BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > M3 Steering Rack Swap
      02-06-2015, 12:30 PM   #67
PHanna04
Drives: 2009 328i
Anybody had any success with an xi?
      02-07-2015, 07:26 AM   #68
gtaccord
Drives: 2009 BMW 335xi
Not possible on an xi.
      02-07-2015, 08:45 AM   #69
gtaccord
      02-07-2015, 03:22 PM   #70
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
To the people who have done this mod: what effect has this had on your stability control? I recently quickened this steering ratio on another car I have and the stability control no longer works. The system compares speed, steering angle, and yaw rate. If you quicken the steering the steering angle sensor values will no longer match the programmed values in the stability control. The yaw rate will be faster for a given speed and steering angle making the car react as if it's oversteering. You would need to reprogram the DSC unit or somehow modify the signal from the steering angle sensor.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      02-07-2015, 06:54 PM   #71
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1131
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
The only reason why anyone would want faster steering is so that they can drive the car more effectively on track and autox events. In both situations the traction control should be completely disabled any way. I fail to see the problem here...
      02-07-2015, 06:59 PM   #72
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Didn't mess with my car, one of my favorite mods. Traction control is always off lol!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      02-07-2015, 08:28 PM   #73
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
What about on the street? I'm just wondering if anyone got it to work again or at least found a way to have it disabled by default when the car starts.
--Marcelo
      02-07-2015, 08:32 PM   #74
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Nothing plugs in, you leave servo unplugged. I didn't even have steering angle sensor recalibrated.
      02-07-2015, 08:38 PM   #75
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Interesting. I'm gonna try that with my other car so I don't have to keep pressing the button every time I start. With the BMW though you'll have to manually cancel the turn signals because BMW.
--Marcelo
      02-08-2015, 09:58 AM   #76
vwetish
Drives: e90 335i
How about adverse effect on the function of the ABS? Granted, you can turn off DTC but you can't turn off ABS and is known fact that bad steering position sensor will throw out faulty codes for the ABS as well because the system will malfunction. I have seen this on E90 and other BWM's as well, e46 in particular.
You will have these codes:
      02-08-2015, 10:02 AM   #77
vwetish
Drives: e90 335i
plugged or not servo has nothing to do with the steering position sensor as that is mounted on the steering column slip ring
      02-08-2015, 01:25 PM   #78
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
The abs light isn't on. I wonder if it still works. Only the yellow "brake" light is on.
--Marcelo
      02-24-2015, 09:32 AM   #79
marconi118
Drives: 06/07 e93 335i
done on mine
no malfunction of DSC and ABS at all
      02-24-2015, 12:20 PM   #80
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Originally Posted by marconi118 View Post
done on mine
awesome! How do you like it? I love mine!
      03-11-2015, 11:03 AM   #81
marconi118
I love it too !!!!!
on heavy track use (lot of turns) the oil can spill out of the reservoir.
this is a common known M3 problem. we should upgrade to the bigger reservoir of the E92 with active steering.
Any hope that BMS will include the control of the stiffness in a new release of the JB4?
I actually control the stiffness by sending a PWM signal to the valve. but it is or too stiff for low speed or too light for high speed.... a variable PWM is needed
      04-27-2015, 10:16 PM   #82
BoostNinja
59
Drives: 335is
Hope this helps guys....
I found that on a 1m the JBE controls the servotronic (pretty sure the dme does on a m3)
Hopefully that means that we can make servotronic work on our cars by possibly programming/coding the jbe and wiring it up
So the wires from servotronic go to the large connector on the back of the JBE/JB connector (X14270)
Pin 5 (black wire with brown stripe)
pin 6 (black wire with white stripe)
These are not listed in ANY wiring diagram, with factory diagnostic software it says those pins are not used. I verified by checking continuity between the servotronic connector and the pins at the jbe. Its 100% accurate.
The ZB number of the jbe that has working servotronic is 9264577
Remember this is on a 1M, im 80% sure this will work on a e90. It should work for sure on a 135i.
GOOD LUCK!
Appreciate 3
      04-27-2015, 11:03 PM   #83
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
GOOD LUCK!
WOW!
      04-29-2015, 09:46 AM   #84
marconi118
WOW it would be great to code this module!
Any coding guru could come in?
Where is located the JBE?
      04-29-2015, 08:45 PM   #85
BoostNinja
59
Drives: 335is
It's below/behind the glove box.
      06-08-2015, 03:45 PM   #86
idnan
idnan's Avatar
England
76
Drives: Alpine White 335i
Any update on this? Would love to have working servotronic on the m3 rack on my car.
      06-11-2015, 06:54 PM   #87
Kizzu
Malta
41
Drives: Bmw 125i Black Sapphire
Will this conversion fit on a co2 packaged e82 with electronic assisted steering?
      06-13-2015, 05:47 PM   #88
BoostNinja
59
Drives: 335is
I doubt it. Anyone tried it yet? Ive been swamped with customer cars.
