2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes H&R Sway Bars Finally Available in US for F10!!
      07-25-2016, 01:01 PM   #67
gestut
Drives: 2015 M5
Originally Posted by Aaron@Autosource View Post
Front does, people are just concerned at the difference in the angle at which the very of the front bar sits(between M5 and non M front sways).
M5 rear is no go for non M car(pretty sure most people know this now lol).
So at this point still only 2 guys have ever ran the H&Rs...and neither has been able to write a detailed comparison due to not having tried both setups I believe.
By any chance any of you guys have an H&R front laying around? I got my hands on a rear. I have M5 CP front and 650i rear sitting here as well.
I finally got H&R front and rear installed a month ago, (2014 550) fitment is perfect, just like factory, had no issues except trying to take front hex bolt , PIA.
handling has definitely changed , i can turn in faster , and body roll is dramatically reduced , moderate increase in turn ins , when pushed the tires squeal now
      07-26-2016, 01:45 AM   #68
TheBlackGT
Like No Other.
TheBlackGT's Avatar
Drives: BMW F07 LCI
Do you have any suspension mods?
And how much did you pay for them?
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT
my work: http://www.instagram.com/CorsaAutoDesign
      07-26-2016, 12:48 PM   #69
gestut
Drives: 2015 M5
no suspension mods, oem m sport suspension, I got it from ECS tunning paid just under 700 shipped. direct shipping from H&R
      07-26-2016, 12:49 PM   #70
TheBlackGT
Like No Other.
TheBlackGT's Avatar
Drives: BMW F07 LCI
How are you liking them over time, worth the upgrade?
delje08153.00
      07-26-2016, 12:54 PM   #71
gestut
Drives: 2015 M5
its wort the upgrade, as the body roll was noticable before . Honestly I havent put that much miles yet, its super hot here in AZ, have been driving my jeep lately. keep in mind you will have to upgrade your tires to complement the sways bars from the run flats. I will putting on pilot super sport this fall, that will change the cars handling more in my opinion with the sway bars
      08-09-2016, 12:32 AM   #72
2011BMW550i07
2011BMW550i07's Avatar
Drives: 2011 BMW 550i
Hey I'm interested in doing this mod with my car as well. Just lowered my car on H&R spring so also want to tighten up in turns. Where did you order yours? Also, i'm out in AZ as well.
      08-09-2016, 01:59 PM   #73
gestut
Drives: 2015 M5
I got it from ESC tuning , and they ship direct from H&R. how are you liking your springs? do you have m sport suspension ? the sway bars are easy to install. I see you are local to me...
      08-09-2016, 05:46 PM   #74
2011BMW550i07
I don't have the adaptive suspension if that's the one you're talking about but I do like the H&R springs a lot better then stock that's for sure. Stock was just too soft and feels like I'm in a boat almost. I like planted and firm when it's needed. I came from a E60 M5 so I like it to be more firm. My car was destroyed and the new F10 M5 was out of budget for me at this time.
      08-10-2016, 08:39 AM   #75
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
this is definitely and upgrade i want to do eventually. the fronts look easy to do just wasn't sure on the rears like i mentioned before?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      08-12-2016, 09:02 AM   #76
snj1013
Drives: 2011 528i
While not the H&R version, I did finally get around to installing my M5 front sway bar yesterday. Took about 45 minutes with handtools. You do need external torx sockets to remove the bushing mounts, but other than that, piece of cake. From what I've read, do not attempt this mod without the wheels under load (use ramps, not jack stands). I believe lining up the end links without the wheels under load is tough.
      08-16-2016, 03:31 PM   #77
lsturbointeg
so you ride the fronts on ramps swap the bar than ride the rears up on ramps and do the same? didn't know that! gonna suck for me as i'm sitting really really low
      08-16-2016, 03:55 PM   #78
snj1013
Drives: 2011 528i
Not sure about the rears. I am referring to the fronts. If I'm not mistaken, I think the rear can be changed as the car sits.
      08-19-2016, 03:54 AM   #79
WST
Drives: F10
All I can say H&R sway bar is a must mod item even it's a stock F10. Nearly eliminate the body roll. I drove my stock 28F10 with 17" stock RFT for 2yrs, then upgrade the sway bar only. The handling complete changed, feels like a different car. 6mths later, I upgrade the wheels to 20" and it feels better. Another 6mths later I put on KW v3, and I was regret that I should start do the mod 1st day when I pick up the car.
delje08153.00
      08-20-2016, 10:50 AM   #80
gestut
Drives: 2015 M5
Not sure what the reason is for ramps. Thats news to me.I always installed sway bars on a lift. Had no issues. I am sure the dealers use their lift and not ramps
      08-21-2016, 11:00 AM   #81
snj1013
Drives: 2011 528i
Try it and see how it works out for you.
      09-27-2016, 06:37 PM   #82
initialM
initialM's Avatar
Drives: F10 535i M-sport
I've searched for the DIY F10 sway bar remove/install guide, but seems no luck. Has anybody seen one? If so please let me know!
TIA
      10-24-2016, 07:49 PM   #83
Jayphil
Jayphil's Avatar
63
Drives: 535I xdrive 2011 (M-SPORT)
I just orderred a H&R Sway bar front / Rear kit for my Xdrive. I hope that it will be a great compliment with my H&R springs.
Currently I do enjoy the ride most of the time exept when I go into some turns where I away wish that car would stay flatter. I do not expect it to become a track but currently it does not handle in well enough in turns for my liking.
I will keep you posted with the outcomes when I get the bars and have chance to get those installed.
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
      10-30-2016, 11:35 PM   #84
07e92
Drives: 07 335i
What are the torque specs on these?
      11-05-2016, 05:20 AM   #85
paul223
paul223's Avatar
Drives: F10
4 bolts mounted to body frames are around 100-110 lb torque spec.
      11-06-2016, 01:21 AM   #86
initialM
initialM's Avatar
Where did you get this information from?
      11-06-2016, 09:36 AM   #87
paul223
paul223's Avatar
Drives: F10
When I installed swaybars, bolts took about 100-110 lbs of torque to unscrew them.
5post
