BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > +1mm Modified Intake Lift Valvetronic Supports- 'MILVs' N52
Closed Thread
      12-13-2016, 08:01 PM   #45
weehe126
Drives: 2017 340i
Originally Posted by hassmaschine View Post
the N55 uses all the same valvetrain parts as the N52 (the eccentric shaft is a little different, but this is mostly due to the smaller/faster valvetronic motor). Consequently, the maximum lift is the same (~9.9mm).
I would just set it to 10mm. It's not going to "break" anything. It appears that what happens is the DME will try to adapt closer to the 10mm target as it can get, where if you leave it at the stock setting it will be closer to 9.5-9.6mm in reality.
It also means that any valve lift mods that work on the N52 should also work on the N55.
I agree any mod for the N52 will work for the N55, but I am not following your logic on the only 9.5-9.6mm stock lift. The stock table lists 9.8mm at 100% throttle, why would you think it is only reaching 9.5-9.6mm? Throttle is at 100% in logs, so it's not trying to limit boost or close the valves.
I just want to compare what the stock N52 table lists vs what the literature has as max lift.
      12-13-2016, 08:11 PM   #46
hassmaschine
Drives: "NBO" 330i
9.8 is the base factor. A whole host of other factors are included in the actual lift value - adaptations, torque adjustments, etc . so just because the WOT map says 9.8mm, doesn't mean its opening the valves exactly 9.8mm.
Throttle opening has nothing to do with it. On the N52, the throttle plate is open 100% at 60% pedal value - the N55 will be similar.
Stock 330i tune maxes out at 9.7mm. 325i and 328i have less but they are detuned.
JohnG716.00
      12-14-2016, 07:15 PM   #47
CobraMarty
CobraMarty's Avatar
620
Drives: 2007 328xi e90 + e92
There is a hard stop on the Eccentric cam, so at mac Ecc Cam- max valve life will be 9.7-9.8, N55 maybe 9.9mm. There is no getting more that the hard stop. If you program in 12mm, it will still only go to the max at the hard stop.
And it might not even go all the way to the hard stop. I think that the min and max hard stops are for the ECU to calibrate and check the range of the ECC Cam sensor.
Something like- Take a reading at close, zap the ECC Cam motor till it hits the max hard stop, take a reading and then back to the min hard start and then the engine starts. Now the ECU knows where the max hard stop is at.
      12-14-2016, 08:25 PM   #48
hassmaschine
Drives: "NBO" 330i
the values in the valve lift maps are commanded targets - they are not used to learn the valvetronic stops. the "learn stops" algorithm is separate entirely, and it is generally only run once (if there's a change or adaptations are cleared).
per BMW, the maximum lift is 9.9mm which I take to mean at the mechanical limits of the eccentric shaft. In practice (due to adaptations and other factors I mentioned), if you command 9.7mm you will get about 9.5mm, consequentially, if you command 10mm you might get closer to the 9.9mm maximum although obviously 10mm is not possible.
I now have a full disassembly of MSV70 with all memory values named and mapped, so I can study this a bit further, although sometimes the math can be difficult to follow..
JohnG716.00
      12-15-2016, 07:13 AM   #49
CobraMarty
CobraMarty's Avatar
620
From another thread-
Originally Posted by Bob@BPC View Post
The head and valves on the car are BEAST, but the cams and vanos hold the engine back from making more.
Good street numbers with our tune, AA headers, 3 stage or n54 intake manifold, no maf & full exhaust will make around 245 - 255rwhp.
This is good to know that the cams are holding back power.
Hopefully another 0.5mm of lift will help that out.
      12-19-2016, 06:15 PM   #50
Taskmaster
Japan
2470
Drives: M235i 6MT / E92 328 Msport 6MT
It's next week.
      12-19-2016, 06:43 PM   #51
CobraMarty
CobraMarty's Avatar
620
Picked up parts from the machinist last week after working nights. Now out of town working for a living. Will be home late tomorrow night.
Should be able to test the last #3 version and then decide which version to use.
Then drop off some more to get machined. And then the holidays get in the way.
Might be able to send one to HassMachine to test fit and measure on his engine.
rjahl997.50
Taskmaster2470.00
      12-20-2016, 11:08 AM   #52
hassmaschine
Drives: "NBO" 330i
That would be awesome! I'm going to start disassembling my head soon.
      12-20-2016, 01:56 PM   #53
Taskmaster
Japan
2470
How about now? Or yesterday!
      12-20-2016, 03:51 PM   #54
hassmaschine
Drives: "NBO" 330i
Yesterday I got off a cruise ship from Mexico. Today, I feel like the ground is still moving..
      12-20-2016, 04:36 PM   #55
Taskmaster
Japan
2470
I hope you didn't drink the water.
So, there is always tomorrow.
      01-09-2017, 04:25 PM   #56
Taskmaster
Japan
2470
BUMP. I need this.
I want this.
      01-09-2017, 06:37 PM   #57
CobraMarty
CobraMarty's Avatar
620
I'm just being a post holiday new year lazy bum with busy regular work gig thrown in and 20* weather.
I did get 2 more sets of parts to get machined. Now have 7 sets for the machinist. 3 new and 4 used. The used pieces have no measurable wear. They are probably better as they have been heat cycled and hardened.
I still have to install version 3 mod and measure it out but I think that it will be version 2 that will get the nod, it has half the machining steps as version 3 and version 3 might add too much lift than I feel comfortable with.
To install this mod, the valve cover has to come off and I would reckon that a new valve cover gasket kit would be needed also.
