KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
09-14-2018, 04:05 PM | #639 |
Rep 5,482
Here's this same setup on my car, with 5mm spacers rear, dinan front plates (-2.2 and -1.8 camber, approx) and ZCP springs. Also no rub, obviously
09-14-2018, 04:14 PM | #640 |
Rep 450
Looks good Richbot I'm looking for some rears as well hard to find though what does the front profile look like? Thanks!!!
09-14-2018, 07:41 PM | #641 |
Rep 5,482
It really doesn’t look that different from the stock 220M setup with a front 15mm spacer. The concavity of the 8.5 and 9.5 is almost the same, the 8.5 just has a much thinner bolt center pad. And this setup has a lot more front wheel and tire width obviously
07-01-2019, 01:11 AM | #642 |
Driver
2692
Rep 2,714
Has anyone run 18x9.5 et23 with 275/35r18 NT01 and a 5mm spacer up front, and cleared the KW clubsport spring/perch?
E90M 6MT Slicktop Single Humper in need of a diet
08-09-2019, 11:10 PM | #643 |
103
Rep 188
Drives: E90 M3, U11 X1
A clean set of 666m's just popped up locally for a very attractive price. OEM 20x9 et29 and 20x10 et40 sizing. Fronts have 265/30 4S's and rear 285/30 Super Sports.
I'd love to see them on my E90 M3, but From what I've read the front is a no-go. Still holds true? I'm really bad with offsets and such. |
09-08-2019, 11:23 PM | #644 |
Rep 1,455
Drives: E92 M3 | E90 330i
E92 M3
Tires: Toyo R888 Wheels: Forgestar F14 Suspension: Stock Camber: Stock 9.5x19F (et21) - 265/30 11x19R (et25) - 295/30 Rub or No Rub?
RAE30 BUILD THREAD: http://www.e90post.com/forums/showthread.php?t=895608 Instagram: @m3whip |
bhup0926.00 |
09-09-2019, 08:07 AM | #645 |
Rep 1,591
We would need to know the offsets of the wheels
2012 E92 M3
Instagram Turbo__Joe |
m3whip353.00 |
09-09-2019, 02:55 PM | #646 | |
Rep 1,455
11x19 et25 Currently wrapped in pss 265/30 and 295/30 lowered on kw has. Is it true that toyo r888/r88r are +1 wider than pss?
09-10-2019, 06:47 AM | #647 | |
Rep 1,591
The front will fit just fine, the rear will be tight. Might need to trim the bumper tab or dial in a little extra camber but it will work.
2012 E92 M3
09-18-2019, 11:38 AM | #648 |
9
Rep 39
Sup guys I’m in the market for rims and tires came across these but not sure if they will work because of the offset. I have an 09 E93 standard offset is 23 and 29 will Avant Garde 19” wheels. bolt pattern 5x120 19x9.5 rear and 19x 8.5 front offset 35 & 45.
Would they fit? Thanks |
10-03-2019, 03:25 PM | #649 |
71
Rep 103
E92 Competition
Tires: Bridgestone RE71R Wheels: OEM ZCP 359M Suspension: Stock Camber: Street/Track setup Front 265/35/19 - 15mm spacer Rear 285/35/19 - 12mm spacer Rub or No Rub?
2013 E92 ZCP /// Alpine stage 2 tune, Bomiz Race X-Pipe, ARC-8 wheels, Vorshlag camber plates, Wheel studs, TMS spacers F15mm/R12.5mm, Stoptech SS lines, BW brass caliper guide |
10-04-2019, 08:10 AM | #650 |
Rep 1,591
Those are pretty tall tires up front but should still clear on stock suspension
2012 E92 M3
ppatel1471.00 |
10-11-2019, 08:39 AM | #651 |
25
Rep 134
E90 non ZCP
Tires: Contintental DW Wheels: OEM 220m Suspension: Swift Springs, alignment pins removed Camber: -1.6 fronts, -1.8 rears Front 255/35 - 12.5mm spacers Rear 275/35 - 10mm spacers Front right rubs lightly on full left lock. Rear passenger did rub a bit on big dips, looks like it's rubbing on the plastic tab in the fender well Another question: would 19x9.5+30 (255/35) fronts and 19x10.5+30 (275/35) be ok? Based on my current set up, using wheel offset comparison tool found on 1010tires, I'd want 25mm offset for fronts to match my current set up. For the rears, a 30 offset would be a few mm higher (or tucked in) vs my current rear set up. So theoretically the rears should be fine without rubbing. For the fronts, I can put on a 5mm spacers to match if it rubbed on the spring I suppose, but looking for any feedback from here. |
11-26-2019, 08:43 AM | #652 |
46
Rep 221
I've waded through literally all 30 pages here and am coming to conclusion that it should be safe running 285/35-19 tires on 19x10.5/+25 rims in the rear (on an E92 w/competition pkg).
But that conclusion is based on summer tires. However, I'm putting on Michelin Alpin PA4 winter tires. Does that change anything with fitment?
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) |
12-13-2019, 09:09 AM | #653 |
Rep 19
M3 e93
2012 Bmw m3 e93 with coil overs, looking to fit arc-8 18s in a 9.5 and 10.5. I am thinking about going with a 265/40r18 and a 285/40r18. I was also thinking about going with a 265/35r18 and 295/35r18. I have a harrop sc so wanting to get the most grip I can. Any difference in fits with the e93 anyone knows about?
12-13-2019, 09:32 AM | #654 | |
Rep 1,025
For what it's worth I'm running 18x10.5 with 265/35/18s and 18x11 with 295/30/18 Michelin Cup2 tires. The car also has a Harrop SC. Plenty of grip in 2nd gear and up. I honestly have not completely floored it in 1st but I know for a fact it's going to spin. I'm pretty low too on Bilstein B16 (Damptronic) and I have zero rubbing so far with all the driving I've done. |
12-15-2019, 01:10 PM | #655 |
Rep 19
Thoughts on r888r
After doing some research I want to go with r888r for my Apex arc-8 9.5 fronts and 10.5 rears. I want 265/35/18 for the fronts but the question is I want 305/35/18 for the rears but is there anyway i can make them fit? I know most go with the 295/30/18s but I really want the 305/35 so anyone with experience lmk
12-16-2019, 09:06 AM | #656 | |
Rep 1,025
12-16-2019, 12:32 PM | #657 | |
Rep 19
01-25-2020, 11:15 AM | #658 |
Rep 1
Awesome info here! Thanks guys.
Working on a set of Apex EC7's at 19x10 et25 / 19x10.5 et22, with 10mm spacers all around for myself. Debating between 255/35/19 front and 265/35/19 for the rear, or 265/30/19 front 275/30/19 rear, but i'm leaning towards the 35's for the more full wheel arch/meaty look. I ran some close test fitting with a set of 19x10 et24 style 95's that had 255/35/19 on them and definitely like slightly more meaty look of the 35 series tires, but my desired ride height/fitment tucks about 1/2" of that tire into the arches and pokes the wheel out of the arches the thickness of the spacers. Will post and update once they're fitted. Last edited by Robb.Deep; 01-25-2020 at 11:21 AM.. |
01-27-2020, 10:11 AM | #660 |
Rep 16
Car: 2011 E93
Trying to order This wheel package includes: (2) E9X M3 GTS front wheels, 19 x 9 inch, ET31 (25.4 lbs) (recommended tire size: 245/35-19) (2) E9X M3 GTS rear Wheels, 19 x 10 inch, ET25 (26.6 lbs) (recommended tire size: 265/35-19) Was wondering if anyone has this setup and if it rubs or not? |
