BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      11-13-2009, 02:03 PM   #45
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Fixed
      11-13-2009, 02:06 PM   #46
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Here is some throttle. Hear the "backfire"?
      11-13-2009, 02:12 PM   #47
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Originally Posted by Subw00er View Post
Where is the video?
It should be a bit quieter after you button it up fully. When my valves are opened up a smidge, like your access doors are, its definitely noticeable, so you dont need much of a leak for noticeably increased noise. The question is.. will it drone! It would seem to me that the header tape will still allow sound waves to permeate and you've created quite a cavity there. If I were you, I'd seal that area up better and drive around before you weld it back. You may want to cover the tubes with something more rigid and sound reflecting than the header wrap.
If you guys can come north a bit, maybe I may meet up too..maybe get out of the city and work it into a nice fall drive! Its too far to go to LI for a quick meet for me.
I couldn't use the exhaust header wrap because it was too thick. It is very tight between the two pipes on the left side of the photos. I used exhaust/muffler repair wrap. I still had some exhaust coming out of the chamber on the right (as installed on the car). I will be securing the wrap with stainless steel tie wraps. When the wraps gets hot, it cures and seals better. I think I will re-stuff the chambers with the absorption material too.
      11-13-2009, 02:25 PM   #48
3XTR3M3
3XTR3M3's Avatar
Drives: E92 AW M3 6MT
Originally Posted by Periokid View Post
I couldn't use the exhaust header wrap because it was too thick. It is very tight between the two pipes on the left side of the photos. I used exhaust/muffler repair wrap. I still had some exhaust coming out of the chamber on the left (as installed on the car). I will be securing the wrap with stainless steel tie wraps. When the wraps gets hot, it cures and seals better. I think I will re-stuff the chambers with the absorption material too.
Perio, the vids you posted are private. When I click it it says you have to add me as a friend on youtube before I can watch.
Cant wait to see how it turned out! Great work and effort, man
      11-13-2009, 02:27 PM   #49
SUB-ZERO
SUB-ZERO's Avatar
294
Drives: 2018 M2 + Spur, DB11, F12, X5
Vid is private. Can't see it
      11-13-2009, 02:53 PM   #50
baarii
baarii's Avatar
Drives: ..
+1
      11-13-2009, 02:58 PM   #51
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Videos should be working now. Sorry.
      11-13-2009, 07:50 PM   #52
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Are the videos working?
      11-13-2009, 07:54 PM   #53
Subw00er
Bates '08 Interlagos Launch
Subw00er's Avatar
Drives: 440i xGC, ZL1, JCW
Ya!!! They sure are! I really wanna hear what sounds on take off!
Sounds pretty good so far. Nice backfire!
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740
      11-13-2009, 08:09 PM   #54
3XTR3M3
3XTR3M3's Avatar
its so hard to tell from the videos. Sounds just like stock but louder I guess?
      11-13-2009, 10:11 PM   #55
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
They seem quiet on the video but they are VERY loud.
If the weather clears up, I can get better video.
      11-14-2009, 04:25 AM   #56
gasterus
gasterus's Avatar
Drives: M6
Sounds like Meisterschaft HP Touring
07 M6 blk/blk, Racing Dynamics RS58 stroker with custom ECU tune, Primary cat bypassed+Akrapovic Evolution exhaust, BMC air filters, RPI air scoops, H&R springs, Dinan FRC & rear sway bar, 20" AC Schnitzer V
08 E92 M3 sparkling graphite/red, Competition pack, Innotech exhaust
      11-14-2009, 12:18 PM   #57
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
OK, Change of plans. After yesterday's test run, I decided to unwrap the two smaller exposed sections. I think the system needs some absorption. I clamped down the wrap on the pipes that have the larger amount of perforations. I'll re-stuff the chambers with absorption material and see how it goes.
      11-14-2009, 01:25 PM   #58
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
OK, I bolted it back up again. I am gonna go start her up and video it again.
      11-14-2009, 01:48 PM   #59
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
I just finished the videos. I think I got what I was looking for.
By keeping the smaller set of perforations and re-stuffing the chambers, the exhaust is still MUCH louder but not insane like it was before.
Videos are processing as I type this.
      11-14-2009, 02:15 PM   #60
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Here you go... I recorded at different angles. I noticed that the recording sound changes a lot when the camera is in different locations.
      11-14-2009, 02:49 PM   #61
Poppin Fresh
Poppin Fresh's Avatar
Philippines
86
Drives: With a sunroof and front plate
Dude that sounds really good IMO! Good job! You gotta do a final summary of your work. Judging by your plates and your name...I'll take a shot in the dark here. You're a Periodontist?
      11-14-2009, 02:59 PM   #62
JCtx
Drives: No BMW yet
Sounds a bit too much like a pushrod V8 at certain angles and rpm, rather than the technological marvel that it is, but surprisingly, better than most aftermarket exhausts I've heard. Not bad for a relatively simple procedure .
Hey, better loose the duct tape if you plan to take it for a ride man; you'll never be able to remove it afterwards. Good job. Curious about the volume/drone inside the car. Keep us posted.
      11-14-2009, 03:06 PM   #63
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
Bingo!
      11-14-2009, 03:15 PM   #64
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
It is hard to truly represent the sound via video. I guess it has to be heard in person. Of course I need to get videos of it driving. I am going to weld it shut first so I can get rid of the tape.
      11-14-2009, 03:19 PM   #65
Edman951
Edman951's Avatar
50
Drives: 2014 i3, Capparis White
Nice work, it's always cool to try different things.
Hope to see a driving video soon.
      11-15-2009, 08:10 AM   #66
Periokid
Periokid's Avatar
61
Drives: 2015 F80 M3
I removed the unit from my car and sent it to be welded. I will post new videos once I install it on the car.
m3post
