Help yourself Software part II
09-01-2021, 04:48 PM | #45 |
Rep 411
Road Map Europe West & East NEXT 2022-1
• F01, F02, F03 from 07/2012- • F06 from 03/2013- • F07 from 07/2012- • F10,F11 from 09/2012- • F12,F13 from 03/2013- • F15 from 08/2013- • F18 from 09/2012- • F20, F21, F34 from 03/2013- • F22,F33 from 11/2013- • F25 from 04/2013- • F26 from 04/2014- • F30, F31 from 11/2012- • F32 from 07/2013- • F35 from 01/2013- • F36, F80 , F82 from 03/2014- • I01 from 09/2013- • I12 from 12/2013- MINI F55 from 07/2014 F56 from 12/2013
Help yourself Software part II, read post 1 : https://www.e90post.com/forums/showt...7#post27890067
allex2913.00 |
09-07-2021, 10:42 PM | #46 |
1312
Rep 2,595
Anyone know if the latest versions of ISTA allow you to program modules via ENET, or is it still an ICOM only thing?
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
09-10-2021, 03:25 PM | #47 |
Rep 411
ISTA 4.31.20 - (PSdZData_Lite_v4.31.21 included)
09-11-2021, 02:09 AM | #48 |
Rep 411
v.4.31.21_PSdZData - Full Version
09-11-2021, 07:41 AM | #49 |
Rep 2,047
You can change Ista config file (ISTAGUI.exe.config) to allow ENET programming. Not sure if its recommended to program using ENET instead of ICOM, havent tested it.
09-11-2021, 11:40 AM | #50 |
1312
Rep 2,595
You happen to know the config line changes?
2015 BMW 535xi
09-11-2021, 02:10 PM | #51 |
13
Rep 51
<!-- enable Programming via ENET -->
<add key="BMW.Rheingold.ISTAGUI.enableENETprogramming" value="false" /> Change false to true: <!-- enable Programming via ENET --> <add key="BMW.Rheingold.ISTAGUI.enableENETprogramming" value="true" /> |
Unspec1311.50 |
09-15-2021, 06:58 PM | #52 |
Rep 16
Hello
For bmw_standard_tools_installer_v2.12.2, how can I make it's INPA work? it seems to me that as is, it's trying to connect to a ethernet device. but i am using KDCAN cable. I was using bimmergeeks but it was having problems with outdated files. using EDIABAS from bimmergeeks version still didn't want to work with your 2.12.2 is there a tut on using 2.12.2 with kdcan usb cable? |
09-15-2021, 08:39 PM | #53 | |
13
Rep 51
you need to edit the file obd.ini from "C:\EDIABAS\BIN\obd.ini" to be set to usb, something like this: Port=Com1 Hardware=USB RETRY=ON |
09-16-2021, 12:45 AM | #54 | |
Rep 16
Mine was set to COM3.. Code:
[OBD] Port=Com3 Hardware=USB RETRY=ON Code:
;################# ;# EDIABAS 7.3.0 # ;################# ;============================================================================= [Configuration] ;============================================================================= Interface =ENET ;Interface =REMOTE ;Interface =REMOTE:OBD_ab625 ;Interface =REMOTE:MOST_CTRL_ab625 ;Interface =REMOTE:MOST_ASYNC_ab625 ;Interface =REMOTE:MOST_MASTER_ab625 ... Interface STD:OBD Last edited by kittkitt; 09-17-2021 at 01:57 AM.. |
09-16-2021, 07:13 AM | #55 |
Rep 411
MEGA is on my case again.
Seems like they're cracking down on hosts
09-16-2021, 12:38 PM | #57 |
Rep 16
09-16-2021, 03:32 PM | #58 |
77
Rep 169
VPN FTW
3PedalJake2613.50 |
09-16-2021, 03:43 PM | #59 |
Rep 16
I figured out how to make it work with the USB DCAN cable.
Now i have another problem, how can I update the SGBD? SP-DATENs? Code:
--------------------------- Versionskontrolle --------------------------- Nicht zusammenpassende Versionen. Fehlfunktion ist möglich! SGBD Version: 17.000 (in INPA) SGBD Version: 21.000 INPA Version: 6.130 --------------------------- OK --------------------------- |
09-16-2021, 08:25 PM | #61 | |
13
Rep 51
09-17-2021, 05:52 AM | #63 | |
Rep 411
They received a complaint of certain software getting shared. But without the decrypt key, they dont know whats getting shared. I am uploading a backup to a completely different host just incase
09-17-2021, 06:02 AM | #64 | |
I only ride park
492
Rep 385
Marvelous. |
09-17-2021, 10:50 PM | #65 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
09-23-2021, 11:22 AM | #66 |
Rep 411
Working away for the week and find out my files have been deleted.
