BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Engine | Drivetrain | Exhaust
      05-17-2015, 10:58 PM   #45
jason561
jason561's Avatar
27
Drives: '08 E90 M3 6MT
A quick question on one of your earlier posts, When and how do you determine that it is necessary to flush the oil system to remove any old bearing material? Also is this a lengthy process?
      05-18-2015, 12:03 PM   #46
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
It depends on what we're presented with, sometimes only a minor flush is needed. More serious cases will need extra attention to make sure all airborne particles are removed as best as possible.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      07-06-2015, 01:09 PM   #47
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
2 more bearing services performed and we're only in the beginning of July, one of them was lucky to get here in time.
Give us a call or email and we'll be happy to discuss any portions of the service with you or get you scheduled in.
      07-15-2015, 04:59 PM   #48
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
PM to schedule you rod bearing replacement, slots open up
For anyone not local we do have rod bearing kits
http://www.m3post.com/forums/showthread.php?t=1148294
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
      08-04-2015, 06:45 PM   #49
kevin @ eas
Drives: 2015 BMW M4
Appointment slots open up for rod bearing replacement
PM today for details
      08-05-2015, 03:01 PM   #50
4corners
4corners's Avatar
Drives: 2008 Jet Black M3 Coupe
Blackstone Report at 135000 miles. Not quite ready to do bearing yet. I hope.....
      08-06-2015, 03:59 PM   #51
kevin @ eas
Drives: 2015 BMW M4
From what Blackstone is saying looks like your bearings are in good condition, pretty impressive for the mileage.
      08-06-2015, 04:23 PM   #52
Z K
Z K's Avatar
1893
Drives: E90 M3, G20 M340i
Wow! 135k miles. Impressive! Have you tracked your car?
Auto Detailing Enthusiast!
      08-06-2015, 06:24 PM   #53
4corners
4corners's Avatar
As we know oil reports can be completely wrong but it's good to see none the less.
No tracking but I drive it as it should be driven.
      08-10-2015, 01:16 PM   #54
steven747
Drives: e46 330ci
fyi im picking up my car from eas either today or tomorrow because of total bearing failure. i had my engine blackstoned 4 months ago with perfect results.
      08-10-2015, 01:32 PM   #55
4corners
4corners's Avatar
I am certainly aware of this possibility.
      08-17-2015, 04:11 PM   #56
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 source for WPC treated bearings and replacement
      08-27-2015, 01:42 PM   #57
kevin @ eas
Drives: 2015 BMW M4
Appointment's available for rod bearing replacement
PM today for details and pricing
      09-25-2015, 11:48 AM   #58
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Appointment slots available, schedule your service today.
      09-25-2015, 02:19 PM   #59
CHE///MIST3
CHE///MIST3's Avatar
Drives: E92 M3 6MT Space/Black
2009 BMW M3  [0.00]
2007 BMW 328i  [0.00]
Hello,
Hopefully I didn't miss the answer to my question in a previous post, but the bearings that you provide in the service...are they OEM-sized? I have read in other threads that many of the "better" replacement bearings available have increase coating thickness and thereby reduce the needed clearance.
Thanks!
GM
      09-25-2015, 06:34 PM   #60
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Originally Posted by GMCHEM83 View Post
Hello,
Thanks!
GM
That is true on coated-type bearings. WPC are not coated, they are a "treatment" performed to the bearings
WPC Treated Connecting Rod Bearings
WPC is a proven process that has been utilized for many years in the racing and automotive industry. WPC is not a coating, it is a treatment that enhances the surface to reduce friction and strengthen engine parts. WPC achieves this process by firing ultra fine particles towards the surface of a product at very high speeds. The resulting thermal discharge permanently changes the surface, strengthening structure and creating a harder more durable final product.
The WPC process is unrivalled in treating engine parts and other surfaces that have contact points of friction. WPC is superior because it is not a coating; it is a permanent surface treatment that reduces friction while strengthening the part. It's unique micro-dimple formation pattern greatly reduces friction and is unmatched by conventional methods of surface treatment.
The fine grooves, that are intrinsically engraved into the product surface at the time of machining, are transformed into micro-dimple indentations by the impact of the ultra-fine media during WPC treatment. These dimples then act as oil reservoirs. Thus, oil that would normally drain away, through the grooves in an untreated product, when pressure is applied, is instead retained in the dimples of a WPC treated product. This helps to keep the surface lubricated.
Hope this helps!
      09-27-2015, 03:33 PM   #61
CHE///MIST3
2009 BMW M3  [0.00]
It does help, thank you! So, a superior, treated surface to help reduce friction AND keep oil in place.
My 2008 M3 coupe (i'm the 2nd owner) has 34,000 miles on it and has had all the oil changes performed on time. I'll get a Blackstone report done soon to see if I can I learn anything of the status of the bearings.
Thanks again for the help.
GM
      09-28-2015, 11:22 AM   #62
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
GM
No problem at all! Feel free to forward your report if you would like any assistance.
      10-07-2015, 04:40 PM   #63
Blindside_137
Blindside_137's Avatar
Drives: 2011.75 SSII E90 M3 ZCP
How have these WPC coated bearings been holding up? After the past couple years has anyone done an inspection to see how these have held up?
      10-19-2015, 02:38 PM   #64
kevin @ eas
Drives: 2015 BMW M4
Haven't had anyone pull them out after we have done the service since the WPC treatment is relatively new. If we do get a chance to pull out the bearing that have been done we will be sure to post results though.
      10-19-2015, 05:15 PM   #65
rcracin
Drives: M3
Originally Posted by tom @ eas View Post
Info
Vehicle: 2008 BMW M3, 6MT
Production Date: 12/07
Oil Used: TWS Motorsport 10W-60, 7500mi intervals
Mileage: 62,833 mi
Fuel: 91 Oct
Driving Habits: Street driving, no track use
Oil Analysis: None provided
Notes:
M3 was just purchased on used market, came in with audible ticking. After getting oil analysis performed, it was quickly scheduled in for bearing service. Engine failure imminent if not attended to immediately.
Bearings were replaced with WPC Treated Bearing Set & ARP Rod Bolts. Engine and oil cooler/lines flushed to clean out any remaining debris.
Images:
As seen, bearing #2 suffered the most damage, with all remaining bearings showing considerable wear. Bearing particles were visible in oil filter element, required flushing to make sure all particles were removed from engine, lines and cooler.
Blackstone Oil Report:
Driver is very lucky to still be driving his M3. Schedule your appointment today!
How did you flush the lines and oil cooler to remove metal particles? Any update on how this car is running? Was the crank scored up? That bearing looked pretty shot.
      01-06-2016, 06:50 PM   #66
kevin @ eas
Drives: 2015 BMW M4
BE bearings now included as an option in our rod bearing service
bearing, eas, journal, rod bearings
m3post
