You might want to click this
05-12-2011, 07:43 AM | #67 |
Rep 3,460
Dzenno any chance you can confirm the accurate of the stock widebands to your aftermarket unit? I am really curious to see if there is a.difference
05-12-2011, 07:47 AM | #68 |
Rep 5,876
05-12-2011, 07:51 AM | #69 |
Rep 3,460
Nice. On all my other cars the factory widebands were dead on. The only thing I don't like about this is that Cobb only logs one bank and I don't even know which one it is. I requested the additional bank to be added but I guess they got too busy with the 07 problems.
05-12-2011, 09:03 AM | #71 |
been there... done that
Rep 277
Engine is definitely loafing so it's hard to attribute the fbo's or the u/g turbos to the nice looking logs. WGDC also looks quite good. So for not pushing it, balance is very nice.
btw, best looking presentation of logs I have ever seen on this board - most of the time you can't distinguish the colors or read the scales. |
05-12-2011, 09:10 AM | #72 | |
Rep 5,876
yep yep yeppp |
05-12-2011, 09:12 AM | #73 | |
Rep 5,876
05-12-2011, 09:15 AM | #74 |
Rep 6,631
If I email shiv like ZOMG I HAVE A CHECK ENGINE LIGHT I can see him doing that, the problem is when it is tune related and I have data for him, provide me with an intelligent answer instead of blaming a meth kit for negative timing or boost oscillation.
I can only count the endless number of people who went crazy trying to diagnose misfires by replacing perfectly good hardware.
E90 LCI N54 6AT
05-12-2011, 09:28 AM | #75 |
Modder Raider
759
Rep 8,633
Drives: M3
Did we ever find out whos graphs these were?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-12-2011, 09:29 AM | #76 |
Rep 5,876
FYI
for those that have cobb, try turning off your traction control and relogging...traction control can introduce throttle closures that otherwise wouldn't have been there...before thinking its tune related, datalog with DTC clicked at least once or fully off..the road you drive on might actually be the reason for your throttle closures |
05-12-2011, 09:31 AM | #77 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
05-12-2011, 09:33 AM | #78 |
Modder Raider
759
Rep 8,633
Drives: M3
05-12-2011, 09:34 AM | #79 | |
Mad Linux Guru On The Loose
1130
Rep 5,404
Drives: 2008 335i Sedan, 2023 M3
Nevertheless, I will give it a try and see if I can get different results. One can never loose hope!
05-12-2011, 09:38 AM | #80 |
Rep 8,835
You would be able to tell if it was traction related by looking at rpm graph. If its smooth then chances are traction wasn't the culprit. It is however a good idea to have the dtc pressed at least once while doing any type of logging.
05-12-2011, 09:50 AM | #81 | |
1130
Rep 5,404
Vasil
05-12-2011, 09:52 AM | #82 | |
That guy
117
Rep 5,740
Also, the car will at times reduce power in anticipation of traction loss (so the light doesnt go off). All logs should be ran with everything off to ensure all data is tune related. |
05-12-2011, 09:54 AM | #83 |
1130
Rep 5,404
Cool cool! I'll give it a try as soon as the streets dry up.
05-12-2011, 10:37 AM | #85 |
That guy
117
Rep 5,740
05-12-2011, 11:11 AM | #86 |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Ya I noticed with traction control on even in 3rd gear the car had throttle closure without traction light blinking.
Soon as I turned it off car took off like no other. Something fishy going on with road speed sensors with traction control on or something idk |
05-12-2011, 11:20 AM | #87 | |
Rep 5,040
