
App Ver: Ksw-Q-Userdebug_OS_v3.4.6
Thanks in advance!
      04-01-2024, 07:34 PM   #6190
zz138
Drives: F30
Subscribe
      04-12-2024, 11:07 PM   #6191
TanyaButler
Drives: suzuki
There are app like mySMS that mirror your text messages on phone calls on 2 phones. It requires that you have an Android phone and both your phone and headunit have https://modilimitado.io/en/games constant access to internet. Bluetooth equivalents are long dead, they were popular in early 2010's but not any longer.
      04-13-2024, 02:56 PM   #6192
S24rrt
Drives: E89
Steering wheel voice button
while using android auto if I press the steering wheel voice button it works to activate google assistant (ok google), but at the same time activates the BMW voice assistant making it unusable. Is there any way to disable to BMW one?
Thanks in advance!
      04-13-2024, 05:24 PM   #6193
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Thanks in advance!
Code it out, that's the only way.
      04-29-2024, 03:18 AM   #6194
Meg_the_Face
Drives: 530d F10
Originally Posted by serge858 View Post
Update here: Unfortunately this Weather activation method doesn't work anymore. Chinese say they work on another Weather app to be implemented soon.
One more update: This method is still valid globally except regions where some limit of activations was reached (for example Russia). In these regions activation using VPN is still possible.
Hi, is there a new way or a newer code? i tried it with vpn but didnt work. Hifimax says in their comments at the Video, that the code is to old.
thanks
edit:
i got it to work. for 4.2.9 ther is a new code i found. same workaround with this Code: KYVNY5KL
hope to help anyone 😊
      05-08-2024, 07:57 AM   #6195
georgiee
Drives: Mercedes C250
Hello!
Is there any way to fix android head unit with snapdragon 662 which is stuck on boot?
https://f30.bimmerpost.com/forums/sh...postcount=4180
I disassembled the device following Kri's instructions in his post and finally saw that it was for the snapdragon 625.
PS: You try with SD card it didn't work
Thanks in advanced!
      05-11-2024, 12:56 AM   #6196
USER18
Drives: BMW F10 N20
Hi, may i know is there update for my current andriod 11
MCV Ver: 023055dGS-NBT-KTH-DC-211915
APP Ver: Ksw-R-M600_9S-V1.7.9
System Ver: 11-662EA-868927950521567
      05-12-2024, 08:30 AM   #6197
smahel
110
Drives: MINI Cooper, 2020 X1
https://f30.bimmerpost.com/forums/sh....php?t=1832178
      05-16-2024, 05:14 PM   #6198
Djbigboss
Drives: BMW F10
Good evening friends, I hope you can help me, I bought a head unit for Mercedes W2 205 with a SNAP Dragon processor.
The problem is that you can't get into the car menu anymore and WLAN doesn't work.
Do you perhaps have an update for me?
      05-16-2024, 05:35 PM   #6199
Djbigboss
Drives: BMW F10
Previous owner probably made wrong software on it, it also no longer works usb only sd card.
By the way, it's a snapdragon 450 I've read now.
      05-21-2024, 02:50 PM   #6200
Maen999
Drives: Bmw 4 series
Originally Posted by rytec View Post
This morning when I started the car it gave me this screen of the oem.
it was now in the middle of the Android HU instead of the left side.
And I did not change anything since I left it yesterday as it was, and below also the actual display config how it is now.
What should I do now?
Hello I have the same issue how did you solve it
      05-21-2024, 03:26 PM   #6201
Kamsung
Drives: F20 LCI
Hey. I've installed a junsun android unit in my f30. Green cables connected. Sounds comes fine through speakers. However when I call or receive a call I cannot hear the person on the other side. They can hear me. Removed my Bluetooth device from the nbt so it can't connect. Even if I don't use the android car play and use bluetooth only through the headunit same issue. Also my settings don't save after each time I start the car of the headunit. Not sure if thats related.
Any ideas?
Thanks
