How to Open Trunk with No Battery.
10-01-2015, 08:23 PM | #45 |
15
Rep 137
Thanks to the OP for finding this solution. Here are some photos for the next poor SOB.
worked exactly as described. I first attempted to fish the Emergency release cable from the trunk grab handle but could not find the cable. |
10-02-2015, 05:40 PM | #47 |
Rep 1,051
I know what the procedure generally is, but even then I still find it impossible to figure out what each photo is illustrating! How about some captions, or a separate post with 'Photo1 shows....', 'Photo2 shows...', etc.
10-09-2015, 08:33 AM | #48 |
Rep 1
Great advice and posts for you savvy electricans. For those of us electrically illiterate however, you can try this. I don't have a external trunk key or ski pass through, and my battery was completely removed, so I couldn't jump it. I took the arm rest in the back seat out with the plastic tub behind it...cut a 2.5 inch hole in the plastic trunk liner and fished a galvanized conduit pole (I put a 90 deg hook bend on it) and pulled the emer release inside. The cable took very little tension to release but I couldn't hear it, so I probably pulled harder than I needed to and stretched the cable a bit. After getting it open I just taped the circle I cut out right back in place, so you can't see it and if I ever pull that bone head move again, I won't be stuck. Hope this helps
11-25-2015, 05:54 PM | #49 |
Rep 2
THANK YOU THANK YOU THANK YOU!!
It was a major PITA, but I was finally able to get my trunk open after finding this thread and following the original instructions. The follow up pictures helped a lot too so that I was sure I was looking at the right stuff. What in the actual #$% was BMW thinking? Battery in trunk but no exterior manual release to open the trunk? wow.. Anyway, thank you again. It saved me a lot of $$ and more hassles not having to have someone else figure this out for me. |
11-26-2015, 11:44 AM | #51 |
Rep 13,134
They stopped putting a keyhole on the trunk
They stopped putting a keyhole on the trunk at some model
year. Read everything in entry 4 of this thread. Last edited by ctuna; 11-26-2015 at 11:50 AM.. |
02-12-2016, 12:19 PM | #52 | |
Rep 4
On the left this is where you connect the ground to the brown wire. On the right is where you will find that grey wire with green stripe. Here are the wires you will need to look for the grey with green stripe. Strip a lil covering off that wire just touch the positive for a couple seconds and POP! |
02-12-2016, 12:33 PM | #53 |
Rep 596
You can also pop the release button out with a credit card. With that loose/hanging, you can look in the hole and see the truck release wire (although just barely). Snag with a coat hanger, pull firmly and it's open. No electrical skills needed.
03-25-2016, 11:40 PM | #55 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
Thx so much for this! I was about to pull my hair out after I disconnected the battery to replace injectors and then stupidly shut the trunk lid (realizing what I had done when the trunk lid was in motion). Mine is a 2008 E93...manual key FTW!
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
03-26-2016, 09:03 AM | #56 |
Rep 485
So.....this really isn't that big of a deal. All you need to do is pop the hood and put a battery charger on the jump post up near the engine cowl. It's on the passenger side and has a red cover. There's a ground post nearby on the fender rail.
03-26-2016, 10:55 AM | #57 | |
Apprentice
86
Rep 491
03-26-2016, 02:57 PM | #58 |
Rep 1,060
My 09 335xi has a key hole on the trunk but my 2010 335i dosent, if you csnt get it opened put a jump pack to the positive and negative under the hood and open the trunk by pressing the trunk button.
JB4 Tune, MHD backend flash, E85
VRSF 7" Intercooler, BMS OCC VRSF CP & TIAL 50mm BOV, BMP PI DocRace 6266 single turbo. |
03-27-2016, 11:00 AM | #59 |
Rep 485
05-11-2016, 11:35 AM | #60 |
Rep 1,342
Thanks for the write-up. We may be in the same situation. We got an M4 from a salvage auction yard. When we looked at the car, it had power.
When the car got forklifted onto a flat bed and brought home, nothing. No power at all and we can't seem to jump start it to get any power at all. I have a sneaking suspicion that before we got the car, the very expensive Lithium Ion battery 'walked away'. We'll try to use this method to get the trunk open and see what's up.
05-11-2016, 11:43 AM | #61 | |
Rep 1,342
So if just the negative terminal of the battery is disconnected, I believe the under hood jumping terminals should work.
05-11-2016, 03:02 PM | #62 | |
Rep 485
I saw you bought at M4 at auction. It probably had the BST pop which would disconnect the positive cable from the battery terminal that runs up to the engine bay. When you looked at it on the lot the battery probably had enough power to run the accessories but since ran down. There's a separate positive wire coming off the battery terminal to run the accessories in the even the BST pops. That accessory wire is indeed isolated from the under hood terminal so if the battery ran down all the way you may have to remove the rear seats to find a way into the trunk.
2006 E90 325i Sparkling Graphite Metallic
2009 E93 335i Montego Blau 2011 F10 535i Sophistograu Metallic |
05-12-2016, 10:59 AM | #63 | |
Rep 1,342
05-12-2016, 12:07 PM | #64 |
Rep 485
Did you find an M4 that wasn't totally trashed? Every time I see an M car on copart.com it's so thoroughly trashed but the ///M tax is still in effect. My theory is people trash these cars when they get away from them and they end up in a ditch or wrapped around a pole.
05-12-2016, 01:52 PM | #65 | |
Rep 1,342
SalvageBid.com - they act as the dealer for you, fees are reasonable and you can even join and buy 1 car without paying a membership fee. Another problem for the auction process if you are trying to make a street legal car is the whole air bag industry issue. I saw one M4 with no air bags deployed (how that car got a salvage title is another ethical matter) that was being bid up into the high 40's BEFORE auction fees (which would have taken it over $50k) and still did not meet seller's reserve. We got very lucky (I cashed in all my good Karma on that one). Pretty much damage just to the right front suspension and fender: https://picasaweb.google.com/1124397...eat=directlink It had actually been bought at auction before we were ready, but the buyer must have fallen through, insurance company got the deposit and re-listed it with a buy it now price that we evaluated it at when we looked at the car. We liked it and bought it at the $33K (plus auction fees) Buy It Now price.
05-12-2016, 02:22 PM | #66 | |
Rep 485
I think you did good on the M4. I've seen a lot of BMW's with that same damage profile and I would have bought that one in a heartbeat if it were in my budget.
