05-03-2024, 03:30 PM | #45 |
Rep 632
My car only had one mic - on the drivers side (RHD car).
Sounds like you’ll need to access newTIS and work out where you’ve gone wrong with the wiring. The functionality of the existing mic should be unaffected, as there are no changes required / made there. Simply the addition of the new mic for B&O. |
05-04-2024, 02:56 PM | #46 |
Rep 2
Thanks @blau3er .
Will try by putting the old mic back on and then double check the new mic and wire. I guess I have to make another hole in the roof, or swipe it with the other old mic on the other side. @truymenh Where did you buy those illuminated grills from? They look spot on. |
05-11-2024, 07:58 PM | #47 |
Rep 533
The Match range doesn’t have the 14 channels needed to do this build. Match also doesn’t by default have digital audio that B&O has or the active noise compensation and if added mixes the BMW audio channels down the stereo. PDC drops to left / right only. The B&O speakers including woofers that are better than most of the drop aftermarket options.
I believe B&O also has Dirac derived DSP maps. Love how this install looks and is completely factory using factory components , yet an option that the audio option 3 series never got. |
