BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Bimmerlabs 330i Tune DIY Step by Step
      07-17-2020, 09:43 PM   #45
Leucosticte
Leucosticte's Avatar
224
Drives: 2007 BMW 328xi E92 6mt swap
2007 BMW 328xi  [0.00]
Originally Posted by E92William View Post
Well to begin with I wasn't aware that the euro 330i had the gm transmission aswell. I thought they had the zf box. Where could I get my hands on those tune files? It would be great if the 330i with the gm box happens to be an n53 because then the transmission tune will ideally be setup for the 272 or so hp the n53 makes.
Theoretically I think one could mount a 6hp to an N52 from a 28i car but I think that's way more trouble than it's worth, at that point just get a manual.
Yeah, manual swap is the best way to go if youre looking at swapping transmissions. Anyway, in order to get the 330i gm flash you must flash the ZB 7587776 via WinFKP comfort mode.
      07-18-2020, 01:44 PM   #46
HydroxFrost
@Lucky.330i
HydroxFrost's Avatar
39
Drives: 2006 BMW 330i
It would mount up in theory but it would be a programming nightmare I think. Manual swaps however, don't need to be coded and the swap is pretty easy if you're mechanically inclined.
      07-19-2020, 09:30 AM   #47
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
BMW built the early E89's with the N52,MSV80 ,ZF 6HP so they are probably software compatible. Have not really looked but it's probably a second generation 6HP so life gets really good. If you like Automatics.
There were also a number of LCI 3 series with this trans.
      07-20-2020, 11:40 PM   #48
Soravia
Drives: 2011 E91 Silver xDrive 6MT
What should I do for my LCI N52K now with DISA?
Should I pay extra for their "Tuner" to add better throttle response or 91 Octane tune?
ECS Tuning offer the service for $400+ but also charges $200+ for cable. That's just too much for $15 cable.
      07-21-2020, 08:55 AM   #49
hassmaschine
Drives: "NBO" 330i
I wouldn't pay for a Turner tune, personally.
      07-21-2020, 09:13 AM   #50
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
Originally Posted by Soravia View Post
W
I believe Bimmerlabs you can also get an "aftermarket" tune above the 330i oe tune; They apparently have one for MILVs too
No idea on the cost but ill be looking into it soon for my brothers 328 (and hopefully they can do the same for my 530 N52)
      07-21-2020, 09:22 AM   #51
nsjames
Drives: 08 328xi Touring
I feel like the xhp stage 3 would be a good pair for the 330 3 stage tune, but it is a little expensive.
xhp has unequivocally told me that there will be no gm6 tune.
ever.
I pestered them about it for a while.
I've not yet done the 330 trans tune.
who's got a link to a thread with the software numbers?
      07-21-2020, 01:25 PM   #52
bluewater328
Drives: 2011 bluewater 328i LCI sedan
ever.
*subscribed
      07-21-2020, 06:36 PM   #53
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Unless I missed something the file that @kakapo was talking about, "ZB 7587776" for the 330i GM 6AT flash isn't in the bimmerlabs website.
I wonder if it'd show up if I had a project as a euro 330i e92
Where could I get my hands on the 330i gm file you guys are talking about?
Or is it a stock file that is available through winkfp
      07-21-2020, 08:21 PM   #54
nsjames
it should be a stock file in winkfp
but I don't know the software numbers well enough to look for it.
      07-21-2020, 08:51 PM   #55
hassmaschine
Drives: "NBO" 330i
Actually, I can make it available to everyone if we know which cars it's applicable to.
      07-21-2020, 11:48 PM   #56
E92William
I'll have to do some research and fiddling around because I haven't used Winkfp much at all except to flash the tunes, so have to figure out how to find the file and flash it.
If you could make it available on the website it would be easier as the stuff to make your 328 into a 330 would be mostly centralized there from engine to transmission.
      07-22-2020, 12:07 AM   #57
hassmaschine
Drives: "NBO" 330i
All I need is the ZB# and which cars it could apply to (whichever have the GM 6AT). Even if it's just the people in this thread, that's probably 95% of cases.
      07-22-2020, 12:39 AM   #58
E92William
Well the ZB is 7587776 supposedly according to the previous posters.
I double checked on realoem it looks like no e60 got the gm transmission at least no usdm car 525/528/530.
For E9x 328i up until 07/2007 it shows all of them with the gm box but then it has the 6hp and gm as options too, though I've never owned a 28i car with a 6hp. Same story with the 128i.
Seems as soon as the USDM 330i ends production in 08/2006, the European 330i goes from using a 6hp to the gm 6at. At least as per realoem.
Can't find an N53 equipped car that uses the gm 6 speed. Maybe it's because the n53 being based on the n54 wouldn't mount up? If there was I think it would be the ideal file specially for a modded n52 that will reach stock n53 power levels.
Also I just found out all the F10s with the N52 engine came with the ZF8. Thats a great transmission.
      07-22-2020, 09:59 AM   #59
hassmaschine
Drives: "NBO" 330i
The ZB will probably be from an EU car. Also sometimes during transitions, BMW will use parts left in stock (parts bin cars, in a way).
edit: I do think 7587776 will work. it'z from an X3 3.0si, which also has the GA6L-45R.
      07-22-2020, 11:03 AM   #60
hassmaschine
Drives: "NBO" 330i
It's available now. Note that the only supported cables are an ICOM or Bimmergeeks. Anything else could potentially brick your TCU, and I can't help you if that happens.
I can't test it but let me know if there's any issue with the batch flash.
      07-22-2020, 11:04 AM   #61
Leucosticte
224
The ZB 7587776 works for both me and one of my friend's cars. We both are currently running the Euro 330i transmission flash. I don't remember how he found it, probably from an old forum post, but I have to say that it has made a remarkable difference, the car seems to feel much better when I drove hard. I attached an image from INPA to prove that this ZB really works. Please make sure that you have a good power supply as I failed to flash my transmission before while trying to do this which caused me lots of needless stress.
      07-22-2020, 11:10 AM   #62
E92William
I'll check it out, most likely I'll take the same course of action I did with the 330i tune and do it right after driving for a while so there's no chance of battery charge issues.
I'm using a bimmergeeks cable so I believe I should be in the clear. Are the steps for doing this the same as the other tunes? Open batch file and go?
Regarding the flash itself, I suppose it resets adaptations for the transmission, wouldn't it be beneficial to do it right after changing transmission fluid for best results?
      07-22-2020, 11:16 AM   #63
Leucosticte
224
yup, I flashed this about 1k miles after changing fluid.
      07-22-2020, 11:23 AM   #64
hassmaschine
Drives: "NBO" 330i
It's exactly the same. If your DME flash worked, it should be no problem. you do have to change your DME to the GM1912, or just add another project for it, and if you want you can always download the stock trans tune again. You don't have to flash the program because they should be the same.
      07-23-2020, 01:46 PM   #65
E92William
Just checked and found it. There's two GM 1912 options but seems they both have the same stuff. Hopefully the e83 x3 is the best one of all the 330i tunes we can get. I'll change the fluid this weekend or soon enough and flash it after driving it for a while, so I don't over-credit the tune for something a fluid change could have done.
      07-26-2020, 08:49 PM   #66
E92William
After trying to change the fluid and stripping the fill plug.. (reason 8272678162 why I dislike xdrive, can't fit a socket over the fill plug)
I'm just gonna try flashing it today. Transmission shifts good so I have no worries about the fluids condition. Just hope the flash file is compatible with the car itself
