V3 Lite Released! 3/27/17 - Preloaded VMWare/VBox Image - Coding/Diag/Programming
04-28-2019, 10:56 AM | #595 |
Rep 55
Drives: 2011 N55 E90
On my side, it shows 10 seeds for the big vm and 15 seeds for the lite vm...
It also shows 1 leach for big and 0 for lite.
2011 BMW 335i N55
Pure Stage 2 Turbo and Turbo Inlet. VRSF 7 inch HD Intercooler, Down Pipe, Charge Pipe and Turbo Outlet Pipe. Go Fast Bits DV+. Stage 2 Low Pressure Fuel Pump (Walbro 485high pressure/high volume version) MHD E85 Pro Tune (MOTIVE Motorsport). Black Market Parts Port Injection Kit (6 750CC Injectors) Split Second AIC-1, AFE Stage 2 Intake (Pro 5R Oil). |
04-29-2019, 12:43 PM | #596 |
A driver
13
Rep 77
04-29-2019, 01:43 PM | #597 |
Rep 8
I installed big one couple of days before and converted it to Mac Parallels VM. After couple of configuration on ( around 5 mins, max. ) it was ready and I confirm that download package is intact and VM is working just fine. Big thanks for the VM provider. Love from Czech Republic.
04-29-2019, 02:38 PM | #598 |
Rep 3
Hi guys,
I think I have done every think right but I still have troubles with Rheingold only (no issue with ISTA/P). I have downloaded the VM, installed VMware v12, and bought a USB to OBD device. My USB to OBD device seems to be installed properly on the VM, configured as COM9 as in the instructions. However when I launch Rheingold using the desktop icon, a black window opens and stays black no matter what. In the meantime, I have used ISTA/P without any issues => my USB to OBD device is working and is probably configured correctly. Lilou Dallas would say “Please help ?” |
05-03-2019, 02:23 PM | #599 | |
Rep 3
Following my not working VM, I have downloaded everything from link mentioned above and I have yet another issue. All the standard tools are working but for some reason, the #5 pre-install (which seems to be just the installation of java 8) is not working. This time I get a white window and nothing ever happens. Java v5 was already installed on my computer so I uninstall it and try to install java 8 but I get the same result over and over. Do you guys have any idea on how to solve this issue ? |
05-11-2019, 12:27 PM | #600 | |
Rep 3
I have finally solved my problem and the solution is quite simple so I will explain it in case this ever happen to someone. So java 8, contained in the pre-install package you can find on bimmergeeks.com was refusing to install for some reason. I simply install latest java v12 which was willing to be installed on my computer. After that everything started to work nicely. I just used ISTA to tell my car a new battery is in so the car is happy again. |
11-10-2019, 05:32 PM | #601 |
Rep 43
Hi,
I have been using this VM as a physical spare laptop for a while now, I have now picked up a E46 project car, can i get this to work on E46 too? Thanks |
03-19-2020, 09:51 AM | #603 |
Rep 3
04-22-2020, 07:12 AM | #605 |
Rep 1,420
You can just download all of this from Bimmergeeks now.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
08-25-2021, 06:18 AM | #607 |
Rep 1,420
You can just Google Bimmergeeks. https://www.bimmergeeks.net/downloads
