08-15-2023, 06:13 PM | #67 | |
Rep 3,958
As far as cooling mods, I've replaced the coolant radiator with a CSF radiator. When you get a chance, take a look at your auxiliary coolant radiator on the driver's side bottom. If all your fins are all bent from years of use, consider replacing that as well via FCP Euro. |
08-15-2023, 06:26 PM | #68 | ||||
Rep 4,218
Mods: Yes.
08-15-2023, 06:35 PM | #69 | ||
Rep 4,218
https://www.torqued.io/csf-12-16-bmw...minum-radiator The 2 addicts thread is a guy using a dual oil cooler setup after the CSF cooler reduced the temps by 3F. Quote:
Mods: Yes.
08-15-2023, 07:58 PM | #70 | |
Rep 3,958
I took a quick look at some of those posts, but it's also in a thread with 15 pages. It's a moving goal post because those people have heavily modified powertrains. If I had an M car with a relatively stock powertrain, I would not be changing out parts for aftermarket cooling parts unless there was a convincing reason to do so. From what I've seen at HPDEs, stock powertrain M cars have almost no issues with engine cooling - from just eyeballing the dash temperature gauge they run ice cold. Their biggest issues are not enough front axle negative camber and the need for track pads. 3F is insignificant. It's questionable whether a temperature sensor is precise enough for that to be significant. Also, keep in mind, that temperature sensor takes an instantaneous reading at one place in the entire system at a point in time (ie. https://www.realoem.com/bmw/enUS/sho...51#13621433076). The only way to know for sure is to be able to know how restrictive a heat exchanger is to flow as well as the temperature drop between the inlet and outlet. That's the empirical data that we would need to know to definitively say that a heat exchanger is effective or useless. I don't think anyone of us are able to create a controlled environment to conclusively say one way or another. |
08-15-2023, 08:25 PM | #71 | ||
Rep 4,218
But M2's do seem to have more cooling issues than others at the track. Quote:
Mods: Yes.
08-15-2023, 08:35 PM | #72 | |
Rep 3,958
I don't think bolt-ons significantly change the parameters of a powertrain. It's the tune that is questionable for track applications. I know you can read real time temps in BM3. I also do it in RaceChrono at the track which I would argue is a better way of capturing data for a track scenario. That doesn't change the fact that the temperature reading you are getting is based on 1 sensor at one specific place in the cooling system as a whole system. It's not providing you data such as flow rate through an exchanger and the temperature delta between the inlet and outlet which is what you really need to determine whether the exchange is effective. Also, the 3F variance is meaningless because what it tells us is that the stock cooling system as well as the modified cooling system's heat capacity and ability to shed heat isn't being challenged to the point where you can tell the difference. The 3F variance is more likely to be related to when the coolant thermostat is opening. However, what I can tell you is that after the Mosselman thermostat and CSF engine oil cooler, my front passenger TPMS always reads 5-10F higher than the other 3 tires. And I have square wheel/tire setups so I can rotate it every 2,500 miles or 5,000 miles to coincide with my oil changes [every 2,500 miles during track season]. A 5-10F increase in TPMS temperatures after the install of the Mosselman thermostat and CSF engine oil means that it's shedding a decent amount of heat during regular highway speed driving. |
rlesko242.50 |
08-15-2023, 08:48 PM | #73 | |||
Rep 4,218
Agree to disagree. Quote:
I'm not sure how that works - maybe you should check your alignment.
Mods: Yes.
