BMW X3 Forum
BMW X3 Forum
      03-11-2019, 01:34 PM   #45
zilunz
Drives: 2012 BMW 535XI
Originally Posted by Rulz View Post
Rear passenger side.
was that part in the car or under the car ?
      03-11-2019, 02:23 PM   #46
E90705
E90705's Avatar
Drives: E90/F25 M-sport
Under
      03-11-2019, 06:32 PM   #47
zilunz
thank you,but i just try the both side and don't see anything...I took the pics, the blue wire is the diver side and other pics is the passenger side.
      03-11-2019, 07:37 PM   #48
E90705
E90705's Avatar
There you go
      03-11-2019, 09:28 PM   #49
zilunz
thank you I will try tmr and see if i can find it.
      03-12-2019, 09:24 AM   #50
F30ed
71
Drives: F30 328i, X3 35M
RDC is tricky, another example of German over-engineering. New RDC module needs to be linked to the system, for which Dealer in my case had to program the whole car to the new I-level (from 2013-11 to 2018-11)
      03-12-2019, 10:03 AM   #51
zilunz
still nothing in there ....
      03-12-2019, 06:04 PM   #52
zilunz
Got it! mine is actually located at the left side of rear bumper
      03-12-2019, 06:46 PM   #53
aspame82
Mr
Peru
21
Drives: BMW X3 XDrive28i Xline 2017
Hi, could you please show a picture with the connections to the trunk? I am doing the retrofit and I would like to know how the control module is connected to the car.
      07-25-2019, 01:53 AM   #54
bikoo
Drives: F30 328i Sport
i Have F30 328i Sprot 2013 i coudn't find it! any help
      12-29-2019, 08:52 PM   #55
fmoraes
Drives: 2011 BMW X3
RDC module removing
Hi kmarei.
I was living in Reston not too long ago. It's matter of fact I bought my BMW X3 in Dumfries I wish I had seen this forum before. Now I live in NYC.
Anyway...
I am having same problems with the RDC module. I changed all the tire sensors, and the guys from Mavis reprogrammed all the sensors but still didn't work. I want to remove the RDC module, but i am don't want to break it. Is it just to pull it out? Is there any screws or lock pin connecting to the case?
How do I check if the problem is the RDC? I am afraid the sensor they installed does not match my car. They said it is universal and works on most of the cars.
Thank you for your time.
      12-31-2019, 10:18 PM   #56
joshaguirre
joshaguirre's Avatar
Drives: 2016 X3 xDrive28i F25
I know you ended up finding the location but for future reference I'd highly recommend utilizing BMW Atlanta's part website! I've used it many times and it will give you a general idea on where a part will be on the vehicle.
      01-01-2020, 04:52 PM   #57
kmarei
kmarei's Avatar
Egypt
689
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Originally Posted by fmoraes View Post
Hi kmarei.
Anyway...
I sold my car
But there is a plastic clip you have to undo to remove the rdc module
Then unplug the old one and refit the new one and clip that plastic clip again
No screws or tools needed
What I did was to remove the old one
Get the exact same part number used from eBay
I think I paid $60 and that fixed my issue
      01-05-2020, 04:55 PM   #58
fmoraes
Drives: 2011 BMW X3
I think it is the new tire sensor that i installed can't communicate with the TPMS module. So i am getting new sensor this week. If that doesn't work, then I will get new module.
Thank you for the information... I don't want to break the module.
FYI, i went to the BMW in NY and the prices are ridiculous:
$445 for module
$140 for each tire sensor
$40 for each tire stems.
Thank you very much!
      01-09-2020, 12:54 PM   #59
jmevox
Drives: Evo, CLA45
$445 for module
A BMW dealership in New York wanted to charge my girlfriend 900 to replace the RDC module in her 328xi. I read up on the forums and bought a used module on ebay for 60 bucks and a cable for 30. Probably took me 3 minutes total to replace the module and code it. Works perfectly now. The hardest part is downloading all of the software for inpa and ncs expert
      05-02-2020, 07:46 AM   #60
fmoraes
Drives: 2011 BMW X3
RDC module coding?
Hello,
thanks for the info. I am planning to do this next in 2 weeks when I have some free time.
How do you code the new RDC module? Did you need at special tool?
      12-20-2020, 09:22 AM   #61
Peepers
Peepers's Avatar
24
Drives: '11 335xi & '97 Spyder GSX
Plug and Play - Old vs New?
Hey guys, so the infamous RDC failure just happened on my 2014 X3. I pulled the RDC module out, opened it up and it was full corrosion - same that everyone has reported and seen on YouTube https://www.youtube.com/watch?v=8Vu7GTFcZjU
My module is part number 36106857938-02 (SW.02.0D.02). Of course it's been disco'd and replaced with 36106881433. The question I have is 36106881433 simply "plug and play" or will 36106881433 require coding? I would like to buy a new module vs. the used eBay route because I'm sure the eBay used one will have some sort of corrosion and eventually fail however I don't really want to deal with coding
Thoughts?
2014 BMW F25 X3 2.8i MSport
2011 BMW E92 335xi
1997 Eclipse Spyder GSX (yes, an AWD Spyder - one of a few in Canada) - 12.7 @ 110 mph w/ 1.8 60'
      12-20-2020, 08:23 PM   #62
e30lover318i
Drives: E30,E34T,E46,F48
There is no coding required for the tire pressure antenna. From my research they seem to be very specific on the chassis range. It’s seems to be related to Idrive for example CIC and NBT would have different antennas, as long as the part you get is the “updated” version you should be plug and play.
Forgot to add if you get used you also will not need to do coding
      12-21-2020, 12:49 PM   #63
TwinSnailz
TwinSnailz's Avatar
78
Drives: 2011 X5//M
Did you not at least read some of the post?
Everyone who changed the rdc including me had to code it regardless of old,new,used, or updated version.
      12-21-2020, 04:42 PM   #64
e30lover318i
Originally Posted by kmarei View Post
Finally replaced my RDC module
Found one on ebay with the same exact part number
Same sw version
It was actually made the day after my original one
Plugged it on today, and it worked fine
No need for reprogramming or anything
So I guess take your faulty rdc module out
Get the exact part number and make sure the sw version matches
And you should be good to go
Cost me $60
Instead of $900 at BMW of sterling , VA
Yes I did read. Ive replaced 10-11 antennas on a variety of chassis including my own no coding required on my end... I’m sorry YOUR F25 required coding but here’s a post from page 1
      12-21-2020, 09:34 PM   #65
kmarei
kmarei's Avatar
Egypt
689
Not true
I had replaced my module with a used one from eBay and I did not have to do any coding
      12-22-2020, 03:31 PM   #66
one9kilo
Drives: 2014 BMW F25
I've replaced my RDC on my F25 with a used one but I needed to code it. I thought I bought the "right" RDC but I guess the version was not an exact match?
Anyways, this is good to know information. Thanks fellas.
xbimmers
