11-08-2009, 06:13 PM | #45 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
They are not difficult to make. I'm just surprised they are not readily available for our cars. Can you teach me the secret handshake to get a set? Do I have to run Hawk pads to enter this secret society of the bronze bushings?
11-08-2009, 06:18 PM | #46 |
Rep 8,033
Joe, can you clarify what you mean above? How does uneven pad/rotor contact result in piston failure? Are you saying that also results in uneven pad/piston contact and that somehow loads the piston in a manner that results in failure?
11-08-2009, 06:22 PM | #47 |
Rep 7,887
They came in a brown paper bag!My buddy that supplied them to be no longer works there as he is recovering from a road accident.I will follow up with him to see what I can dig up.
11-08-2009, 06:26 PM | #48 | |
Rep 7,887
http://www.prosystembrakes.com/catalogpg016.htm They usually run 3 ducts per wheel with inline blowers to ensure plenty of air flow to cool the brakes.All this in a 15" wheel! |
11-08-2009, 06:31 PM | #49 |
Rep 8,033
Sound heavy duty indeed. Do you have pics of the cooling setup?
11-08-2009, 06:45 PM | #50 |
Rep 7,887
Good article here.
http://www.stockcarracing.com/techar...rol/index.html Interesting stuff here. http://www.renagadecomposites.com/NASCAR.html |
11-08-2009, 06:54 PM | #51 | |
Rep 8,033
"Your brake temperatures really need to stay below 400 degrees Fahrenheit," says Derek Spencer of Performance Friction, who works with race teams on their brake packages. "And 400 is kind of pushing it. If you get above that, the seals in the calipers start to crack and deteriorate. If you can keep your maximum temps below 350, you are doing good. Anytime you find you have exceeded 410 degrees, it's a good idea to go ahead and rebuild your calipers." Not sure what part of the brake system he is referring to, but I don't see how one can keep rotor temperatures that low on the E92 M3.
11-08-2009, 06:59 PM | #52 | |
Rep 7,887
11-08-2009, 07:05 PM | #53 | |
Veni Vidi Vici
89
Rep 2,750
11-08-2009, 07:12 PM | #54 | |
Rep 8,033
11-08-2009, 07:15 PM | #55 |
Rep 8,033
Most likely. I've never measured caliper temperature on this car. I will next time I drive it on the track. My only basis from personal experience is that the caliper paint has cracked and fallen off--very much like the cracking of paint in the pics the OP posted--but I don't know at what temperature that is likely to happen.
11-08-2009, 07:19 PM | #56 |
Rep 5,012
I'd rename the thread as 'Biblical brake abuse' .
But yes, even though our 1-piston calipers are not the same as on Hondas and such, there's no excuse to at least have 4-piston calipers in the front and 2-piston on the rear on a high-performance V8 car IMO (like all the M3's competitors). At least as an option. Take care. Last edited by JCtx; 11-08-2009 at 07:36 PM.. |
11-08-2009, 07:30 PM | #57 | |
Veni Vidi Vici
89
Rep 2,750
11-08-2009, 07:34 PM | #58 | |
Rep 7,887
http://www.performancefriction.com/pages/access.htm |
11-08-2009, 08:03 PM | #59 |
Rep 8,033
I see. I missed that. Please articulate how piston failure would result in such excessive heat generation--to the extent that the brake line failed and fell off. If you have a stuck piston, sure there is more heat generated at the piston/caliper interface when you apply the brakes, but how much heat can that generate relative to the heat transfer into the caliper from the normal operation of the system due to friction at the pad/rotor interface?
11-08-2009, 08:21 PM | #60 | |
Rep 7,887
11-08-2009, 10:11 PM | #61 | |
Veni Vidi Vici
89
Rep 2,750
11-08-2009, 10:16 PM | #62 |
Rep 8,033
Well, that would result in strange/uneven handling if it is to generate significant heat. Hard to believe that a pro driver would not notice one of the brakes dragging like that...Anyway, the good thing he didn't end up in a wall or something.
11-08-2009, 10:29 PM | #63 |
Rep 221
I think the stock brakes are perfectly fine handling street duties, but if you plan to track it on weekends, it's "Logic 101" that you HAVE to do the BBK upgrade.
Everything is work in progress.
11-08-2009, 11:40 PM | #64 |
Rep 10,407
Wow very warm rotors. This image looks to be around 700°C or 1300°F. Warm to say the least.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 11-09-2009 at 12:11 AM.. |
11-09-2009, 12:02 AM | #65 | |
Rep 1,084
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
Brake Abuse!!!
You didn't upgrade your brakelines! Fowl on you! Definately brake abuse!!! |
11-09-2009, 12:11 AM | #66 |
Rep 10,407
I also firmly agree that piston count is no where close to equivalent to lower operating temps. Heat generation is based on primarily how much speed is scrubbed off, how often that happens and how much your car weighs. The problems with the M3 system are:
1. Car weighs too much compared to rotor mass. 2. Not enough cooling flow to rotors (of course this was probably mitigated in this case). 3. Insufficient rotor vane cooling of the rotor. Last but not least I firmly agree with those who have pointed out that in this case the car was firmly out drivered. I'd bet the OP could easily toast most Audi and Merc brake systems as well.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
