Ista-d_2.36_ista-p_2.5.40
11-21-2013, 11:17 PM | #67 |
Rep 9
ISID
[QUOTE=Sensible_;14732232]Hi,
Once again i'll share what i'm using This is an ISID Virtual Machine with both ISTA-D and ISTA-P installed. ISTA-P has been updated to 50.4 and I-LEVELS corrected. What is unique about this VM is that it has an ICOM EMULATOR built into it. Of course you need an ICOM EMU dongle to use it, unless you want to replace the files with the free version Thats up to you... Anyway, to use this - there a 3 network adapters installed. Only eth0 is connected at start up. If you wish to use the emulator you must then turn on the second net adapter eth1 and wait until device configuring messages clear. Then disconnect eth0. Once complete you can start the emulator process as normal. Also, I made printing easy with quick links to dedicated folder. Hope its useful. Oh, and download latest winrar as i use RAR5 compression. Sadly 41GB download Thank you Sensible for your effort, Im downloading this version of yours, I have Icom it will allow me to select the interface is there a menu to choose, this version will do flashing on a single ECU?. thanks again |
11-23-2013, 12:35 AM | #68 |
Rep 7
Running two systems:
First is a C2d notebook with a T7200 , 4GB RAM, win8 x64, and also Samsung Evo SSD 256GB, and a 7200rpm hdd. Notebook has a max read speed of 220MB/s ... i.e. early SATA2 controller. Second is a C2 Quad Q9550 with 8GB RAM, win8 x64, on a 7200rpm platter. The RAM is the big difference, but when I moved the VM to the SSD on the notebook, the SSD used as virtual memory was able enough to keep the system moving. Will move VM to a new PC: i5 with 8GB RAM I am building as I write this, for it's future use. Thanks again Sensible. |
11-26-2013, 01:15 AM | #69 | |
Rep 9
Hi sensible, I manage to download your build, I did connect the ICOM for diagnostics, for programming Im having a hard time configuring the vm connections, Im using ICON only, could please tell me the right configuración on VM for the 3 vnet, thank you. |
12-01-2013, 05:10 AM | #71 | |
Rep 9
Thank you guys for helping me, Im stiil not connecting to isid or istap, Im using ICOM only, if someone manage to conect this vm to a ICOM clone please tell me the steps in configuring vmnet 1 2 and 3 or jusat the vmnet that is needed for ICOM. Best regards |
12-01-2013, 12:17 PM | #72 |
529
Rep 2,503
Boot VM with just #1 connected.
Once booted, connect ICOM to car . Wait a minute or so then right click on #1 (eth0) then settings then change from custom to 'bridged'. Wait some more then icom should be visible in connection manager. |
12-02-2013, 10:24 PM | #73 | |
Rep 9
BO 008E0001 BO 001B0001 BO 00240001 BO 00460001 BO 006F0001 Is in this situation when I use IBAC, the problema is the combox unit was replaced now I need to program RAD2 and all related most units, but it ask to download codes, anyways I think I can put the answer codes on a usb stick and ISTA P will read it from there I think . I have no idea why ISTA p sees the new combox and the whole most modules as retrofit, can you share a light on this matter. Best regards |
12-12-2013, 02:12 AM | #74 |
Rep 6
Sensible_
Thanks for sharing, everything works perfectly for me. One question, have you tried modifying ISTA P so that it allows the voltage to drop below 13 volts. I think it will be easier to mess with the software instead of getting real expensive PSUs. What do you think, is it possible? |
12-12-2013, 06:02 AM | #75 | |
General
10543
Rep 41,207
12-12-2013, 10:28 AM | #76 |
Rep 6
Well, if you hook the car up to a charger I don't think it's going to be a problem. I have updated the software of individual modules without any charger or PSU, no problems. You just have to have a good battery. It's just a stupid safety measure of BMW and a pain in the ass for us, that's all |
12-27-2013, 03:47 AM | #78 |
20
Rep 72
Help With "e89 Ista-p-d" And Gini's Emulator.
Hello,
Merry Christmas To All. I Own A E90 320 06/2006 Which Work Perfectly With The Older Software And A K Can Cable. I Have Downloaded And Running In Vm Both "e89 Ista-p-d" And Gini's Emulator.i Made Lot Of Reading But In The End I Am Confused. Can Somebody Guide Me How To Make This Two Work? (settings-sequence Of Moves) I Read Many Post From Tinkerman He Has The Same Car And He Made Them Working. Thanks |
12-30-2013, 03:10 PM | #79 |
14
Rep 117
Does anyone have a link ISTA-D 2.38 Rheingold? Seems like everyone keeps saying on forums that it's easy to install and it works fine with DCAN cables, but couldn't find any viable links to download.
01-02-2014, 04:58 PM | #80 | |
Rep 648
01-03-2014, 09:38 PM | #81 |
14
Rep 117
I'm using macbook pro with intel P8600. It is supposed to have VT, but doesn't work neither in Windows 7 (through bootcamp) nor MacOS X 10.9. Is there a way to make this VM running?
01-04-2014, 02:29 PM | #82 | |
295
Rep 2,203
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
01-08-2014, 02:21 PM | #87 |
57
Rep 104
01-08-2014, 02:51 PM | #88 |
20
Rep 72
Thank You Tinkerman. Is It The Same Com Port For The Gini's Snapshots?
I Tried Today With My Netbook But It Was Very Slow. Next Time I Will Try With The Laptop That Runs Vm With No Problem. |
