Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > About Bimmer Performance Center
      09-27-2016, 04:51 PM   #793
hassmaschine
Drives: "NBO" 330i
Originally Posted by TheAxiom View Post
349 degrees duration? That sounds...racecar high.
yes, but actually with valvetronic, the effective duration should decrease slightly at lower lifts.
      09-27-2016, 04:52 PM   #794
Taskmaster
Japan
2470
Drives: M235i 6MT / E92 328 Msport 6MT
Sounds barely streetable.
      09-27-2016, 04:54 PM   #795
justpete
Drives: '11 328i '19 M6
2019 BMW M6  [10.00]
2011 BMW 328i  [9.00]
Sometimes barely streetable is all we ask for.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
Appreciate 3
Taskmaster2470.00
David0ff1060.50
tetsuo1111227.00
      09-27-2016, 05:03 PM   #796
hassmaschine
Drives: "NBO" 330i
I'm sure it would be fine with catless headers and a 1200rpm idle.
Taskmaster2470.00
tetsuo1111227.00
      09-28-2016, 06:10 PM   #797
justpete
2019 BMW M6  [10.00]
Yeah, that'll work. Right up until the cops get pissed...
      10-25-2016, 10:14 AM   #798
tom.gnade
Apex Forged 19", AA headers, MILVs, 3IM, Euro Intake, Swift Spec-R
Drives: 2013 328i coupe
2013 BMW 328i  [0.00]
cams
Was there ever any update on the cams?
      10-25-2016, 03:25 PM   #799
justpete
2019 BMW M6  [10.00]
No, but I'm trying to get BPC interested in building a tune with my regrinds. Long shot given as busy as they are. Asking only if they've the resources in the off season sometime. Not pressuring anyone and no one should bother them about it, it's up to the owner to make the decision.
rjahl997.50
      01-11-2017, 03:13 PM   #800
Taskmaster
Japan
2470
I know all the cool kids are moving to boost, but some of us old fashioned hipsters still like N/A. I think you guys have a shop Automatic 330i. Any updates or progress? Experiment with manually retarding the intake cam perhaps? What about testing out CobraMarty Rocker/Valvetronic lift adjuster?
( http://www.e90post.com/forums/showthread.php?t=1329840 ) for context.
      01-11-2017, 08:11 PM   #801
n55jb4
Drives: 328xi 2007 Auto
Hey Bob, I have some questions if you don't mind: for n51 guys what is the best tune you guys have currently? Is it Alpha-N? Can I get a stage 2 tune for my n51 - it already has 3SI so why not stage 2? Do I have to choose 91 vs 93 octane for tune or I can switch somehow between 2 of them? Thank you
Oh, forgot to ask, any other method I can use - maybe cams available for n51 to increase power? Just asking
      01-12-2017, 08:12 AM   #802
Bob@BPC
Bob@BPC's Avatar
Drives: F30 328i Sport Line
Currently we have 5 big project cars at the shop
- S54 3.5l stroker build, full cage, race car stuff
- F10 M5 engine & turbo build
- F10 535D build ( first one in the USA to get a hybrid turbo, meth & stage 3 tune)
- S54 supercharger build 500+hp
- & the n52 turbo build
Once I get through some of these project I will have some free time to jump back to the NA world of the n52.
For the N51, the peak horse power will not be the same as an n51, however the gains will be around the same(12 -15rwhp). As for the Alpha N tune, its recommend for street/track use cars or all out race. Around another 5 - 8hp.
Appreciate 3
      01-14-2017, 05:13 AM   #803
JuniorB
Drives: 07 e60 525 N54
Hi Dan,quick question that you may have a better understand of,I see you do a lot of motor swaps, I'm swapping a n54 in place of a n52 soon. I'm current running the msv70, the donor is msv80. Can my vin be loaded on the msv80 for legal issues. I have the donor car,both e60s, I know the car will run with the swapped modules. The emission are going to read the donor car,not my legal car. What are guys doing to solve this aspect of the motor swap? I can't drive in with a e60 525 and have them plug into a e60 535 lol. Is this something you can write? It's the last on my inquire for this swap. Thank you.
      02-19-2017, 06:49 PM   #804
Taskmaster
Japan
2470
Some minor question/update.
I think the 330i/N51 DISA set points are better for mid range power than the stock 328i values. It see that setting the transition to 4300-4400rpm instead of later still allows for the power peak at or near 3800-4000rpm, but because the power is dropping off, having the transition occur sooner doesn't seem to make the power drop off as rapidly. Probably such a violent transition while the car is already coming off peak VE causes it to drop more...
Have you guys done testing with the set points?
      02-19-2017, 08:17 PM   #805
Taskmaster
Japan
2470
Looking at my dyno, you did actually set it lower lol. Niiiicccee
      02-19-2017, 08:50 PM   #806
JuniorB
My bad ,it's the msd81 that I need in place of a msv70,sorry I was confused,just doing a lot of visa- versa.Can the current programs, speedo,steering column,ecu,cas,key,and start. The speedo is 60k as the car and ecu. I know you guys have projects going on were ecu's and programming are hand in hand. Any insite in this? Thanks guys
      02-19-2017, 08:59 PM   #807
Taskmaster
Japan
2470
Dude, I can barely understand what you're asking, I don't think they would know either.
Can you use the MSD in place of the MSV ans keep the same sensors speedo and the like? Possible, but why? If you're doing the N52 head and N54 bottom end, you need the MSV to control valvetronic.
      02-19-2017, 09:27 PM   #808
hassmaschine
Drives: "NBO" 330i
No. MSD80 is very different from MSV80. Its not a matter of swapping DMEs and making it work. Most of this stuff is locked up in a way that makes it impossible to swap (vin, EWS4 secret key, mileage etc).
The signals are the same, that isnt the issue. But this isnt something you make happen without specialized knowledge.
That said - terra and I have some ideas on how you can make this work. Meaning, swap an MSD80/81, keep your original keys, cas, vin swap, etc. We are in the early stages, but I think it is possible.
      02-20-2017, 03:37 AM   #809
JuniorB
I know it was my bad and was doing two things at once,I have the msv70 n52, my new motor is a msd81 n54. I know what to swap and what needs to run,that part is easy. What my concern is the vin conflict and mileage discrepance. When I go pull into a station,with a 07 525,and the vin comes up as a 08 535, that's the issue. With all the swaps that are going on,this seems to be the only gray area. Hope this helps,
      02-20-2017, 03:39 AM   #810
JuniorB
Thank you, I'm still in the works finding out if in my state,if this presents an issue,and if some type of recertification is needed.
      02-20-2017, 03:45 AM   #811
JuniorB
No,I'm replacing the whole n54 in, not a block,so it's a different ecu,to run it. I know a msv70/80 cannot run a n54. I do have the msd81. I can understand you wouldn't be able to answer this,it's not a n52 I'm keeping. Going boost!
