seat airbags, seat occupancy sensor disable ?
12-15-2012, 10:09 AM | #47 |
Rep 9,097
In case of accident, will any airbag deploy with this coding?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
12-15-2012, 10:30 AM | #48 |
442
Rep 18,331
12-16-2012, 11:51 PM | #50 |
Rep 954
Did this to clear my my airbag and passenger seat lights on my dash... the coding method from apkraven works perfectly! I followed what he said here:
hey, i finally got time to manage the coding thing, the options to disable the seat airbags are called : sidebag_links sidebag_rechts (set to nicht_aktiv) the option to disable the seat occupancy sensor both contain "oc3" (set to nicht_aktiv) both in ABG module of course. hope it helps someone. i now have fully functioning 911 seats in my 335i instead of ugly and unsporty leatherette stockers I didn't have to play around with the airbag coding... I just disabled the OC3 and cleared any errors I got in INPA
2006 E90 325i | Sports Package | 6MT | 3IM | PE | AA |
12-17-2012, 07:07 PM | #51 |
Rep 3,223
Drives: 2018 BMW 440i GC
Can someone confirm that this is the icon you see when you have this issue?
Can someone summarize the way to code out the error? If there is a way to diagnose the real issue and correct it, can someone please explain |
brianziho0.00 |
12-17-2012, 08:09 PM | #52 | |
Rep 954
to do this, you need NCSexpert. (go to the "BMW Coding Success" thread and follow the DIY instructions step by step). If you are familiar with using NCSexpert, the go to the ABG module, look for the "OC3" and disable it. If the above steps dont' make sense to you still, please read through this thread & read this .PDF carefully
12-17-2012, 08:35 PM | #53 |
Rep 3,223
I see that this was a recall issue for 2006 3-series with non-sport seats and other models. Did anyone else have this replaced under warrentee?
http://www-odi.nhtsa.dot.gov/recalls...intVersion=YES |
12-17-2012, 09:33 PM | #54 |
Rep 885
Okay so, I did an interior swap, and my old seats had these warning lights, and the new seats I have have the same issue? Bad occupancy sensor? Seems unlikely. Wish I could just read the airbag module so I could get some detailed info. Like when the error occured.
12-23-2012, 04:46 PM | #55 |
Rep 1,933
If you're getting the restraint malfunction code on your dash, you can disable the passenger occupancy mat. With the code thrown, the passenger airbag is off regardless. Once you disable the occupancy mat, I'm fairly certain I read that the passenger airbags are always on so you do not need to worry
12-23-2012, 04:49 PM | #56 | |
Rep 3,223
04-29-2013, 03:25 PM | #57 |
Rep 104
This method does work. You need to code it out, disconnect it then clear the code.
335i JB4 g5 iso backend flash BMS DCI walbro inline pump vrsf 7'' intercooler vrsf dp -Car sold 135i |
04-29-2013, 03:39 PM | #58 |
Rep 3,223
04-29-2013, 07:19 PM | #59 |
Rep 104
1.You must use ncs expert to code the OC3 vales to non active, there are two.
2.Then disconnect the sensor for the mat under your passenger seat which is located at the back of the seat. 3.Clear the code by which ever you like, inpa bt tool ect. FYI you will not be able to clear the code while the sensor is still plugged in, i tried but you have to disconnect it. 4. No more red lights on dash, or passengers asking if their airbags work
08-15-2013, 05:02 PM | #60 | |
Rep 25
It worked!!! First time, it didn't want to budge, but I erased the TRC and MAN files and reread and rewrote it with the new codings and it worked. |
08-22-2013, 05:59 PM | #61 |
Rep 5
My OC3 is already set to not active but if I disconnect the mat from the seat the fault shows up on the dash and wont clear. Any advice on how to fix this?
Cheers Incase any one has same problem I sorted it by setting SBE1_1_CD to not active Last edited by Wan15bad; 08-23-2013 at 01:31 PM.. Reason: Update |
09-03-2013, 10:02 AM | #62 |
Rep 8
Thank you, nicht_active SBE1_1_CD saved my day. Any idea what does SBE1_1_CD stands for? BTW, once you turned of mat sensor, there is no seatbelt warning if there's a passenger and seatbelt unbuckled, right?
04-24-2014, 12:37 AM | #64 |
Rep 6
E90 320i 2005 BMW - Restraint system faulty
Hi all,
i tried many different ways to clear the same error on my E90 2005 BMW 320i - no luck what so ever Tried INPA to clear - it says cleared but nothing happens Tried NCS to disable - but no luck either - i coudint find SBE1_1_CD under the module ABG only SBE1_1 is avaialble any help at all is much appreciated thanks |
04-24-2014, 07:37 AM | #65 | |
Rep 6
E90 320i 2005 BMW - Restraint system faulty - please help
i tried many different ways to clear the same error on my E90 2005 BMW 320i - no luck what so ever Tried INPA to clear - it says cleared but nothing happens Tried NCS to disable - but no luck either - i coudint find SBE1_1_CD under the module ABG only SBE1_1 is avaialble any help at all is much appreciated thanks Also i've just installed all the latest version of INPA and NCS and NCS dummy and datan 50 for E89 as well - all ready to test if some one can tell me what codes should i disable in what module Secondly what if i want to change all modules back to factory settings just in-case if i muck it up Cheers in advance |
03-30-2015, 03:52 PM | #66 |
Member
17
Rep 141
I've just been doon a car tonight (2008 e92) and he lad has put a bypass kit in to stop the error light
Cleared all codes but it keeps coming back as SBE on the airbag module Any ideas? Does he need to unplug the bupass kit and just code it out? Is the seatbelt pretentionor able to be coded out at all? Cheers |
