BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Chiptuning a 116i
      04-19-2012, 11:10 AM   #45
scorpionkit76
Turkey
Drives: c4 thp 156 hp
Originally Posted by iBeech View Post
Interesting- has anyone ever had BMW refuse to do work because they have detected a software mod on the ECU?
that's a good question....!!
      05-10-2012, 02:53 AM   #46
Mr.Sonderbar
Drives: X5 E70 30d, 116i F20
just compared some part numbers that are relevant for a tune and cant find any difference to a 118i (http://www.realoem.com/bmw/)
intake valve
116i: 11347585901 - 118i 11347585901
camshaft
116: 11377591483 - 118i: 11377591483
clutch
116i: 21207625147 118i: 21207625147
gearbox
116i: 23007633986 118i: 23007633986
intercooler
116i: 17517600530 118i: 17517600530
turbo
116i: 11627633925 118i: 11627633925
but there are different parts used for the (pre-)silencer
anyone tuned so far?
      05-17-2012, 04:11 AM   #47
Fanis
Fanis's Avatar
Greece
53
Drives: 116i (F20) Auto
I am going to install the Hartge Tuning Box in the next few days, to run some tests. Will keep you posted in a relevant thread.
2011- : BMW 116i (F20)
2009-11: BMW Z4 2.5si (E85)
2007-09: Mini Cooper S (R56)
2005-07: BMW 325ti (E46)
2004-05: BMW 318i (E36)
      05-17-2012, 09:24 AM   #48
Gras
Greece
Drives: F20 116i, Urban, Auto
Nice! Im intrerested as well. Let us know your impressions.
      05-22-2012, 12:35 PM   #49
Mr.Sonderbar
any news?
      05-23-2012, 02:09 AM   #50
Fanis
Fanis's Avatar
Greece
53
Due to heavy work schedule I did not have the time yet to install it. If everything goes as planned, I will install it this afternoon...otherwise on Friday. I will keep you posted!
      05-23-2012, 05:25 AM   #51
ms1971
Russian Federation
Drives: BMW F20 116i
We look forward, only please with photos
      05-23-2012, 05:28 AM   #52
01142007
10
Drives: BMW F20
Would be nice to know what the difference is and how much it cost you
      05-23-2012, 06:46 AM   #53
Fanis
Fanis's Avatar
Greece
53
I will try...at least to get some, since probably I will not be present in the process of installation.
I will not pay anything, I am just installing the box for a week or so to run some comparison tests and in general have an idea of the performance increase. It is the 1st box to be installed (as far as i know) apart from the Hartge demo cars and we want to test it. The Hartge dealer in Greece is a friend of mine, so I am letting my car to be a guinea pig!! I know the RRP in Germany (and most European countries) is 1.530 Euro + VAT.
      05-28-2012, 09:29 AM   #54
Fanis
Fanis's Avatar
Greece
53
I installed the box on Friday and over the weekend I had the chance to do around 200 miles. The increase in power is noticable, but only on full throttle and high speeds. From standstil to 120 km/h, the power increase is not very noticable. However, when I accelerated from 60 km/h to 200 km/h, the increased power is noticable after 120 km/h (approximately) when you feel the car pulling faster and more eagerly.
It reminded me a lot of how the 118i drives...the power difference is more noticable on higher speeds. I did not notice any increase on consumption. I did not run any comparison tests, since I could not get hold of a normal 116i with auto box. As a summary I would say (just a feel, I do not have any numbers to back it up) that it was like driving a 118i.
The installation is very easy. There is a harness from the control box (with one plug to the box) to 5 different sensors (turbo pressure, camshaft position etc.) plus a cable to power supply and a cable for grounding. All in all it takes about 45' for a proper intallation.
Tonight I will post a few pics.
      05-28-2012, 12:52 PM   #55
Fanis
Fanis's Avatar
Greece
53
Here are some pics, as promised.
Here you can see the wires for power and grounding:
Here you can see the box, placed (with adhesive tape) on top of the fuse box, so once installed and the cover is back, nothing is visible:
      05-29-2012, 05:11 AM   #56
nordschleife
BMW fanatic
15
Drives: F20
Hi Fanis, How many sensors to connect and what are they? I noticed different piggyback connect to different number of sensors, for Swiss, it is 2, TMC is 3 and Hartge is 5?
I wonder what would be the difference? they all have similar claimed max output
      05-29-2012, 05:35 AM   #57
darapis
Greece
Drives: 116i F20
Hi Fanis,
Γεια σου Φιλε.
Have you looked this : http://www.tmcmotorsport.com/CarProducts.aspx
It seems to be the same installation method and it is cheapest.
      05-29-2012, 05:51 AM   #58
bimmer852
Drives: F20 118i
if one worries abt losing warranty...do it after two years perhaps?
      05-29-2012, 07:13 AM   #59
Fanis
Fanis's Avatar
Greece
53
There are 5 sensors and (if I remember correctly) are:
1. Boost Pressure 1
2. Boost Pressure 2
3. MAF
4. Camshaft Sensor
5. Turbo Sensor
Originally Posted by darapis View Post
Hi Fanis,
Γεια σου Φιλε.
Γειά σου φίλε!
I am not sure if it is the same, as it seems to have only 2 connectors for the sensors. Also, if I ever consider doing a tuning, I would go only with a reputable and well-known BMW tuner, like AC Schnitzer, Hartge, Kelleners, Hamman. I would not trust anyone else.
      05-29-2012, 07:26 AM   #60
nordschleife
BMW fanatic
15
Drives: F20
Thanks Fanis, do you mind to send me photos or scan of the installation manual, I like to know more about the connections.
      05-29-2012, 07:54 AM   #61
Fanis
Fanis's Avatar
Greece
53
I do not mind, but I do NOT have the manual, as I have not bought the Tuning Box (just installed it for a week to test it). However, it does not say antyhting more, just photos of the connections and what each connection is (for example it says: ''Turbo Pressure 1'')
      05-30-2012, 03:40 PM   #62
max2005b
23
Drives: F20
I've searched the net for differences between 116i and 118i, engine wise, and haven't found any other than the exhaust silencer.
There is a chip tuning 118i to 204-210 HP.
Theoretically we can get the same result for 116i right?
Anyone tested it?
Thanks.
      06-01-2012, 10:10 AM   #63
Gras
Greece
Thanks for the feedback Fanis! This power/response increase you described, is it noticable on all driving modes eco pro, comfort, sport,+ ?
      06-02-2012, 02:32 AM   #64
Fanis
Fanis's Avatar
Greece
53
Yes, on all a driving modes. But it is more prominent on the Sport mode.
      06-02-2012, 05:16 PM   #65
vladberca
vladberca's Avatar
Romania
768
Drives: '18 octavia 2.0 tdi dsg
Reputable tuners offer warranty too, this is also the reason for a higher price
      06-03-2012, 12:26 AM   #66
max2005b
23
Drives: F20
Anybody knows the answer for why there are tuning differences in the 116i and 118i?
EVO-TECH has no answers for me yet, its been a week.
