BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Kyostar CAI - Why isn't it more popular?
Studio RSR
      09-17-2022, 02:59 PM   #45
bheng89
Drives: 2012 328xi
Reviving the thread for any update from those that have bought the intake; has anyone run into issues?
I managed to stay away from modding for the first year of ownership but now the mod bug has bit (again lol)
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete |
      11-07-2022, 10:41 AM   #46
SRB440IGC
101
Drives: 2018 BMW 440i GC
Not a single issue since installation.
      11-07-2022, 02:55 PM   #47
blacksapphire440i
Novice
blacksapphire440i's Avatar
316
Drives: 2018 440i Gran Coupe
You could purchase this intake box and replace the filter with a pro ram filter or a K&N filter.
      01-22-2023, 02:08 AM   #48
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Drives: 440i Gran coupe F36
You still using the original kyrostar filter as well? & what is the best way to clean the kyrostar filter? I want to clean it and at the same time buy a new filter but don’t know which cause I can’t find one with the same exact dimensions .
      01-22-2023, 02:10 AM   #49
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Any filter you please recommend specifically? I can’t find any with the dimensions of this kyrostar/mst filter.
      01-23-2023, 01:16 AM   #50
G.Newt
Drives: CT4-V Blackwing 6MT
If it's an MST clone, would the MST replacement filter not work?
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-25-2023, 11:10 AM   #51
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Just found the MST replacement filter cone for the B58 but I also found one from RK tunes that says it’s for the B58 as well but a different design compared to the MST one. The design of the MST one has a closed filter top, but the clone MST intake and the RK tunes filter has a open top that goes inward, Which one would you recommend if you had to choose between those two ? I’m thinking the MST filter but it seems like the open top filter that goes inward and closes inside looks to provide more surface filter space?
https://www.rktunes.com/products/replacement-air-filters-for-rk-tunes-front-mount-intakes?variant=40076578160745&currency=USD&gclid= Cj0KCQiAw8OeBhCeARIsAGxWtUz78UhdF8LwICl5cMXSGiRwUc ZM-mQJ5ls6-_nyJh9Bo8Xmlfi5FD4aAmRFEALw_wcB
https://mst-performanceusa.com/products/replacement-filter-for-mst-performance-intakes
      01-26-2023, 01:32 AM   #52
blacksapphire440i
Novice
316
https://www.rktunes.com/products/rep...4aAmRFEALw_wcB
https://mst-performanceusa.com/produ...rmance-intakes
would rather get this ovr the mst replacement https://www.b58racing.com/performanc...b58-air-filter
not the stock one tho but the actual cone filter
      01-26-2023, 10:24 AM   #53
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Are you talking about this one ? https://www.b58racing.com/performanc...ntake-filter-1
Already ordered the MST replacement but now thinking if I should cancel it and get that one since I have a stage 1 BM3 tune. I’m sure the MST filter is enough airflow for a stage 1, are you running that proram filter? Anyone else used this filter before?.. couldn’t find reviews on them for the B58 for some reason.
Would that filter even fit the MST heat shield cover? Since the width of it is more then the MST by a good amount. ..?
n55david1306.00
      01-27-2023, 01:27 AM   #54
blacksapphire440i
Novice
316
The heat shielding cover will most likely have to be removed but it definitely sucks in more air than the MST filter and produces more woosh sounds
      01-27-2023, 05:09 AM   #55
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
21
Do you currently have installed the proram air filter without the heat shield cover or the MST cone filter with the cover installed?
      01-27-2023, 06:01 PM   #56
blacksapphire440i
Novice
316
No not at the moment but I will be ordering one for my friend for his M340i. I have ordered an intake filter from cobb_developments so I will be installing that one on my F36. I will have to remove the intake cover though but I already have a turbo heat shield from ross racing.
      02-06-2023, 06:06 AM   #57
Fast_Rabbi
9
Drives: M140ix
Bought it on alibaba.
I'll receive it end of the week.
For those who bought it, are you stock?
