2010 2011 BMW 5 Series Forum F10 Cheap Ebay Strut Tower Bar Review |
03-20-2020, 11:13 AM | #45 | |
Rep 5,409
More air without a corresponding increase in fuel delivery will cause a lean condition and possible engine damage; the computer can only adjust for so much increases air. I don't a dog in this fight and it really isn't any of my business how someone spends their money. I was just posting from 45+ years of automotive experimenting. Modern factory cold air intakes are superior to the under-hood hot air intakes that sat on top of the carburetor. This should be moved to a different thread as it has nothing to do with the shock tower brace. I'm interested in the actual fitment problems, like the mounting points. Just curious. Do you have a degree in fluid dynamics? I'm sure the fellows that design vehicle intakes (and exhausts) do. |
03-20-2020, 11:38 AM | #46 | |
Rep 1,299
Lastly, we don't know what went at BMW for all we know BMW could have asked the engineers for a restrictive design as 535i is not sports car. Edit: are you saying K&N and other manufacturers that design aftermarket intakes got some Joeshamo with 0 knowledge designing the intakes? Last edited by ziekxq; 03-20-2020 at 01:22 PM.. |
03-20-2020, 12:30 PM | #47 |
Rep 14,521
lol my bad i said i wanted to keep hearing about this my fault! we'll all just get back into the strut bar topic and hey, we are all friends here so
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
03-20-2020, 02:10 PM | #48 | ||
1312
Rep 2,595
Stop spouting nonsense about "but BMW could have if they wanted to!" You're missing the scale of things here. They sell tens of thousands of 5ers a year. When you're a major car manufacturer that is trying to maintain certain reliability standards and more importantly, emissions standards, a 50HP bump is not an insignificant number. Is a stage 1 significantly less reliable? Absolutely not, and most people won't run into reliability issues. But will it objectively reduce reliability in the grand scheme of things? Yep. And when scaled, even a 1% reliability decrease can cost you a lot of money. A ram style intake isn't about restriction, it's about reducing the length of tubing between the intake and the turbo inlet. Less volume, less inertia to overcome, better throttle response. And while we're talking about physics, let's do some math here. Using this calculator, we can see that at redline our engines consume about 741 CFM of air. Our intake tubing is 3.5" or so. Using this calculator, assuming we're traveling at 60mph (5280 feet per minute), our stock plumbing can take in close to 1411 CFM of air, almost double of what our car needs at redline. So obviously, plumbing is not the restriction here. Next, we need to look at the CFM of our filters. Good quality paper filters flow about 4.95 CFM per square inch. Given 741 CFM required, we need about 150 square inches of filtering capacity. Our stock filters are 112 square inches. Not great, but not bad either. More airflow is not just more airflow, your engine only needs a certain amount of it. Below 5000 RPM, our stock filter is actually fine. If you really want to get that last 2k RPM restriction out, using a drop in filter is actually just as good as the Air Charger. Which is probably why most people use the drop in filter. Lie about their power figures? Lolwhut? Lying requires the intent to deceive. BMW underrates their cars, that is not the same as lying about their power figures. Quote:
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
03-20-2020, 02:11 PM | #49 | |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
lsturbointeg9167.50 |
03-20-2020, 02:20 PM | #50 |
1312
Rep 2,595
Sorry, just can't stand misinformation (in addition to his misconstruing of what I said), and he's spouting a lot of it
2015 BMW 535xi
03-20-2020, 02:22 PM | #51 |
Rep 1,445
You guys are gonna make me unsubscribe from my own thread.
03-20-2020, 02:28 PM | #52 |
1312
Rep 2,595
Apologies, I'll drop the topic
Also, I double checked with my bar. It appears to be the same shape, so I don't think your fitment issues is related to the bar. I think it might actually be due to the black brackets. Did you try swapping the two brackets, left for right and right for left?
2015 BMW 535xi
03-20-2020, 02:32 PM | #53 | |
Rep 1,445
Yea, that is a good piece of advice... THAT I COULD HAVE USED A COUPLE DAYS AGO... No I didn't try that lol. You have yours off... do they look different? |
03-20-2020, 02:35 PM | #54 |
1312
Rep 2,595
I didn't take the brackets off. Given I've already stripped 1 of the bolt holes on each side due to BMW's crappy self tapping aluminum crap, not risking it. I checked the bar by just undoing the bolt holding the bar to the bracket.
