Best OBD tool + iOS
09-24-2021, 12:26 PM | #45 | |
Ameya
Rep 5
03-12-2022, 04:19 PM | #46 |
2010 e90 335i 6MT, RWD, Msport
24
Rep 114
I need to disable my Tire Pressire Gauge sensor and headlight washers. Can I do that with my Foxwell NT530 or do I need to get an app like BimmerCode.app (iOS) and use that with my MHD OBDII reader?
Thanks! |
03-13-2022, 02:52 PM | #47 |
Rep 13,134
As far as updates go you don't need them .
Why they stopped making E9x's in 2013 it's now 2022. Any updates probably would have stopped coming unless it was something for a specific recall. Every thing you need to work on the car is in the Ista D/plus. Eveything you need to program the car is in Standard Tools. |
06-25-2023, 06:01 AM | #48 |
Waiting for a tow truck
22
Rep 95
Old laptop running whatever Windows + SSD
K+DCAN Cable Bimmergeeks inpa If you want more get a SSD over 500GB and look for ISTA D / ISTA P+ All of the software you can get for free |
06-25-2023, 11:55 AM | #49 | |
Rep 4,108
BimmerGeeks INPA (BMW Standard Tools with E89 Datens) requires ~ 2.5 GB of HD space, and ISTA+ requires ~ 21.5 GB disk space. See attached pdf for Links to MEGA Downloads. Neither INPA or ISTA installation or use interferes with any other software I have installed (MS Office Pro, Acrobat Reader, Google Web connection via WiFi, etc.) and I save ScreenPrints to jpg files using 'MS Paint' image editor. Alt+Tab allows navigation between open applications. ONLY issue is ISTA must be "minimized" to perform some functions, such as opening other programs, at least using "Speed Keys". I'm NOT sure why there seems to be a "belief" that you should install INPA/ISTA on an OLD computer. I "Live" on my laptops, and have NEVER had a Software Issue or conflict. I've had INPA installed for 5+ years, and ISTA for ~ 4 years. ONLY issue I've had (using BimmerGeeks Pro K+DCAN Cable) is that "Windows Updates" frequently resets COM 1 Latency from 1 to 16, causing connection issues until reset correctly. ANYONE with differing experience, please advise. George |
06-28-2023, 04:05 AM | #50 | |
22
Rep 95
Personally, I run a new surface dedicated to BMW diagnostic you don't have to run an old one but not many people are gonna be spending surface money on a diagnostic laptop. Also, I'd like to add it was a pain trying to get INPA and ISTA to run on win 11 so most people who are not tech orientated would be better off to just get something with XP which would be an old laptop where the programs run straight up P.S SSD are dirt cheap now and if you aren't seeing an advantage of your SSD vs HDD I'd suggest looking into what brand you bought |
06-28-2023, 09:03 AM | #51 |
Rep 13,134
https://www.bimmerforums.com/forum/s...-P-actually-do
No trouble getting standard tools (and Ista sorta )running on win 7 to win 10 skipped Vista . ista problems https://www.e90post.com/forums/showthread.php?t=1661945 https://www.e90post.com/forums/showthread.php?t=1581663 |
07-25-2023, 05:59 AM | #54 |
Rep 13,134
Ista D is a shop manual with guided trouble shooting .
No looking up codes because the meanings and solutions are attached in a searchable database along with schematics wiring diagrams procedures and assembly disassembly instructions. Plus all torque specs etc. etc. |
11-16-2023, 01:21 AM | #55 |
Rep 2
The Foxwell NT510 Elite is a great pick. I personally use one, and it can read codes from all systems. What's cool is it can also handle crankshaft relearn and battery registration, which can save you a bunch of money. While ISTA/INPA can do similar things, they're a bit tricky to navigate. Check out this review for more details to help you make a decision.
https://www.obdadvisor.com/bmw-scan-tool/ |
11-16-2023, 01:41 AM | #56 |
DIYer
279
Rep 320
I have the Schwaben 14020SCH and while ECS sent me the old version rather than the new one I paid for. It has proven to be indispensable when it comes to maintenance.
The only code I have to deal with now however is 29F5. It told me when my water pump speed deviation was off. Can read some live data and reset ABS recently after tapping the motor housing in order to free up internal brushes. It just tells me what the issue is mostly. I want to setup the BMW Ista software with this extra laptop I have but it seems kind of scary. I don't want to lock out anything and don't like messing with things I don't understand haha. |
ios, obd2 |