It also needs a 1/4" drive external torx socket E8 and short extension, 22mm socket to turn the crank, and a 1/4" torque wrench.
On the N55 turbo to N52 head front, none of the manifold mounting bolt holes line up. The port spacing does line up and when the ports are lined up, all the bolt holes don't line up.
So new plan is to make a 3/4" adapter plate that will bolt to the N52 head with counter sunk socket head bolts and the stock N52 studs will then be screwed into the adapter plate at the N55 bolt locations and then the N55 turbo will bolt on.
Actually the 3/4" plate will add needed clearance for one webbing rib on the block and the block water fitting.
N55 Turbo--->N52 exhaust studs--Adapter Plate--counter sunk socket bolts<---N52 head.
Adapter plate also needs to adapt the different size of the exhaust ports. It worked out perfect using a piece of 1.625" 0.063" wall tubing as the OD is the same as the N52 and the ID is the same as the N55.
The first plate will be made in HDPE with alumn tubes because it is the easiest to work with for the mocking up.
Ruddigger694.00
David0ff1060.50
      01-09-2017, 07:53 PM   #58
Taskmaster
Japan
2470
Remind us again, what's v1 v2 and v3?
      01-09-2017, 09:10 PM   #59
CobraMarty
CobraMarty's Avatar
620
(early is less than 140* and late is over 140*)
v1 mods- early slightly lagged stock lift and late more than stock but less than v2 (I didn't graph this v1)
v2 mods- completely different mods than v1, v2 is shown on 1st page graph, slightly increases lift early and more late as compared to stock
v3 mods- has both v1 and v2 mods together, I hope that v1 will decrease the early rise above stock lift of v2 and add just a little more lift later
      01-09-2017, 09:45 PM   #60
Taskmaster
Japan
2470
Plan on hitting the dyno?
      01-11-2017, 05:38 PM   #61
CobraMarty
CobraMarty's Avatar
620
Not my pictures but I will use them to illustrate install.
Taskmaster2470.00
Keidame10.00
      01-12-2017, 07:50 AM   #62
CobraMarty
CobraMarty's Avatar
620
The rectangular 'support' in the 3rd picture (that is what BMW calls it) is the piece that gets modified, machined and needs to get changed out. Unfortunately it is not a simple unbolt and replace. It just doesn't slip out when unbolted.
N52 + N55 – Twin cam, 4 valves per cylinder, valvetronic engines produced from mid 2000s to current (US), Cylinder numbering is from front to rear; 1 at the front and 6 at the rear.
Ignition firing order is 1-5-3-6-2-4.
Use this order sequence to minimize the amount of crank rotation
Sequence that I have found works reliably is-
1- remove valve cover, there are plenty of write ups about how to do this
2- rotate engine CLOCKWISE until #1 intake cam lobe center is pointing just above the eccentric cam, this will put a slight downward pressure on the intermediate rocker lower roller wheel
3- loosen the bolt holding the spring in place exactly 5 turns. NO MORE! or you risk the bolt coming out and spring coming off and MAJOR hassle to replace spring back into place without spending $300 for a special tool. Be warned
4- insert spacer under spring and tighten. COUNT how many turns to tighten. This will raise the spring 'coils' up enough to allow for the 'support' to be removed.
5- remove the 2 bolts holding the 'support' in place
6- wiggle free and remove the stock 'support' and replace with modified 'support'
8- while pushing 'support' towards the exhaust cam, tighten 'support' bolts to spec (120 in lb, **105 in lb for the bolt with oil squirter, Cyl #3**)
7- loosen spring bolt exactly the same number of turns required to tighten in step 4. This will keep the spring bolt still only loosened 5 turns total
8- remove spacer under spring and tighten spring bolt to spec (95 in lb)
9- repeat for other 'supports' Use sequence cylinder 1-5-3-6-2-4.
10- replace valve cover. NOW is a good time to use a NEW valve cover gasket kit
MOST Important is to turn over the engine CW to get the intake cam lobe into the proper position and ONLY loosen the spring bolt a MAXIMUM of 5 turns.
'Special' tools required- (I sourced all these online)
1- E8 external torx socket and short 1/4" extension and 1/4" ratchet or 3/8" adapter to remove 'support' and loosen spring bolts
2- 22mm socket for crank bolt to rotate engine clock wise
3- 1/4" torque wrench to tighten 'support' and spring to spec- inch pounds (in lb)
4- spring spacer to lift the spring and it's coils to allow the 'support' to be removed(included with modified supports)
Appreciate 4
Taskmaster2470.00
rjahl997.50
6ixSpd6034.50
Keidame10.00
      01-12-2017, 08:48 AM   #63
Taskmaster
Japan
2470
8- remove spacer under spring and tighten spring bolt to spec.
Fantastic!
When are we going to do some live testing?
      01-12-2017, 09:06 AM   #64
hassmaschine
Drives: "NBO" 330i
Should work on the S55 too
http://www.realoem.com/bmw/enUS/partxref?q=+11377583781
      01-12-2017, 02:42 PM   #65
CobraMarty
CobraMarty's Avatar
620
Even the newer engines with the 'springs' and 'Eccentric cam motor' down low, they use the same part and would be a much easier install.
      01-12-2017, 02:48 PM   #66
CobraMarty
CobraMarty's Avatar
620
The part is die cast, super precise and accurate out of the mold. No additional machining required or done by BMW. They are steel and are not hardened. Very expensive to manufacture unless you are making a few million of them, like BMW.
Closed Thread
