The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Changing triple turn signal blink count
      02-12-2012, 03:16 PM   #45
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
Is anyone willing to write a DIY for dummies for this? I'm just starting with some basic coding and going into NETTODAT file seems a bit scary... I'd really like 5 blinks on our 2008 and 2012 3ers
      02-12-2012, 09:17 PM   #46
bmw325i
Drives: 2006 BMW 325i
I'm interested in doing this but what module do I get the NETTODAT file from. Also hoe do I know where to change the number of blinks.
      02-17-2012, 04:57 PM   #47
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
It's in every module. Just look in your 'work' folder.
      02-18-2012, 01:39 PM   #48
bmw325i
I actually meant which file do I need to get the NETTODAT file from to change the blink count.
edit- went out to try and figure it out. I think I found where to change it here is the line from my NETTODAT
1 2 PARAMETER NAME
PARAMETER VALUE
* B 00340300,0010,F1,00,00,28,0F,28,0F,28,0F,00,00,00,00,0E,00,00
* B 00340300,0010,F1,00,00,28,07,28,0F,28,0F,00,00,00,00,0E,00,00
Bottom one is 1 blink top is 3 so would I change it to the following for 4 blinks?
B 00340300,0010,F1,00,00,28,13,28,0F,28,0F,00,00,00,00,0E,00,00
After I edit the NETTODAT file what do I do with it? Thanks in advance
      03-01-2012, 12:11 PM   #49
Escarlinrivas
Drives: 2007 bmw 330xi
Anybody knows how to to codimg in the new yor new jersey pa
area.
For folding mirrors with key remote and windows , etc thanks..
      03-08-2012, 04:17 PM   #50
bmw325i
1 2 PARAMETER NAME
PARAMETER VALUE
Still need help with this
      03-09-2012, 01:18 AM   #51
Rotary Rasp
241
you have to apply the new nettodat file. it's under the basic functions tab.
sgcodennattodat or something like that
      03-10-2012, 01:07 PM   #52
bmw325i
So was I correct on what to change I'll probably mess with it again tomorrow.
      03-12-2012, 01:12 PM   #53
dluke
Sh!t happens... Deal with it
dluke's Avatar
Drives: '06 Alpine 330i
'06 BMW 330i  [0.00]
hey guys,
i have a few questions, if you could possibly help me out it would be much appreciated.
first let me make sure that i am even taking the correct steps to change the blink count. (i have '06 E90 330i) so when changing all the other vehicle options that ive chaged (i.e. digital speedometer and windows close with fob), ive done so within the CAS ecu and then whatever module, but now to change the blink count we do so within the NFRM ecu instead of the CAS? and then from there i basically read the FRM module once with 1 blink set and once with 3 blink set. then compared the nettodat.trc files and located the one value that changed and then changed it to the 6 blink value (which from what i got reading this whole thread and the one on ********* for same topic, i think it should be '1B') and saved as NETTODAT.MAN in the work folder. and then providing that everything i just explained is correct (please let me know what i did wrong so far, if anything), this is were i got the error. i got the error right after i selected the 'basic function' 'coapiCodeSgNettoData'. the error just said "Fehler Beim Einlesen Der Nettodataliste" which basically translates to 'failed to read the nettodat file'. any idea whats going on, or what i did wrong? any input would be greatly appreciated.
thanks,
dluke
      03-20-2012, 02:43 PM   #54
dluke
dluke's Avatar
'06 BMW 330i  [0.00]
blink count
hey all,
so i still haven't figured out why my NCS is unable to read the nettodat file when trying to change the blink count. but if anyone else is having trouble with changing this feature via the nettodat method, i was able to successfully change my turn signal blink count to 6 blinks through a different method. although same as with the nettodat method, changing it within the idrive afterwards will erase it, but it will stay otherwise. also just incase, i did this on my 06 e90 330i, whether or not it will work in the same manor on other years/models i have no idea. so anyways what i ended up doing was editing the daten file for the module containing the blink count (btw many hours of research went into this.. didnt just go in and start changing the daten file blindly). for me the daten file i needed to change was FRMFA.C11. first disassembled the file with NCS Dummy (Thanks to Revtor for creating an amazing program). then located the function MIND_ANZ_ZYKL_TIPP_BLK. (the disassembled file will look something like the attached pic) then just changed the highlighted field on the attached pic from '01' to '06' for six blinks. then re-assembled the file with NCS Dummy. **before you replace the original daten file with the new edited one you will want to get an FSW TRC file with the triple blink turned off. then create a PSW MAN with that trace file without changing anything. now replace the original daten file with the edited one and then just code the unedited .MAN file to the car. now after the coding is done just double check that your triple turn signal is turned off and turn your car off, then turn the car back on and tap your blinker!
