BMW M3 Forum (E90 E92)
EXXEL Distributions
      04-22-2010, 03:45 PM   #45
MarkB84
Drives: E36 M3
Seems easy enough to do. Thanks for the write up. Going to upgrade to new springs soon. This will definitely help.
Paintless Dent Repair
Techs make $100k/year. Interested?
      04-22-2010, 07:43 PM   #46
JCtx
Drives: No BMW yet
Am not going to do that, but a relevant question for those with EDC: How do you remove all that EDC crap on top of the strut to get to the center nut?
By the way, if you only remove the top bolt, like to swing the strut out to change the fender liner (done to my car on passenger side), alignment doesn't seem to change since both front axles were identical. I checked it anyway, and had dealer adjust to minimum specs, but they left all adjustments all over the place within spec, saying specs are too tight, and couldn't do it. Seems to me the tech was a clown, since I've read people mentioning they had adjusted toe-in to zero, like I wanted. Oh well. Dealer charged me $149, by the way. But yeah, messing with the lower bolts warrants an alignment for sure IMO. I posted the specs somewhere, in case some of you want to go to an independent shop. Only adjustment not specified was caster; probably because it can't be adjusted.
      07-15-2010, 07:42 PM   #47
slimj281
Drives: E92 cp 6-MT
Just finish installing my springs. I have one concern though, when i removed the fronts i only loosened the one top nut on the shocks and when the strut came out so did the rubber bearing on top of the springs. Is this how its suppose to be done? or did i mess it up?
      10-08-2010, 10:55 PM   #48
SchwarzerM3
18
Drives: 2008 M3 E90
Just finished mine, it's realy a straight forward install...It took me and my buddy 3 hrs. with a few "beer breaks"
Gread write-up....thanks a bunch
      10-08-2010, 11:03 PM   #49
SchwarzerM3
18
Drives: 2008 M3 E90
Remove the dome shaped cover first (be careful, the cable underneath is not very long, so don't pull the cover away too much). The cover should come off without tools, just kinda squeeze it a little and gentle pull on it.
Once the cover is removed, you'll see a plug at the very end of the shock absorber rod. Take two flat head screw drivers and pry it straight up, be very careful, the pins inside this plug are tiny....
Thats it....
      10-08-2010, 11:05 PM   #50
SchwarzerM3
18
Drives: 2008 M3 E90
I don't think the whole bearing came out, I think it was just the part which is riding on the bearing (spring seat)...
Anyway, as long as you put back everything, you should be fine
      11-10-2010, 12:34 PM   #51
adc
Drives: 2018 F80 M3 ED
Just a word of caution - at least on the E46 cars if I remember correctly, the 3 nuts that hold the front spring hat onto the tower brace need to be replaced every time (and they are expensive). The reason given was that BMW uses a special stretchable nut (the torque being very low).
I'm not sure if this is fact of myth, but I think if I went to the trouble of replacing the springs, I'd spring for new nuts (pun intended).
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      01-22-2011, 03:05 PM   #52
donovan
donovan's Avatar
372
Drives: R8 - Ford Raptor
Going to give it a try tomorrow with my H&Rs
Wish meh luckkk
Audi R8 v10
Ford Raptor
m3e46freak@yahoo.comfor all euro parts!!
ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum
      01-22-2011, 10:45 PM   #53
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Should be reusable, because the torque is so low. But definitely do NOT over torque it. It is expensive because it is a special BMW-spec nut.
On BMW service manuals, BMW makes clear of the nuts/bolts that REALLY need to be replaced, i.e. the bolts on the propeller shaft. Those nuts are actually torqued beyond yield (torque value + torque angle).
      01-24-2011, 12:17 AM   #54
mot
Drives: e92 AW M3 6MT
update with e36 bumpstops?
btw are the 3 series bumpstops & e36 bumpstops the same?
      01-28-2011, 10:30 PM   #55
wrh3
Car Guy
wrh3's Avatar
34
Drives: BMW M2, Alfa Romeo Giulia/4C
Thanks for the DIY, this has to be the easiest spring swap ever (at least that I have done). Taking my time and taking some pics, start to finish with some breaks was ~2 hours.
H&R Sport Plus (Race) Springs feel great with EDC and I am using the OE bumpstops.......
