The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Something cool (n54 vs 3sm Page 5)
      11-21-2015, 02:44 AM   #45
Taskmaster
Japan
2470
Drives: M235i 6MT / E92 328 Msport 6MT
Originally Posted by hassmaschine View Post
It doesnt say anything about testing it at 8k. It just says it becomes less efficient at high rpm.
Mike, i was talking about what SDemetris said. I saw that BPC it tuning it to that, but the dyno posted so far ends at the stock redline.
Hass, for some reason they (and everyone else) seem to get less power from 325i's why? Would this mean gains are higher on 328i/MSV80 cars?
I just want a Plug and play kit....
      11-21-2015, 05:11 AM   #46
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
2046
Drives: F80 M3
2013 BMW 335xi  [10.00]
Ah ok. Also, the way they made it sounds it that both of those dynos are before the manual swap. They got that number intake/manifold/exhaust/tune/noTB which is really impressive.
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels
      11-21-2015, 05:39 AM   #47
W37V
[Oo=||=oO]
1105
Drives: e92n52 & f15n57
Bimmer Performance Center LLC
261/223 peak numbers so far and still the process of getting the power to carry out as far to 8000rpm as possible. Motor has turned 8000rpm already but are still in the process of scaling the powerband.
i wonder what that powerband looked liked.
Also, it appears there is a huge dip in power at 4500 rpm. I thought this dip mainly happens because of 3im. But they are not running any manifold. Does anyone know why is it still there?
      11-21-2015, 07:32 AM   #48
hassmaschine
Drives: "NBO" 330i
could be VANOS tuning
      11-21-2015, 07:37 AM   #49
hassmaschine
Drives: "NBO" 330i
less power than what? I don't think there's any advantage to a 328i over a 325i, or vice versa. Same engine, basically the same tune. This 325i seems to be doing OK?
also it doesn't look like they are running a filter. it needs a plenum/air box of some sort. a filter will probably drop that peak power a bit - 5hp or so. But you don't want to DD with no air filter.. Maybe it would be balanced out by not sucking in hot air from the engine bay.
      11-21-2015, 01:57 PM   #50
Taskmaster
Japan
2470
Their full bolt on 325i was lower (substantially) than a bolt on 328i, and the power peak occurred lower. Odd...
      11-21-2015, 02:01 PM   #51
hassmaschine
Drives: "NBO" 330i
Who knows. It was still an automatic. Theres no real difference between a 325i and 328i engine.
      11-21-2015, 02:04 PM   #52
Taskmaster
Japan
2470
Exactly, it has to be a software issue .
[IMG]http://i234.photobucket.com/albums/e...ps6cphukne.jpg[/IMG]
peak power at 6300rpm on a intake/header/exhaust/ tune car? Stock intake manifold, but that wouldn't make a difference.
      11-21-2015, 02:07 PM   #53
hassmaschine
Drives: "NBO" 330i
Its not the DME, they are the same as the 330i just with differences in the tune.
      11-21-2015, 02:17 PM   #54
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
On a side note, Did you notice the BMW N52 based Z4 2.5 SI tune retards the intake cam to 124.9 degrees while our tunes are limited to 120? It's the same actuator as the 3.0. Do you think the extra 5 degrees is something we should try to use?
You did mentioned it would be good to have an extra 5 or 10 degrees retard.
      11-21-2015, 03:09 PM   #55
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
Ya know, that might be part of the 'soft limiter', maybe used to differentiate performance. Gotta love marketing...
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
      11-21-2015, 03:56 PM   #56
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
I'm not sure I understand your comment. The 2.5 SI is a euro car only and BMW needed to create as much power from the 2.5 liter motor as they could. Even the high speed threshold for the Disa is moved up to 7500 RPM.
I bet the final gear is much higher and the car is set up to rev more than the bigger N52.
      11-21-2015, 04:00 PM   #57
Taskmaster
Japan
2470
Can you see if the cam retarding and dIsa threshold change anything?
      11-21-2015, 04:14 PM   #58
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
I've not tried the cam timing spread at the 125 degrees but I have moved the Disa threshold back to 7200 and it stopped closing before the gearshift. I still need more work on the soft limiter but it's really only kicking in around 6,850-6,900 rpm now. With a factory exhaust I don't se much point in going much further. I could be wrong.
      11-21-2015, 04:15 PM   #59
Taskmaster
Japan
2470
You should try it !!
      11-21-2015, 04:27 PM   #60
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
I probably will but right now I'm a little stuck sorting out the dynamic load limiter and knock control. I think I can spot the point were the DME switches on the load control and the ignition advance goes to hell. Part throttle up to that point is great, really beyond my earlier hopes. I don't want to screw up the knock control and blow a motor, so it's research and test.
This tuning thing has been a fun road to travel but I'm getting a lot of pressure from my loving wife to pick up an IS 350. My only argument to keep the Z4 is financial, it's paid for.
      11-21-2015, 04:45 PM   #61
justpete
2019 BMW M6  [10.00]
Yes but I was wondering if the N52 Vanos limit is similar. Hadn't thought of how different cars/engines might be limited in this way. Y'all know way way more than I do. Back to lurking...
      11-21-2015, 08:37 PM   #62
hassmaschine
Drives: "NBO" 330i
Hm, interesting - i havent seen that. All the n52 tunes ive seen max out at 120 degrees. Do you have a binary i could look at?
If its not mechanically limited to 120 degrees, then yes another 5 degrees should pick up some power.
It would be nice to see what other changes they made. I already changed the upper threshold from 6900 to 7500 and it seems to help.
      11-22-2015, 07:08 AM   #63
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
Here you go,
I created a BIN from the S7581341.ODA file.
I'd like to see the actual dyno power curve from this motor.
Richard
      11-22-2015, 04:43 PM   #64
Taskmaster
Japan
2470
You know, it's just runners functioning like ITBs, if there was a larger plenum and a snorkel hooked to the TB/MAF, this would be a Plug and play (plus tuning) affair. Then again, AA got close to those numbers with the 3 stage and stock exhaust.
      11-22-2015, 07:11 PM   #65
Taskmaster
Japan
2470
What about an N54/N55 throttle body? That would be step one I imagine...
      11-22-2015, 08:01 PM   #66
hassmaschine
Drives: "NBO" 330i
Why not just delete it altogether?
