BMW M3 Forum (E90 E92)
      01-30-2013, 08:05 PM   #67
crazyfoo
crazyfoo's Avatar
Drives: '09 Montego Blue 335i Coupe
Hmm surprised there is no red wire...!?! I've done three now all had the red wire.
      01-31-2013, 03:23 AM   #68
Saschi
Germany
20
Drives: F82 M4
thats my problem
Umnitza said i must only connect the little white box at the OEM H8 bulb...
but the box only hat a white and brown wire ,you see on the picture ?!
so there is no red one?
the only red cables are at the wiring harness from umnitza... ?!
if i turn the white and brown from the box at OEM bulb the angle eyes turn on , of course...
but what is when i turn on the low beam ?
the angle eyes dimm and the orion v2 should turn of ? do they? there undercharged ?
      01-31-2013, 04:26 AM   #69
Wasteland
Drives: 09 Space Gray E92 M3
there's only a positive and negative coming from the box (brown or red; brown or white). Tap into the OEM angel eye positive and negative cables.
      01-31-2013, 04:28 AM   #70
Wasteland
Originally Posted by Saschi View Post
thats my problem
if theyre only turning on when you turn on the low beam, youre obviously tapped into the low beam bulb, not the angel eye bulb.
      01-31-2013, 05:41 AM   #71
Saschi
Germany
20
Drives: F82 M4
no that was my question because the OEM angle eyes have a dimm function?
and SMD cannot dimm ?!
so that was my question where i turn in + ???
to the h8 OEM bulb wire or on the yellow cable at the xenon low beam? (it is the yellow to the xenon callet?)
thx very much
      01-31-2013, 08:46 AM   #72
crazyfoo
crazyfoo's Avatar
I didn't hook up red anyway on mine. They still dim as they are supposed to when the headlights come on and function as normal. I wired it by breaking apart the stock H8 bulbs. Get some pliers, cover the blub in paper towel, and crush it. Remove all the glass and the metal circle piece at the base and there will be two long metal pieces exposed, I soldered the brown and white connections there and then the kit is plug-and-play.
You will have to test which side goes on the left or right for brown and white, so make sure you don't screw that up!
      01-31-2013, 12:42 PM   #73
Saschi
Germany
20
Drives: F82 M4
that means the orion v2 rings could be dimmed? as the normal OEM h8 bulb?
      01-31-2013, 12:44 PM   #74
crazyfoo
crazyfoo's Avatar
Yup! Dims to about 70% when the headlights come on.
      01-31-2013, 12:57 PM   #75
Saschi
Germany
20
Drives: F82 M4
ok perfect ,
than i can connect them easily with the two cable from the white box to the OEM h8 bulb...
i thougt the orion v2 turn off if the dont get enough power
thx very much i test it
edit: but why do you have 3 cable? and why you connect it with the low beam?
      02-01-2013, 12:41 PM   #76
Saschi
Germany
20
Drives: F82 M4
Done
thx to you guys
      02-01-2013, 09:42 PM   #77
badazzm
badazzm's Avatar
India
21
Drives: RRS GT2
Done
thx to you guys
Enjoy them brotha!
      02-02-2013, 11:10 AM   #78
Saschi
Germany
20
Drives: F82 M4
you seal the headlight seperate with silicone?
after it i turned them in the oven for 15min ,but my headlights are not seal
      02-06-2013, 11:52 PM   #79
Wasteland
BTW guys, i recommend not using epoxy if you glue the led engel eyes to the stock plastic tubes, mine are yellowing. looking for an alternative:
Bond 527 / Beacon 527
3M™ Universal Adhesive Clear
      02-07-2013, 12:14 AM   #80
crazyfoo
crazyfoo's Avatar
Or you could do as I did and just paint the portion from the epoxy and up all black...
      02-07-2013, 12:22 AM   #81
Wasteland
looks good!
      08-26-2013, 05:06 PM   #82
cleex024
Drives: 2008 BMW 335i Coupe
hey guys i know this is an old thread but could someone tell me if anyone has looked into which one looks better from this one and ae's that are completely round
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      09-16-2013, 05:50 PM   #83
Wasteland
if you have the completely round eyes, the car will have a surprised look to it.
      09-21-2013, 12:16 PM   #84
Najt
Drives: e92 325D 2008
can somebody confirm that the smaller/inner ring would fit into the e92 lights??
10,5 cm is way bigger then the origin, or not?
      09-22-2013, 04:15 PM   #85
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Sorry, I can't answer your question but I do want to point out that your inner ring looks like it's their V2 version and not the V4's like the outer ring you have in the pic. You should contact whoever you bought them from and get the correct ring before proceeding.
      09-22-2013, 04:32 PM   #86
LightWerkz
Drives: E90 M3
V4's have LED's next to one another, those are both V2's. The size looks correct.
      09-22-2013, 05:26 PM   #87
Wei718
Wei718's Avatar
340
Drives: 718 GT4
I thought the V2's only have 1 plug. Guess I'm wrong.
      09-24-2013, 11:08 AM   #88
Najt
yes, they are V2. V4 has only more LEDs, but unfortonutaly the are not made in 4300k color. I just only wanted know, if the size of inner ring will fit instead of inner OEM. Coz Umnitza inner diameter is 10,5cm, an OEM is about 9.5cm, and there is not so much space in the headlight.
m3post