      01-30-2011, 04:39 AM   #56
donovan
donovan's Avatar
372
Ok its now 1137 am in Germany, I will start the process at noon and let you know when I come back in. When I try things for the first time, just like my fabspeed headers on my e46 m3, I take my time and do it slowly. I hope this goes smoothly as advertised LOL
Audi R8 v10
Ford Raptor
      01-30-2011, 11:49 AM   #57
donovan
donovan's Avatar
372
I broke a module thats in the rear because the assembly went down to far and it snapped it off... ALSO almost did the same thing in the front , they are both on the left side. I think its part of the bullshit EDC system.
Audi R8 v10
Ford Raptor
      01-30-2011, 11:54 AM   #58
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Thats the headlight sensors...
      01-31-2011, 12:59 PM   #59
donovan
donovan's Avatar
372
Yup, broke it. Lol, superglued it, let it sit over night, wrapped a zip tie around that bitch, reinstalled it, did a 1 mile lap with bumps and light breaking to make the suspension do its job. NO fault codes!!
However, I used nothing in this thread to help me.... because I had a different set of spring clamps so I couldnt use your way to clamp it. Had to do it the generic way... If I had power tools I said 2 hours max...
edit: If I do get a fault code for the lights, then I know why..
Audi R8 v10
Ford Raptor
      06-12-2011, 10:36 AM   #60
TRY...M3
TRY...M3's Avatar
Drives: Depends on the day
Used the install last night step by step...super easy then i turned the car on and i got a ABS light, Traction control light and the BRAKE light???? NO idea why, someone please help
      06-24-2011, 02:52 AM   #61
Stormtroooper
The General
Stormtroooper's Avatar
34
Drives: 2018 M3CS
2011.5 M3  [10.00]
I like the updates, so now it can be done without removing the shock. Good stuff! Def. easier to do it this way, and it saves time.
E92 M3
2011.5 AW / DCT / ZCV / ZP2 / Heated Seats (SOLD)
2018 M3CS
      07-04-2011, 07:12 PM   #62
shake&bake
OZ
Drives: 10' E92 M3
Spring Install - after the fact questions
Replaced the front OEM springs with Eibach Performance springs on Friday. Started with the front with the plans of replacing the rear springs later this week. I used the very helpful DIY instructions available on the forum and everything seemed to go OK. Here are my questions:
1.When swapping out the springs, did anyone replace the swaybar or strut lock nuts with new hardware? I just reused them, but am questioning if I needed new.
2.If I like the ride and look of the car with the Eibach springs in the front and the OEM springs in the back, is there a compelling reason to change out the rear shocks with the Eibach? I have 20" CH-R in 255/30/20, and 285/30/20 in the rear. 3mm chamber plat coming for the front. The car currently has an even stance and I'm worried if I drop the rear it will be too much for the 30 profile tires.
3.Dove the car home on Friday after the front install with no errors. Washed the car over the weekend and when I started it today there was a EDC error. I checked all the connectors and the wiring harness and everything seems ok. Any ideas?
Thanks for the help.
'10 M3 E92 | Alpine White| DCT| BBS CH-R 20" & Eibach Springs| Dinan Stage 1|M.S. Key Hole Delete|Angel iBright V3.0| LED upgrades
Others:10' Landcruiser|09' Ducati 848|10' Tundra 5.7| 97' 993 Cab
      07-13-2011, 10:55 PM   #63
JRam
Drives: 2010 E92 M3 DCT AW/FR
anyone have the part number for the nuts that need to be replaced? tackling mine this weekend....
      07-13-2011, 10:58 PM   #64
saeedg48
Drives: Porsche 991.1 GT3
so much could go wrong :/
2015 Porsche 991.1 GT3
2015 F80 M3 -- Individual; Space Grey
      09-02-2011, 10:30 PM   #65
youngvedder
Drives: 2008 e93 M3
did mine tonight, went well....front is much easier than the rear...especially getting the bolts back in..what a b&^ch...
thanks for the outline!
Yv
      03-01-2012, 08:11 AM   #66
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
How different is KW adjustable sleeve kit compared to regular springs? Anyone have any tips on installing those?
Thanks
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
m3post