08-15-2023, 08:57 PM | #74 | |
Rep 3,958
As far as the temperature readings off the TPMS, it's not an alignment issue because I know for a fact the specs are the same between the left and right sides. Tire wear is even. The car is gets alignments 2-4 times a year at the dealer because I like to experiment with alignment specs. If you were generating that type of temperature delta from an alignment issue, I would be able to detect from a quick check with my toe plates as well. Honestly, it sounds like most people on those other forums don't really understand how their cooling system works. They've become incredibly complicated these days because not everything is plumbed in series. Once you start plumbing in parallel, it becomes monumentally harder to understand the consequences or effects of a modification in just part of that circuit. You'd really need an engineer in fluid dynamics. Even your technician working in a dealership shop won't be able to explain the parameters of that system with the specificity needed to actually understand the system when it's pushed to its mechanical limit. Last edited by Polo08816; 08-15-2023 at 09:07 PM.. |
rlesko242.50 |
08-15-2023, 09:28 PM | #75 | ||
Rep 4,218
Mods: Yes.
08-16-2023, 06:25 AM | #76 | ||
Rep 3,958
I think it opens and closes repeatedly during regular operation because the factory oil cooler design is more than sufficient for normal use and even HPDE use. (I only upgraded the cooling system because the car was being shared which would result in the car being run back to back in different sessions for 50+ minutes continuous.) Keep in mind, there are N55 cars (like my X3 35i) that do not have an oil thermostat and engine oil cooler behind the front fascia. I would submit to you that the N55 platform, in normal driving, doesn't even really require the engine oil cooler. A liquid to liquid heat exchanger with the coolant system is sufficient to keep temperatures within operating range. The point that I'm making is that with the stock oil thermostat, a 3F difference is insignificant and if you're saying the temperatures still go to 264F-267F, then the stock oil thermostat is the limiting factor. It's very well the case that in normal use with the stock oil thermostat, someone wouldn't be able to benefit/realize the difference between a factory oil cooler and a modified oil cooler. If the thermostat decides to not flow oil, there's nothing that the factory or aftermarket cooler can do. Also, the temperature effect on the front passenger tire is not due to added weight or alignment. It's been like that for 30,000+ miles out of my car's 155,000 mile life. It's also been like that through 2 different suspension setups (M Performance Suspension kit and Ohlins R&T) as well as another M3 control arm replacement where I've had the Mosselman oil thermostat and CSF oil cooler. If it were a weight issue or an alignment issue, trust me, I would have noticed in regular driving or at the track. I also know that it's not a braking issue because when I come off track, I inspect the rotor temperatures with an laser temp gun and the left and right sides are pretty much the same. I also rebuild my calipers from time to time. With that type of temperature differential in the tires, if you're not feeling the change in balance or handling, you're have to be in the novice group. |
rlesko242.50 |
08-16-2023, 07:10 AM | #78 |
Rep 3,958
Yes, because it is an M Sport and Sport Automatic Transmission vehicle. There is a transmission radiator (that flows regular coolant to the liquid to liquid transmission heat exchanger) that sits in front of the coolant radiator. However, I question if it's an "auxiliary" transmission radiator because I don't think there is a "primary" transmission radiator.
08-16-2023, 07:22 AM | #79 | |
Rep 499
I was curious how that transmission cooler is connected to the cooling circuit - it sounds like you're telling me its connected to the heat exchanger that hangs on the radiator fan cowl? (I do see two different part numbers for that heat exchanger- 17217600550 & 17217600553 ) Although based on the research that has been done so far it seems like the rest of the cooling circuit could be converted to 'M Sport' and this could be left as-is. |
08-16-2023, 08:10 AM | #80 | |
Rep 1,130
Polo088161616.00 |
08-16-2023, 09:18 AM | #81 | |
Rep 3,958
