12-01-2015, 01:43 PM | #45 | |
You got my money?
3248
Rep 4,716
Drives: Ice Cream Truck
I plan to redo mine today too. So did everyone literally use all those set screws into the bottom part of the carbon splitters too? The ones you must drill all those holes into. I did, but I did like doing it. So many holes! However, its nice knowing my carbon splitters can be yanked off anymore.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
12-01-2015, 01:46 PM | #46 | |
Rep 3,661
Thanks.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
12-01-2015, 01:51 PM | #47 | |
You got my money?
3248
Rep 4,716
PS: I called two dealerships looking for help. BOTH, repeat BOTH said, they are just as lost as us and that this lip. Great.
12-01-2015, 01:58 PM | #48 | |
Rep 3,661
12-01-2015, 02:30 PM | #49 | ||
You got my money?
3248
Rep 4,716
How the hell do you get your hand way inside there? Because I tired and there is no way to get your hand where those recessed bolts are man. You just rattling off do this or that, or this goes here or there without a diagram, video, or picture showing us exactly what to do. And did you even use those plastic bars with clips? No, you said you used a set screw instead. If it was so easy to do, why cut corners? And you didnt even install your lip correctly by your OWN words! SO you COME on!
12-01-2015, 02:32 PM | #51 |
Rep 3,661
I would have but honestly I didn't understand most of your responses. Anyways, I'll go back and appreciate all of them if that makes you happy
12-01-2015, 02:37 PM | #52 | ||
You got my money?
3248
Rep 4,716
So we make a slit somewhere for a c lip. Then we use a bolt. Not sure what bolt, as the box came with a lot. But we use a bolt. All the parts have numbers on them, but zero reference to what goes where. But we choose a bolt. You and the guy who made this install sheet must be related.
12-01-2015, 02:39 PM | #53 |
You got my money?
3248
Rep 4,716
I wouldnt pump his ego anymore, he might float away.
12-01-2015, 02:42 PM | #54 | |
You got my money?
3248
Rep 4,716
I have like 6 holes going THRU my carbon slippers PER SIDE. Thats right through the carbon splitter cover and the bumper its covering. Then I have two more holes at the bottom of the front fenders edge where the lip starts. And I have two more holes in the middle of the front bumper for the middle part of the M lip to be held in place. So I think there are 18 holes drilled in my bumper.
12-01-2015, 02:52 PM | #55 |
Rep 555
Can I ask a question about the splitter part? I just got my shipment from BMW. The splitters only came with adhesive tape, no Betalink.
Is this ok or do I need to order the Betalink? |
12-01-2015, 03:32 PM | #56 | |
Rep 595
Hope you have a great day!!!!. |
12-01-2015, 03:33 PM | #57 |
Rep 595
12-01-2015, 06:10 PM | #59 |
You got my money?
3248
Rep 4,716
That's not 3m double sided tape. That's black felt tape for the edge that meets the top edge of the bumper and carbon. If you have a white car you'd see a slim white line there. Using that tale makes it look matching black.
12-01-2015, 06:25 PM | #60 |
You got my money?
3248
Rep 4,716
Ok, let's see if us who can't figure this out can together.
Is this how this piece goes? If so, what am I cutting? Anyone know what we do here? Thanks
12-01-2015, 06:36 PM | #61 |
You got my money?
3248
Rep 4,716
Can anyone who has done this help us out? What do we do? These instructions are garbage.
12-01-2015, 07:39 PM | #62 | |
Rep 595
Are you matching the holes. There is two that need to line up. Once those line up you only cut the indented part of the template. leaving that part that is about 5 inches long.on the right side of the template. So you will split the rubber in about the point I am talking about(indented) and start cutting about 1/2 inch deep towards the left side taking the soft rubber and about 1/2of the hard plastic with the soft rubber. |
12-01-2015, 07:44 PM | #63 |
Rep 595
Now what are you taking about here. The carbon splitter overlay part has double sided 3M tape to stick to the bumper cover also has a little tab with hole to secure it to the Lip Spoiler and the deflector cover with a screw.. I did not have any felt tape in my overlay carbon piece that goes together with the lip.
12-01-2015, 07:47 PM | #64 | |
You got my money?
3248
Rep 4,716
Mine came with felt tape ONLY. It goes across the bumper where the splitter touches the plastic grill like mesh. Mine also had foam tape pre installed on the inside to hold, protect, or do whatever it does.
12-01-2015, 08:02 PM | #66 |
You got my money?
3248
Rep 4,716
They add a thick foam tape on the backside of the splitters now. Did yours have foam on the backside? If not, then they revised the install.