2015 BMW 535xi
03-20-2020, 07:25 PM | #55 |
Rep 14,521
03-20-2020, 08:46 PM | #56 |
1312
Rep 2,595
IMO these bars definitely need to get painted. The brushed look sticks out like a sore thumb in our engine bays. I'm planning on painting mine a satin black once the HD opens up again.
2015 BMW 535xi
03-20-2020, 09:04 PM | #57 |
Rep 1,445
The brackets are 100% symmetrical and left to right, right to left would not have mattered. BTW, John polished his and it looked awesome, alone with the black supports AND oil filter housing...
03-20-2020, 09:14 PM | #58 |
Rep 1,445
03-20-2020, 09:45 PM | #59 |
Rep 14,521
I'm gonna leave mine polished for now and see if I can wrap it with 5d carbon fiber vinyl. If I don't like how it turns out gonna paint it satin black. Or I might paint it Bronze?
03-20-2020, 09:48 PM | #60 |
Rep 14,521
Yup! He made it look easy! I think you got screwed?
03-20-2020, 11:23 PM | #61 |
1312
Rep 2,595
I'd raise a bit of a stink with the ebay seller. Having to remove your heat dampening of the hood is kinda dangerous, those hoods can get stupid hot. if someone leans on it unknowingly, they might actually get a solid burn.
2015 BMW 535xi
03-21-2020, 10:02 AM | #62 |
Rep 1,445
If someone leans on my hood, they deserve to get burnt
I have dealt with bad product off ebay and I've already modified it, installed it, and while I might let him know it didn't fit at all, it's just not worth the rise in my blood pressure. If I had paid full retail I would have sent it back straight away but when I got out the dremmel tool there was no turning back... |
03-21-2020, 01:33 PM | #63 | |
1312
Rep 2,595
While saying someone deserves to get injured is a bit questionable when it comes to morals, there are good reasons for someone to touch your hood sometimes. For instance, I went for a 2 stage paint correction and the detailer went to take paint depth readings on the hood. If that hood is burning hot, I'd feel pretty horrible if he got a burn.
2015 BMW 535xi
03-27-2020, 03:44 PM | #64 |
Rep 1,445
So I had a major gaffe on this review... I was testing my new endlinks and I pulled into the gas station to adjust my CO and make them a bit stiffer when i realized I JUST freaking CAPPED MY COIL OVER ADJUSTMENT NOB WITH THIS STRUT TOWER BAR...
fail. lol. |
03-27-2020, 03:58 PM | #65 |
Rep 14,521
oh damn!!! so now you gotta remove it just to set the dampers? lol that sux but funny i still have yet installed mine. probably this weekend
04-12-2020, 10:29 AM | #66 |
Rep 14,521
so now that i got to do some spirit driving for the last few days here's my impression on the strut bar. if you've done some spirit driving with your car you know how your car responds and reacts to the different types of turns you make as well as how fast you are going. from my impressions i can totally tell a difference with this bar because like most of you...you know your car and when something's different or wrong with it you notice it right away. when coming into some normal S turns the car sticks pretty good. usually i feel a bit of body lean say if i'm going 40mph. with this the car feels pretty flat with no roll. i usually kinda lean into the turn with my body if that makes sense? now there was some pretty knarly bank turns that shows a speed limit of 40mph and i can take them at about 60mph. wheels didn't break contact and i can feel the car lean but it felt tight as it didn't feel like the car was loosing control. it just stuck the turn and it felt pretty good. not with round-abouts (for those that don't have them) it's just a round circle with no stops but exits so usually you're suppose to enter those like at 10-15 mph. usually my car has a lot of body roll into those as i have to slow down at times but with the strut bar in place i can totally feel that the body roll is gone and it just sticks now with applied gas. my last test was the 360 degree on ramps. i usually have a lot of body roll/lean and if i'm going fast enough the tires will break. i usually take these ramps pretty aggressive but now the car doesn't feel like it's leaning so much. again feels pretty planted and even when i really pushed it the tires never broke contact like it usually does. i could go on and on with different scenarios but i will say if you're thinking about getting these just for some handling improvements i totally recommend these!
