N54 Drag Times Compilation
10-05-2020, 09:21 PM | #771 |
Rep 940
487 crank hp ??
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
11-15-2020, 09:53 PM | #773 |
Rep 2
1) Model and Transmission 135i
2) Elevation, Temp and Humidity. 70ish 3) All performance modifications done to the car single turbo 4) Level of gas ran and how much gas in the tank? (ex: 93 octane and 1/4 of a tank) full e85 5) Any weight reduction done to the car?? (ex: removal of rear seats) 4) Type of tires and rims?? (size and weight if possible). Style 68 mickeys 5) Years of driving the type of transmission?? (this goes for mainly manual transmission, so if you are relatively new and are an "ok" driver let us know, this def makes a difference) 6) Obviously some type of proof of your 0-60 time, trap speed and finally quarter mile time. Preferably some video or slip or link to the drag time slip website to your direct slip. 11.7 |
11-29-2020, 10:21 AM | #774 |
Rep 449
First time drag racers
Decided to throw caution to the wind and take my son and son in law and both cars to the track a little earlier this year. Turned down boost on both cars as it was their first time drag racing and really driving the cars so there was reason for concern lol. They both ran mid 12's first time in the XI and 11's the first time (2nd pass ever) in the 335i and most importantly no issues the whole day. Needless to say we had a blast and they are hooked. Turned the boost up on the 335i to race my friends red 335i. Ran a 11.3 @128 with first gear turned down to 8psi due to bad prep but was happy to win. Link to a couple Vid's below and some of the slips.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C Last edited by blown07; 12-26-2020 at 11:42 AM.. |
11-30-2020, 06:50 AM | #775 |
Rep 1,420
Nice, 11.3 is great. If you can improve your 60' you might get into the 10's.
What was your Wheel and tire setup?
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
blown07202.00 |
11-30-2020, 05:14 PM | #776 |
Rep 449
Thanks... 275/40/17 NT05R's on 17x9.5 Apex arc 8's in Satin. I run them with matching 18's on the front and you can't really tell...actually looks better than the 18's on the back...highly recommended tires as I can't feel the sidewall difference.
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
Silent9n54573.50 NoGuru772.00 |
11-30-2020, 08:33 PM | #777 | |
63
Rep 124
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
11-30-2020, 08:59 PM | #778 |
Rep 449
The car is quicker with a 1st gear launch with the Sutphin trans flash. I cut a 1.79 on my 11.25 but the car dead hooked so I knew I needed to build more boost off the line. Track prep was great that day but only got 2 cracks at it. You can see it in the vid a page back that it was slow for 1/2 of 1st gear. I would like to try some E85 as well.
11-30-2020, 09:07 PM | #779 | |
63
Rep 124
12-01-2020, 08:46 AM | #780 |
Rep 449
Actually check out the red car in the video and the time slip as it left in second and I left in 1st and that was the difference in the race... and no the Sutphin flash is a different animal than XHP. Agreed a second gear launch is better with poor tires but guys running in the 10's are not leaving in second.
12-22-2020, 06:21 PM | #781 |
234
Rep 317
Nice. I run 17x10 ARC8s on the rear with 18s up front as well. I'm running R888Rs and man they hook so much better than 18s.
blown07202.00 thormessiah165.50 |
06-04-2021, 11:30 PM | #782 |
Rep 940
Well, our local track finally had a test n tune day after 18 months of covid shutting down the track. No power added in 18 months, just much needed maintenance and some weight reduction
4 passes, 4 new Personal best times. my previous PB was 11.46 @ 120 First pass Next 2 passes tried 2 different tunes with just different line pressure, EXACTLY THE SAME TIMES ?!?! Final run of the day was the best and a new PB Ill post the 0-60mph from dragy and ill try to post the video and the slip from it in the next day or 2.
06-05-2021, 04:17 PM | #783 |
Rep 940
Here is the best pass that day
06-07-2021, 06:45 AM | #784 |
Rep 1,420
Saw your post over at Spool S, very impressive times!
So you installed the Racing Diffs kit? How was the install?
06-07-2021, 03:53 PM | #785 | |
Rep 940
no issues, no leaks, no noises. Car doesnt hook hard right anymore when it spins, much easier to stay on it when it spins.
06-13-2021, 09:26 AM | #786 | |
63
Rep 124
06-13-2021, 09:31 AM | #787 |
63
Rep 124
My local track just opened up this weekend as well. Here is my slip. Launching in 2nd, shifting at 6500rpms. Running rb ones with E40 custom tune. Full weight. I also had a full tank of gas because I wasn't expecting to hit the track that day........
06-13-2021, 03:00 PM | #788 |
Rep 940
still launching from 2nd, shifting at 5300-5500rpm
06-13-2021, 08:28 PM | #789 |
63
Rep 124
Your draggy is showing 3 shifts, so you are in 5th gear then crossing the line?
06-14-2021, 01:31 AM | #790 |
Rep 940
yes, since i flushed the trans and installed new tcu, shift times have improved, and in the process of getting a custom trans tune as well so in 5th when crossing the line.
06-14-2021, 11:39 AM | #791 | |
63
Rep 124
06-14-2021, 12:03 PM | #792 |
Rep 940
i was staying in 4th before now shifts are faster so i go to 5th. I also installed a 3.5 tmap so after reworking the tune now i actually see the right psi up top and shift early at 5300 to keep the psi at 20-21