-any questions or need me to explain anything or explain why this works just PM me.
-btw thanks to everyone that paved the way for us new coders
dluke
      03-20-2012, 11:00 PM   #55
wdlfbio
Wow. You wanted this bad. Good for you. I think I need another glass of wine and then reread this
      03-21-2012, 01:24 PM   #56
dluke
dluke's Avatar
'06 BMW 330i  [0.00]
haha ya.. when i first bought the car this was the first thing that i wondered about being able to change, and ultimately what got me into coding. and then it was the last coding mod i had left to figure out.. so yes i was pretty determined.. plus once i start something and get stuck, i cant rest until i find a solution.
      03-21-2012, 01:34 PM   #57
mot
Drives: e92 AW M3 6MT
You must be an engineer.
      03-21-2012, 02:16 PM   #58
dluke
dluke's Avatar
'06 BMW 330i  [0.00]
lol.. never quite got there.. i started a civil engineering degree years back but never completed.. i guess thats what i get for picking the #1 party school in the nation haha.. Go DEVILS!! (Arizona State for those that dont watch college sports)
      03-22-2012, 10:31 AM   #59
Rotary Rasp
241
hey all,
dluke
Nice work!
      03-22-2012, 12:22 PM   #60
dluke
dluke's Avatar
'06 BMW 330i  [0.00]
Nice work!
thanks man!
      03-22-2012, 11:02 PM   #61
bmw325i
I will try editing the daten file since I still haven't figured out how to do this using nettodat thanks.
      03-22-2012, 11:14 PM   #62
BMWonderful
When I think of something witty it will go here
BMWonderful's Avatar
Drives: E90 330
It's actually very easy.
Judging by the discussion you guys are having and how it's making my head hurt just reading it, I would have to say that sentence seems to be very dependent upon the person reading it.
      03-25-2012, 07:46 PM   #63
steelersfan
steelersfan's Avatar
Drives: 11 335i E90 M-Sport
2011 BMW 335i  [0.00]
Originally Posted by srwatters View Post
While this is true, it perhaps isn't really obvious that you need to use the code via NETTODAT option. The option is MIND_ANZ_ZYKL_TIPP_BLK. The parameter needs to be custom added with the data being the number of blinks you want (I used 4). From there you can export the trace data as a NETTODAT.MAN file and write it back to the module using the job coapiCodeSgByNettoData. It's all explained in the NCSdummy thread "Taking the expert out of NCS expert".
Good luck!
For those who need a better explanation of how to accomplish this...
You need to scan the NETTODAT file once with the triple blink disabled within the gauge cluster (or idrive) and once again with it enabled. Then use beyond compare to scan the two NETTODAT files and find the value that has changed. That value is the HEX value you need to modify to increase the blink count.
Once you've changed it from XX to 37 (or whatever), save the NETTODAT file as NETTODAT.MAN and recode the car using the codeNETTODAT command.
Hope this helps.
I think I got there based on the 2 quoted posts, although I will mention that no where in this thread (unless I missed it) is there a mention of which module you should be reading to get the correct NETTODAT.TRC file in order to change the blink count. srwatters' post mentioning the option "MIND_ANZ_ZYKL_TIPP_BLK" was the key I needed to get there. I found that option in the NFRM module. And after going through the process of setting the blink count to 1 and then 3 and using the "beyond compare" program to compare the 2 nettodat trace files, Blink set to 1 = 0x04 where Blink count set to 3 = 0x0C. Makes perfect sense based on srwatters conjecture in post #13 of this thread. Now I just have to do the deed and see if it works.
2011 335i Sedan | Le Mans Blue | ///M Sport | Performance Edition | WeissLicht AE's | AG 19" M355's |
      03-25-2012, 08:30 PM   #64
bmw325i
hey all,
dluke
I finally changed the blink count thanks to this. This is by far the easiest way. thanks
      03-26-2012, 12:56 AM   #65
dluke
dluke's Avatar
'06 BMW 330i  [0.00]
awesome!! im glad it helped!
      03-26-2012, 08:37 AM   #66
Dziqsek_
Poland
37
Drives: e91 320d
Easiest?? Come on, you go to module kombi and change one valuewith 3 blinia and thats all
