05-20-2020, 02:26 AM | #67 |
Rep 54
Was looking to get 19x9 ET28 all around on my F32, the fitment guide on the Apex website claims that its a direct fit with no modifications, is that true? Is that on stock height? Any photos of that setup?
05-20-2020, 11:22 AM | #68 | |
3595
Rep 6,846
That is correct, the 19x9" ET28 or ET30 (depending on wheel design) will be a direct fit on a stock F3X with a 245/34-19 tire. Here is a stock F31 on 19x9" ET30 SM-10 wheels wrapped in 245/45-19 Michelin PS4S tires: Hope this helps! -Geirsen
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
01-27-2021, 04:07 PM | #70 | |
3595
Rep 6,846
EC-7 Flow formed: 18x9 ET31 21.25 lbs 18x9.5 ET43 21.55 lbs EC-7R Forged: 18x9 ET30 19.2 lbs 18x9.5 ET45 20 lbs ARC-8R Forged: 18x9 ET30 18.7 lbs 18x9.5 ET45 20 lbs These weights are approximate and may vary slightly based on finish/production ET C. The forged wheels also have a significantly higher load rating as well as being lighter. Our other flow-formed wheels aren't available in these size/offsets. If you might end up running a larger BBK on this car in the future I would recommend our EC-7Rs or EC-7s despite the slight weight penalty for improved spoke side brake clearance. Any specs including weight are always available on our product pages on the website as well. Check the specifications tab under the wheel photos on desktop for this info. Thanks, -Tom
01-30-2021, 10:06 PM | #71 | |
bt5000
Rep 45
Do you have other option for widest tire for F30 like F:255+ and R275+
02-02-2021, 11:41 AM | #72 | |
3595
Rep 6,846
Alternatively, if you are looking to maximize tire size overall, some of our customers have run our 18x9.5 ET35s all the way around with 265/35-18 tires: https://flic.kr/p/2khU3ZE The 18x9.5 ET35 fitment above is not a guaranteed rub-free fitment. Depending on the model of tire you choose, alignment settings, and ride height of the car you may experience rubbing either in the front or in the rear. This fitment also has extremely close clearance up front on the strut side and is not recommended for cars with suspension that limits clearance like KW/ST coilovers. A small front spacer may be required even with stock suspension. An easier square fitment to run would be our 18x9 ET30 setup which is a direct fit with 245 or 255 section tires. -Tom
02-02-2021, 10:02 PM | #73 | |
bt5000
Rep 45
Is there FL-5 wheel for 245/40-18F and 275/35-18 tire or wider and rub-free fitment?
02-03-2021, 01:15 PM | #74 | |
3595
Rep 6,846
-Tom
