Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Where the hell is the TPMS module?
      03-01-2019, 08:18 PM   #45
nsjames
Drives: 08 328xi Touring
I just followed the DIY to delete the RDC and go to FTM today.
I found the module behind the insulation above the battery.
2008 E91
the DIY thread was very concise and step by step with ncsexpert for the coding.
      03-27-2019, 02:11 PM   #46
gary02453
Drives: 2010 328xi e90; 1997 318i e36
location of RDC tpms 328xi 2010
Replace mine. Some pictures to show the location of RDC tpms on e90 328xi 2010 (Reifendruckkontrolle)
Thanks everybody!
      06-02-2019, 09:38 AM   #47
loc116
Drives: BMW 328xi
TPMS antenna relocation
Thank you for the location information!
I was able to pick up a replacement from a local salvage yard for cheap. For my '11 E90, it was plug and play. However, It only lasted about a month before it failed (you get what you pay for). I'm wondering since it did work for some time, would have lasted longer if it was mounted away from the elements? Living in New England, In the winter, most of the water on the road is usually mixed with salt - Of course, this is not a good combination for exterior electronics.
I've since picked up another older style (3616793122) from a salvage yard - again for cheap and plug n' play. I tested it and it works... for now.
In an effort to prevent re-occurrence, has anyone tried relocating the TPMS antenna from outside the body to an interior location, such as inside the trunk area? We could guess that they may have located it outside for a better signal, but I do not have any data to support that theory.
Or...but does the updated part number (36106868194) new, from the dealer, built to withstand salt water?
      06-02-2019, 10:26 AM   #48
nsjames
spray the connector with corrosionx when you assemble.
then put the module in a ballon, with a zip tie over the harness to hold it.
that's what I used to do with receivers in sea planes before I just started treating them with corrosionx.
if you really want, split the module open ad treat the PCB with corrosionx.
      06-18-2019, 11:20 AM   #49
loc116
Drives: BMW 328xi
Relocated TPMS module
Thanks for the suggestions nsjames. I'll look into getting some corrosionx at some point, as that looks like a great product!
For now, these are the steps that I took.
  1. Purchased a used module from salvage yard.
  2. Used a razor blade to carefully cut along the factory seam to open the module. (found some corrosion inside even though it was working).
  3. Cleaned the existing corrosion using a soft nylon brush, WD40 and isopropyl alcohol.
  4. Coated both sides of the board with clear nail polish.
  5. Used a soldering iron, with flat tip attachment, to melt the module seam back together.
  6. Applied some some electrical grease to the connector. (already had)
  7. Relocated the module higher up in fuel filler neck area to keep it away from the road spray as best as possible. <see pic>
  8. Reset TPMS system via iDrive console.
Repair cost: $30. Time: 1 hour.
It's only been a couple weeks, but so far so good. I also tested the system by lowering air pressure in one of the tires. The low pressure warning activated as expected. I then was able to clear the error after setting pressure to recommended levels.
Oct 4 2019 update: It's been about 4 months and all is still good
Nov 1 2022 update. Still good!
      03-10-2021, 09:45 AM   #50
Dennis.L
Drives: 2015 328i
tpms
Originally Posted by skepticalMD(?) View Post
Originally Posted by Gate7 View Post
actually i haven't yet, what i thought it was it wasn't... have you found it?
Yup! It's a popsicle/USB drive looking thing that sits right behind the fender of the rear passenger wheel. Literally you just have to pop off the first two clips from the bottom of the fender as well as the clip on the undercarriage and you have access. It's the easiest thing
Hope this helps
Which year and model do you have? still can't find mine.
      05-08-2023, 12:09 PM   #51
NoTime4Gamez
Drives: 328xi 2008
Ok I've looked in all other threads and it said TPMS is located where the battery is. Then it said, they changed it on 2011 models to rear passenger wheel well. Well if you look at the photos it's in neither of those places.
Any ideas?
2011 e90 335i n55
Does anyone know what the white and grey things are on the third picture? Mine is missing and I dont know what is called so I can get it replaced.
      05-09-2023, 12:44 PM   #52
Serf27
Serf27's Avatar
2856
Drives: 335i
Gray is abs sensor and white is brake sensor.
