09-30-2016, 07:19 AM | #45 |
Rep 1,408
09-30-2016, 07:46 AM | #46 |
Rep 465
Originally Posted by Richbot View Post #30 in this thread I am not a fan of the way their adjustment works, without proof/info to the contrary. The way the bar ends drop down and the three holes move the endlink attachment in such a way that it seems like it relies on putting progressively more bending moment on the swaybar to get additional stiffness, which means bushing bind when the bar tries to lift up against the mounts. By contrast the Dinan and RD bars have their holes oriented roughly parallel to the ground so that you'r twisting the bar primarily about the long straight center section, which is how a swaybar is supposed to work and how the OE bar is designed. Eibach appears to have foregone the spaghetti bends the stock and Dinan/RD bars have in favor of...whatever that is. Maybe it works great, no idea, but it doesn't pass the eyeball test without knowing more Sounds reasonable to me. The difference in price is only about $200.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
10-01-2016, 02:07 PM | #47 | |
Rep 1,408
10-01-2016, 07:25 PM | #48 | |
Rep 8,077
Drives: 11 E90 M3 Individual
Maybe I misinterpreted it to apply to only springs and not springs and sways.
2018 F30 320iX Melbourne Red
10-22-2016, 03:43 PM | #49 | |
46
Rep 152
Thanks! |
10-22-2016, 06:37 PM | #50 |
Rep 3,361
RE-71R, 275/35-18 all around, E92 ZCP. Earlier in the season he was running 265/35s all around, but I think for Nationals he had the 275s. A board member herein owns the car and co-drove with the 1st place winner, placing well.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
10-30-2016, 11:51 PM | #51 |
46
Rep 152
11-06-2016, 07:12 PM | #52 | |
Rep 3,361
I have the original Dinan 28.5mm solid front bar, and my goal here was to try to achieve a closer to original front/rear roll stiffness balance now that I'm not autocrossing the car in stock class any longer, so I bought the Eibach rear bar which according to Eibach is tubular. Well, it's clearly solid and probably weighs close to twice the stock bar. It's 25mm (according to Eibach, but I'll measure it tomorrow) vs the stock 22.5mm. I was fine with the rear OE 22.5mm to Eibach 25mm, both tubular, bar stiffness increase, but now I'm concerned the rear may be too stiff since it's apparently solid -- I set it on the least stiff setting at least. I guess if it's too stiff I'll have to look at the adjustable front Dinan bar now. Installing this rear bar was the biggest PIA of just about any job I've done on a car, and I *never* want to fool with it again, and this was using a lift, tall tranny jack for subframe, etc. If I have to swap it again, I'm likely paying BPC here in town to do it. I'll finish it up tomorrow and figure this all out...hope this works out ok balance-wise as I'm running an event on Michelin Proving Grounds wet course soon. I guess if it's too stiff, it will make it easier to drift at least.
Current Stable:
11-13-2016, 06:19 AM | #54 |
Rep 3,361
Accidentally posted this in another thread also but meant to post it here:
I ended up going with the Eibach rear bar, and it turns out that......it's SOLID. . My calculations were based on it being hollow (with a similar wall thickness to the OEM hollow bar), so they were thrown off creating worry that the roll stiffness would be shifted to the rear too much. Hence I set it on the softer of the two possible adjustment choices -- unfortunately I didn't take careful measurements of the moment arm length before installing it, but eyeballing it shows the further out hole might be 1/4" - 3/8" longer moment arm than the stock bar. With my street tire staggered setup (OEM 220s with Michelin PSS, 255/275), the car is superbly balanced right now (in the wet). I just did an event yesterday on a flooded wet short road course track (first half was drifting practice, second half was timed runs, so a really good example of two different genres of demands), and then a 1/2 mile circumference wet skidpad. This car is so connected, intuitive, just superbly easy to control; I was able to hold a 3rd gear drift (~60-70mph?) for almost an entire 1/2 mile lap. Unfortunately, I only had one session on the big pad due to time constraints. On the road course, the transitions from drifting one direction...holding it until just the right moment....then shifting to drifting it in the other direction were very easy to contol, and the car responded superbly. Linking together 5 turns in a row like that was a blast. So very pleased with the combo of the origninal Dinan 28.5mm solid front bar (non-adjustable) and the Eibach 25mm solid rear adjustable bar "at the moment." It remains to be seen how the car behaves on track with my square setup (10x18 with 275/35 NT-01) in the dry. Regards, Chuck
