01-16-2014, 08:50 PM | #45 |
Rep 1,300
I just installed new tires today. Hankook S1 Noble2. 255/40 - all around. The ride is smoother yet I feel more connected to the road. The feel has intensified approximately 15%+ . You can really feel the different. While I had the tires replaced I also painted the brake calipers gloss black. (No decals). I am going to enjoy this setup for about a week or so until I install the M5 sway bar. After that it will most likely be the Dinan springs.
01-17-2014, 08:53 AM | #46 | |
40
Rep 213
I am going for my fitment today! |
01-17-2014, 12:24 PM | #47 | |
Rep 94
255/35/20 is 27" 285/30/20 is 26.7" Your xDrive will not be happy with that. Try 245/35/20 (26.8" overall diameter) for the front. If you go for staggered setup you will need to keep the front and rear overall diameters as close as possible.
2017 F82 M4 CP - Black Sapphire Metallic - drive it like you stole it
2014 F10 550xi M Sport - Jet Black - gone 2010 E92 335i Coupe - Black Sapphire Metallic - gone 2004 E46 330xi Sedan - Black Sapphire Metallic - gone |
01-17-2014, 02:36 PM | #48 |
40
Rep 213
i know it is off by about 1.1%, but is it not that a difference of under 3% is ok, just wanted slightly wider tires as my front wheel is 20x9. and the ideal size for a 9" rim is 255.
Also, with slight tire pressure changes you can have that height difference between front and back with same tires on all four corners. Last edited by audiogolf; 01-17-2014 at 03:26 PM.. |
01-21-2014, 05:29 PM | #49 |
40
Rep 213
so finally had my wheels and tires fitted, will post pics as soon as this weather clears up.
wheels look really great. Dan, went with 245,35,20 instead of 255,35,20 for the front. could not really test the tires, as whole way back i was only driving at 25 miles per hour. will report soon. Also got the brake calipers painted in red, they give a nice contrast with dark bronze wheels and AW. |
01-25-2014, 09:37 AM | #51 |
40
Rep 213
01-28-2014, 02:31 PM | #52 | |
10
Rep 92
01-28-2014, 03:38 PM | #53 | |
Rep 1,300
Tires are Amazing!!!!!! Highly recommend. I did 255/40 all around. Love it. Would not do bigger nor smaller. they are perfect size. You really feel better planted to the ground. You regain some of that old BMW feel. I love it!
01-28-2014, 11:38 PM | #55 |
6'0 / 250lb
140
Rep 1,797
Audio...who painted your calipers?
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center |
01-29-2014, 06:51 AM | #56 |
40
Rep 213
01-29-2014, 07:47 AM | #57 |
6'0 / 250lb
140
Rep 1,797
I'm going to put my wheels on myself, but not sure if I feel like getting involved with painting the calipers................"........
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center Last edited by PhilT3; 01-30-2014 at 06:54 PM.. |
01-30-2014, 08:15 PM | #58 |
Rep 55
Just had H&R springs installed on my 535 and call me crazy, but it feels as the ride has gotten smoother. The ride has gotten less bumpy and more mellow in response to road imperfections.
The car exhibits less roll and increased sexy-ness. If you're considering a set of springs for lowering I would highly recommend H&R. |
01-30-2014, 11:17 PM | #59 | |
Rep 540
01-30-2014, 11:57 PM | #60 |
Rep 55
01-31-2014, 10:07 AM | #61 |
124
Rep 318
Which LA shop did you use?
Where did you buy the ACS springs and which shop did you have install them? Thanks.
02-03-2014, 10:44 PM | #62 | |
10
Rep 154
1996 E36 328i Touring
2000 E46 328Ci 2004 E46 M3 Dinan Exhaust 2011 535xDrive F10 AFE CATBACK, AFE SCORCHER, AFE Performance Air Filter, H&R, AR Down Pipe, ER Charge Pipe. |
