2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Lets build an LCI MSport wheel and retrofit it!
      03-15-2024, 06:12 AM   #45
DS_BMW88
Sweden
21
Drives: BMW 218i Coupe
Originally Posted by idog View Post
Yeah, I'm measuring right now, but your F10 readings weren't the same as the F10 paddles I have here, the ones I have here are paddles from an F10 535i.
The -paddle
Off : 5.3kohm
On : 1.283kohm
The +paddle did match : 5.3kohm off and 2.297kohm on.
Anyway, I read your message wrong the first time. You said you were going to source SMD resistors in the right values. I read that as - get the same resistors that are now on the F10 paddles. Of course, you meant getting resistors to achieve the same off/on values as the F10 paddles are measuring. My bad. Now ordered again. It's a good thing these smd's are cheap
Edit : I stand corrected. Your measurements were on point. I'm an ass and measured the testpoints instead of the cable. Hence my bad reading for the - paddle. They work ! So thank you !
Could you please explain how you used the probes to measure the resistance. I read that it is actually not a good idea to measure on a live board.
      03-16-2024, 11:36 AM   #46
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Just use a multimeter. I used bent paper clips as "pins" for the connector and then attached the probes to the paper clip.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
      03-18-2024, 03:03 AM   #47
DS_BMW88
Sweden
21
Thanks! I haven't thought about that at all
      04-03-2024, 01:40 PM   #48
crm123
Drives: F01 pre LCI
Hello. I have a problem. I installed the steering wheel with paddles from the F10 LCI.
My car is F01 pre LCI and the paddles don't work.
What resistors do I need to use for the paddles to work?
Thx
5post