https://www.realoem.com/bmw/enUS/sho...diagId=17_0638 I recall it being plumbed somehow with #13 here: https://www.realoem.com/bmw/enUS/sho...diagId=17_0674 I don't want to provide the wrong information because I don't remember exactly how. However, if you remove the intercooler (to be able to look up into that space ) and remove the engine coolant expansion tank, it will all be clear and make sense or at least be as clear as mud. One thing I will say is that the 3 coolant hose connections going into the top passenger side vicinity of the radiator can be confusing. If you are going to disconnect those, I recommend labeling which inlet/outlet they wil go into. I believe the lower 2 of those will go to the air to liquid transmission coolant radiator. The way the connector of those hoses "bend" doesn't make it 100% clear which hose goes where - if I remember correctly, they all appeared to have similar diameter connectors. Perhaps I got lucky and got it on the first try so the resulting coolant flow wasn't wrong. Otherwise, maybe they should have filmed my engine as the core of the nuclear powerplant in the HBO series Chernobyl. |
rlesko242.50 Boostedphil698452.50 |
08-16-2023, 10:43 AM | #82 | |||
Rep 4,218
https://www.ecstuning.com/b-ecs-part...0743ecs09~ecs/ Quote:
I'm not sure how else I can explain this to you - this is not a matter of variance, we are talking about maximum allowed. As I pointed out above, once the thermostat is open, oil is flowing through the oil cooler to keep temperatures in line. This really is only applicable to high performance driving scenarios and not daily driving. If your car is hitting 265F in oil temps, your oil is in danger of breaking down and not providing the same protection and lubrication it otherwise would have at lets say - 230F. The car will activate limp mode (cut timing, boost, and overall power) around 270F to preserve itself. So the CSF reducing MAXIMUM temps by 3F is pathetic. It's basically doing nothing to add additional headroom for maximum temperatures.
Mods: Yes.
08-16-2023, 10:45 AM | #83 |
Rep 895
The stock oil thermostat DOES work very simply like that, it just opens when it hits temperature and then stays open. There’s no partial closing or opening - it’s binary. So it’s not a real mechanical thermostat that can continuously open/close to regulate flow and temperatures (like the Mosselman), it’s just a simple ‘valve’, once it reaches temp it fully opens and stays fully open - until the car completely cools down and then it fully closes again.
AmuroRay2379.00 |
08-16-2023, 11:25 AM | #84 | |||
Rep 3,958
I have RaceChrono logs to demonstrate this point at VIR back in 2021. My N55 engine oil pump failed and oil did not flow through the circuit after a certain point in time. Over the course of 1.5 laps, engine oil temps went from 220F to 290F before the engine self ventilated through the bottom. The car did NOT go into limp mode (nor was there a drivetrain malfuntion warning) before the engine seized and a rod went through the bottom despite the rise in temperature. I surmise the actual temperature at the crankshaft was way higher than the 290F it registered at the oil temp sensor because there was no oil flow at that point. This is based on the discoloration I saw in the vicinity of the crankshaft. But if your oil sump system is functioning properly, I would submit to you that you will never see over 265F because the delta in oil temps through that circuit would be much less when there is oil flow. Quote:
And it will open and close repeatedly during regular operation. If the other cooling components could not effectively remove heat from the system without the oil thermostat being constantly open then 1) it wouldn't explain how there are other N55 platforms that do not have the air to liquid oil cooler and 2) there should not be a thermostat and it should stay open the entire time. If it was, BMW would just use this design and have constant flow: https://burgertuning.com/products/sp...l-cooler-valve Take at look at the Mosselman thermostat site: https://www.mosselmanturbo.com/en/msl-thermostat-n55 Quote:
08-16-2023, 11:48 AM | #85 | |||||
Rep 4,218
Mods: Yes.
08-16-2023, 12:01 PM | #86 | |||
Rep 3,958
One thing to keep in mind about adding fluid (like I did in the case of the CSF engine oil cooler - 0.5 quarts) is that you're increasing the length of the plumbing. This increases the work that the fluid pump has to do to cycle fluid in that circuit. How much more work? I couldn't tell you with any specificity. What I can tell you is that my car won't go back on track without the M2 N55 / S55 oil sump retrofit that adds an additional pump and pickup tube to the oil pan. Quote:
08-16-2023, 12:22 PM | #87 | |
Rep 4,218
The Do88 unit was promising (thread linked) that when it was combined with the lower temperature thermostat, never allowed heat to overwhelm the system. Again, the flimsy CSF unit could not do that.
Mods: Yes.
08-16-2023, 12:39 PM | #88 | |
Rep 499
