Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > Spacers on OEM E92 only
      11-02-2017, 04:42 PM   #45
Silent9n54
574
Drives: 2007 E92 335i
im looking for spacers as well just not sure what size to get
wheels are style 230s 19 inch - 275/30/19 michelin ps4s and 245/35/19 for the fronts on stock suspension
i thought fronts would rub at full turn with 245s but they surprisingly dont rub at all
thinking 10mm for front and rear.. i dont want the rear to rub at all so im hoping 10mm does the job...
      11-02-2017, 06:49 PM   #46
Olagüe
Olagüe's Avatar
Spain
106
Drives: 333i e92
This is my e92, 225 and 255 rear. 12mm front and rear. I think if you have 245 and 275, is more good 10mm.
      12-11-2017, 07:10 PM   #47
Donethat
Donethat's Avatar
339
Drives: 10’ 328 Msport w/ESS huffer
New member here. Thanks for all the heads up on spacers with Oem wheels. After reading up on this I decided to go with 12 front and 15 out back on 193’s. I have an extra set of 15s but I don’t prefer them any farther out. And as far as the rear I have a set of 18s which I think would be too tight. Anyways I’m very happy with the fit. No rubbing on stock m-sport suspension, with 225s and 255s.
Thanks again.
Snake882.50
      12-15-2017, 09:31 AM   #48
Faredo
Faredo's Avatar
312
Drives: 335i
I run a 15 / 20 spacer setup, no rubbing no modifications. style 189 wheels on firehawk indie 500's
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
      12-15-2017, 09:32 AM   #49
Faredo
Faredo's Avatar
312
Drives: 335i
note, the above pics was with runflats, not the firestones.
      12-15-2017, 09:50 AM   #50
Faredo
Faredo's Avatar
312
Drives: 335i
      06-14-2018, 02:32 AM   #51
thormessiah
thormessiah's Avatar
166
Drives: 2008 BMW 335i Coupe
2008 BMW 335i  [0.00]
Would 12-15 mm in the rear be OK for 18 inch Continentals? M-sport suspension here
      06-14-2018, 12:29 PM   #52
atmosphericM
Basic Bimmer
Drives: E92 328i 6MT ///M
Yes. I run 20mm in the rear with stock 18's on my M Sport LCI coupe.
Black Sapphire 328i ///M Sport Coupé
Save the Manuals!
      06-16-2018, 03:44 AM   #53
Poison32
Poison32's Avatar
18
Drives: E92 320 m sport
I had 12mm spacers all round on my car 2011 m sport on 313 alloys and had no rubbing 👍
      06-22-2018, 04:05 PM   #54
RDelaCourt
Drives: E92 335D
Ive recently purchased 20 mm spacers for the rear of my E92 335D, at first i thought it looked awful, but as it turned out as the car was jacked up the suspension on both sides had extended fully.
After a day or two of driving the ride height returned to as it was and it is now (in my eyes) sitting perfect.
Looking at this thread Im going to go with euther 10mm or 12mm for the front.
F:225/40/18 R:255/40/18
Thanks guys
      07-03-2018, 05:55 PM   #55
mic_on
Drives: E92 335is
I have 10mm front, 15mm in the back sitting on stock 335is suspension and stock size pilot 4s. Rear rubs under compression and driver side front rubs on the front inner fender in full lock. Passenger side seems to barely clear.
      07-16-2018, 08:41 AM   #56
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
I posted a while ago but I’ve got bigger spacers now
2011 M Sport 335i E92
Stock M Sport suspension
Stock 19 inch 313M wheels
Stock tyres sizes, Kumo KU39
20mm bolt on spacers front and rear
Works pretty well
Rear scraps very rarely if the road dips
Front scrap only just on hard lock reverse
Otherwise 95% of the time they are fine
      04-09-2019, 05:00 AM   #57
chevee
Poland
Drives: 335i E93
Hello there,
Spacer question.
I have 2007 E93 335i M sport suspension
my setup:
8" 225 / 35 / 19 front ET29
9" 255 / 30 / 19 rear ET40
OEM 296M 19 inch wheels
I have performance brakes installed (rear hubs were swapped from 135i to allow brake fitment, which worked as a spacer already adding ~ 6 - 8 mm comapring to stock. front is fully stock/ OEM)
it is explained here in the first post pictures:
https://www.e90post.com/forums/showp...91&postcount=1
so my question:
which spacers would work w/o rubbing (cosidering rear is already having ~ +8mm). I was thinking about adding 12mm spacers on both rear and front.
Any thoughts ? Many thanks in advance.
      02-07-2020, 08:27 PM   #58
JunkyardDogg
Drives: 2011 BMW 335is E92
Works pretty well
Did you roll fenders?
I've come to the conclusion tire brand also makes a difference. I had 12mm rear on 265 Continental and no rubbing at all. I went down in size to 255 Michelin and now it rubs on dips. I might have to roll fenders now
      05-07-2024, 10:55 AM   #59
minulache
19
Drives: BMW 4 F36 & E92 N55 LCI
Hi guys,
Sorry to bring this topic alive from the dead )
I really cannot find any good information about spacers for the E92 LCI. I have the 193M style wheels and would like to bring them out a bit, without rubbing.
I read here that 12mm on the front rubs, but 10mm from what I know is not recommended for BMW's due to the hub lip?
Also, on the back, 12 or 15mm should work?
Wheel size: Front: 225/40/18, 8J, ET34 Back: 255/35/18, 8.5J, ET37
      05-08-2024, 10:35 AM   #60
Phil325i
Phil325i's Avatar
624
Drives: E92 325i MSport Coupe
Originally Posted by minulache View Post
Hi guys,
I had the same set up as you and 15mm front and rear caused no rubbing so 12mm would be fine. Here's what it looked like:
      05-08-2024, 11:34 AM   #61
mattanderson
210
Drives: 2007 E92 328i
^ above setup is pre-LCI, though, correct?
My buddy put 12mm all around on his LCI sedan, and reported a slight amount of rubbing in the rear (maybe only with passengers?). It might depend on the specific tire and camber settings.
I think 15mm rear on an LCI is going to be a bad time without camber or fender work.
      05-08-2024, 03:14 PM   #62
minulache
19
That is the thing, apparently the LCI and Non-LCI are different when it comes to spacers. On non-lci bigger spacers have no problem, but on LCI they do. That is what I am trying to find out...
      05-08-2024, 04:12 PM   #63
mattanderson
210
Correct, LCI rear track width is 8mm wider, so LCI rear wheels are already "spaced out" 8mm vs. Pre-LCI.
ie., 20mm spacers on a Pre-LCI results in the same track width as 12mm spacers on an LCI (which is pushing it).