      02-10-2023, 08:00 AM   #58
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
I received this intake and installed it. The intake itself is of decent quality, actually I was pretty surprised considering the price. The biggest gripe I have is that, in my opinion, the intake tube is a bit too small. The tube where it slides into the intake box to attach the filter seems a bit off. They could have bent the tube a little more to get it to sit straighter into the hole. Also, the filter itself is a pain in the ass to position correctly without it touching the wheel well. Other than those two things it seems to perform well, with nice intake and turbo spooling sounds, especially over 3K RPM in sport + mode.
Overall I would give it an 8 out of 10. I also snapped the stupid plastic ball pin that secures the base of the intake to the car, so I gotta get another of of those. I'll take some pics of it after word and upload them to this post. I got the unit from here:
https://www.ebay.com/itm/325317524143
I was also able to get the price down to $150 by sending the seller an offer if you guys wanna save some scratch. Also, if you broke the ball pin stud like I did, the part number is 13718620703
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
      02-10-2023, 08:42 AM   #59
Fast_Rabbi
9
Drives: M140ix
Clearly, a bit pain to install it.
I didn't reuse the plastic pin pall to secure the base. I used one of the nut (sorry if that doesn't mean anything, i use google trad). to secure it.
I'm on stg3 with a p800 so I already have a free flow inlet from pure without any resonator.
The sound is INSANE.
I did log the car : 4% less of wastegate work. Quite good !
      02-10-2023, 11:56 AM   #60
XxThe_RemedyXx
967
You used one of the locking nuts to secure it? Did the threads match up and were you able to get a good bite?
      02-10-2023, 02:09 PM   #61
blacksapphire440i
Novice
316
Glad there are both stock and upgraded turbo users using this intake and having good results. Would definitely recommend replacing the Kyostar intake filter with something more high quality such as a Pro Ram Air Filter or maybe an air filter from Cobb_Developments
      02-12-2023, 02:54 AM   #62
Fast_Rabbi
9
Drives: M140ix
I had that in my mind before purchasing the CAI.
I'll buy a pro ram air later, it's another 100€ to spend.
      02-12-2023, 07:14 AM   #63
XxThe_RemedyXx
967
I managed to adjust the intake tube a bit so it’s sits a little better now. Some shots…
      03-27-2023, 09:54 AM   #64
Cesarherc
Cesarherc's Avatar
Drives: 328i BMW
2015 328i  [0.00]
2015 328i  [0.00]
Hey all, not sure if this has been brought up and I know the thread is a few months old but I just wanted to put it out there, this brand does not go well with n20/n26 motors, I got two cars with the same motor, a couple years ago I got the injen one at a lower price than what you can find it for now, I put that on my car and waited too long to get it for my second car, by the time I went to buy one it was nearly double the price. I found kyostar at a cheaper price so bought that for the second car and although the design is similar, it’s maf sensor placement is different and it doesn’t have the nipple that connects the hose to the valve cover. Anyways I went to put it on and the car ran rough, decided to drill a small hole and put an npt fitting with a gasket for the hose that it didn’t have the nipple for, still ran rough, reset adaptations and still nothing. I ended up putting the og one back on and it runs way better, I guess the point I’m trying to make is just get the injen one if you got the n20 motors.
Ps it did throw some cels at me, saying it was too lean and air mass too low, unless anyone recommends a work around this? Maybe a different aftermarket filter? I also cleaned my maf sensor
      05-18-2023, 07:10 AM   #65
GENAU
17
This might sound sacrilegious but has anyone found these to be _too_ loud? It's hard to tell with the sound videos and many of them also have highly modified exhausts.
It's funny that the intakes either produce no increase in sound or far too much. Something that reminds me of older turbo japanese tuners or something.
      07-13-2023, 05:32 AM   #66
Ruebz_fthirty
Drives: f30 330i bmw
2015 F30 330i  [0.00]
https://youtube.com/shorts/8P3E0re4eAQ?feature=share
Heat shield fitment is terrible but doesn’t sound bad at all. Worth every cent.