Current Stable:
M43S7RO504.00 SYT_Shadow11511.00 |
11-25-2016, 09:20 PM | #57 |
Retired Curmudgeon
3000
Rep 4,075
Mine was ordered today. Will be nice not to have so much leaning in the corners.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
///Mobbin1478.00 |
11-25-2016, 10:15 PM | #58 |
E90
167
Rep 821
Hotchkis front and rear E9X M3 sway bars are currentlty discounted at Bimmerworld, I havnt heard much about them one way or another but confirmed with BW that they are indeed hollow. I just picked up a set:
http://www.bimmerworld.com/About-Us/...3-Car-Set.html |
11-26-2016, 04:29 AM | #59 |
Rep 3,361
Hotchkis doesn't even list them on their website. They show no application for the M3 and searching what is clearly a Hotchkis part number from BW site yields no hits on their site. By the way, if Hotchkis includes the directions for the rear bar like their other E9x applications, don't believe it, lol. The rear is a major pia to install, and if I ever do another one, I will simply disconnect the two brake lines to the subframe, drop the exhaust and lower the whole thing (as opposed to their partial lowering scheme) -- it will be much faster and easier to do it that way.
Current Stable:
11-26-2016, 12:27 PM | #60 |
E90
167
Rep 821
I'll be dropping my subframe completely anyway to perform the install, since I'm going to knockout subframe/diff bushings and a new driveshaft at the same time. I'll let you guys know once I get the bar if it is indeed the advertised M3 specific 32mm front/25.4mm rear, as opposed to the standard E9X 3-series spec bars.
///Mobbin1478.00 |
01-09-2017, 11:08 AM | #61 | |
1478
Rep 2,672
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
01-09-2017, 04:19 PM | #62 |
E90
167
Rep 821
01-11-2017, 11:49 PM | #63 | |
124
Rep 137
Bars at both ends are the ticket for the track, even if you have a square setup. The HK bars seem like a great option too. I'm installing them along with my Bilstein Clubsports. If they weren't a PITA to install, you'd probably see big increase in their use. Not much information from those who have KW/Bilstein clubsports AND front/rear swaybars though. I'll post my feedback once I get the car on track. The staggered tire setup can work, it just takes fully adjustable suspension, and adjustable bars on both ends. Sure, you give up some ultimate braking performance with a staggered setup, but still, for novices and experts alike, who want to simply drive up on stock/ish wheels/tires, even sticky ones, a rear swaybar should be part of the equation. I've got dedicated track cars, I just want something I can simply drive up without dragging the whole truck-and-trailer out. Sure, I'll have a square tire setup for the track, but my goal is to get a staggered tire setup (NT01 and Trofeo-R's available in stock 18" sizes) to be very neutral, have good tire wear, and be just as fun. This way, I can just hop in my car and do an event a few times a year with zero effort, and not even have to swap wheels back to stock. AKA - laziness.
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
01-12-2017, 12:06 AM | #64 |
Rep 513
Is there a general consensus for what the best front sway is? looking to order one soon.
car is primarily street driven, but i live in the mountains, so i get to have nice cruises |
01-12-2017, 07:06 AM | #65 |
Rep 3,361
255/35-19 and 275/35-19. Nope, car has stock springs/shocks for now. I just came from F-street class prep and added the rear bar. I don't have any great plans for this car other than enjoying it for now. If I change anything, I'll probably be going with MCS coilovers, plus camber plates, etc, but I'm not headed that route for now. I may try the new 888R but I guess it will be in 275/35-18 square since I have the Apex 10" wheels. For now I have 3 year old (but still very sticky) NT-01s on those wheels, so those may have to do for my next autox at the PC.
Current Stable:
01-13-2017, 07:52 AM | #66 |
Rep 1,055
From what I've gathered, it came down to being between the RD Sport and Dinan adjustable but there seem to have been some possible quality issues with the RDSport after reports of them breaking under load.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
