08-13-2023, 09:40 PM | #46 |
Rep 4,380
yes, but i believe some sportline/non m-sport packages had the 704 m-sport suspension fitted.
i just checked my own car and the 704 rear sways are very thin. i'd definitely consider a proven aftermarket a bit thicker. . Last edited by alohasurftoad; 08-13-2023 at 09:55 PM.. |
08-15-2023, 12:24 PM | #47 |
Rep 77
OK. So it seems the rear subframe bushings are very lose, which I think was a problem all along. I am replacing those with street poly.
I was able to get the part numbers from the mechanic who put the new front struts, springs, and rear springs. Here are the part numbers: Front Struts: 31316874371 Front Spring: 31336851920 Rear Springs: 33636851929 For the rear, it is current at b4. Part numbers: Bilstein labeled: SKU: BIL-19220093 Equivalent OE Part Numbers: 33526868653, 33526874377, 33526874372, 33526791588, 33526868654, 33526791569 I talked to the motorsports shop. They believe they are compatible enough where I will not have any issues. However, impossible to tell without replacing the bushings first. I will update once I receive the car after repair. |
alohasurftoad3132.00 |
bilstein, f30, struts, suspension |
