Something cool (n54 vs 3sm Page 5)
11-22-2015, 09:03 PM | #67 |
198
Rep 2,239
I'd enjoy true ITB's if there were kit or a way to make them more user friendly bolt on.
As well as a tune to compliment it. all though i know AA said they'd love to tune ITB's.
08 e93 335i MT
11-22-2015, 10:14 PM | #70 |
Rep 7,215
Itbs on an N52 means running full standalone and ditching valvetronic, head machining etc. That is not simple.
We can have something even better because we dont need throttles at all. All we really need are trumpets and an airbox. |
11-22-2015, 10:18 PM | #71 |
Rep 3,778
Drives: '11 328i '19 M6
I've been told the stock DME can't be used if Valvetronic is locked open so a TB throttle cable could be used so ITBs would need a Motec ECU or the like meaning the rest of the car no longer works.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-22-2015, 10:18 PM | #72 | |
Rep 7,215
You could do the same thing by cutting up an N52 manifold. Theres nothing special about the N54. |
11-22-2015, 10:20 PM | #73 |
Rep 3,778
And it's really really tempting for a track car, sounds really cool.
11-23-2015, 09:23 AM | #74 | |
Rep 7,215
On all the tunes I've seen there's a parameter for maximum intake cam timing and it's always set to 120 degrees (I think there's a total adjustment range of 75 degrees, so the minimum would be 55 degrees). I wonder if it's just a matter of changing those targets enabling a bit more physical adjustment. it would definitely benefit higher RPM speed, and likely allow a higher redline before VE falls off the cliff. |
11-23-2015, 11:57 AM | #75 | ||
Rep 9,004
11-23-2015, 12:52 PM | #76 |
Rep 7,215
Basically the thing that is needed would be a bolt on manifold & plenum. But even if something like that were made, it would be expensive. Something along the lines of a replica CSL airbox for the E46 M3 - $2-3k.
Thus the N54 intake. It's cheap although not really perfect since there's no plenum or filter. You could fab that yourself but it's never going to be bolt-on. |
11-23-2015, 02:01 PM | #77 | |
Rep 9,004
A N54 manifold would bolt up, you could use the same TB, MAF, intake plumbing, and an off the shelf tune. I don't want to fabricate an airbox, or pay 4k. I just want an easy bolt on solution...and supposedly it makes sven more power than the 3 stage even without headers - that's why it's appealing. Those numbers are nice, but so is this: (They say it's a 3 stage, but no dropoff? Hmmm...) Or this. That's over 95% of the power without hacking everything up and requiring 2k in fabrication. Again more power is nice, but at what cost? Last edited by Taskmaster; 11-23-2015 at 05:36 PM.. |
11-23-2015, 02:07 PM | #78 |
Rep 7,215
yeah I don't think it makes sense unless you DIY. And I'd expect a torque loss at low RPM.
What drop off are you talking about? the typical "wall" at redline? that is part of the tune so it should be possible to flatten it out. VE will still drop off at some point but the stock tune makes it far worse than it needs to be. also, at least some of the power gain is from ditching the TB & MAF, neither of which are really required since the DME controls VE almost directly through vanos & valvetronic. I have access to a 3D printer at the tech school, my idea is to make some sort of adapter for a CSL replica airbox to bolt up to the N52 head. But that's more of my own personal preference, and I really want it for the sound.. BTW, rjahl, that 2.5si tune is really aggressive. I ended up copying parts of it into my own tune to see what it does. The ignition timing is even more advanced than the aftermarket tunes I've seen, and the intake vanos tuning is way more aggressive. The disa transitions are also quite different, as are the sport switch settings. I'd like to see a dyno of one! the max intake retard parameter is still set the same as the other cars I've seen (122, not 120), but still with it set at 125 in the maps I want to try it. It would be easy to verify by looking at the actual vanos position vs the target in Testo. Last edited by hassmaschine; 11-23-2015 at 02:24 PM.. |
11-23-2015, 02:19 PM | #79 |
Rep 4,040
Drives: 130i coupé ;)
great stuff in here. M50 manifold style
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
11-23-2015, 05:55 PM | #80 | |
Rep 9,004
I want More power I want streetable power I want minimal/no fabrication/custom work. That's why I like the idea of using the N54 manifold - yes I understand there will be losses, but how much, and how much of a gain are we talking? With something like the manifold, a off the shelf tune solution could work for anyone who wanted to plug and play, and go back to stock anytime. Hacking up the single stage seems easy enough, hashing out the fine details is where majority of the work comes in. Not about that life in my daily. |
11-23-2015, 05:59 PM | #81 | |
Rep 7,215
11-23-2015, 06:07 PM | #82 | ||
Rep 9,004
11-23-2015, 06:12 PM | #83 |
Rep 9,004
One more question Hass, do you think the High RPM drop off (after 6500rpm) is because the DISA is trying to close, or the catalyst protection is still built in?
11-23-2015, 06:23 PM | #85 | |
Rep 9,004
11-23-2015, 08:40 PM | #88 |
Rep 3,856
