BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 / N26 Timing Chain Failure Log
ARMA SPEED
View Poll Results: Did you experience timing chain failure on your N20 engine?
Yes, my timing chain failed or required replacement. 33 14.47%
No, I have not experienced timing chain failure. 187 82.02%
I replaced my timing chain as a preventative measure. 8 3.51%
Voters: 228. You may not vote on this poll
      06-27-2019, 09:53 AM   #67
DYH
Drives: 2013 328i xDrive M Sport
Originally Posted by rjdnyy224 View Post
Originally Posted by pierreye View Post
You can try to use a borescope to take a look. Especially at the joint where the plastic will most likely break. You can refer to the photo I take on the possible point of failure.
Where is that joint in relation to the front of the engine? As in, if I were to buy a borescope and take a look, where would I want to be pointing the thing?
The joint is on the lower right side.
rjd_F302001.50
Fr3sh29.50
      06-27-2019, 11:59 AM   #68
fluke
Drives: 2013 328 and 2015 X5
Here's a diagnosis method I've posted before that some of you will find useful:
You can check your oil filter for metal shavings or bits of plastic by cutting the filter media open. In most engines, oil flows from the inside of the filter to the outside, so the shavings will be in the folds of the filter media when you cut it away from the center of the filter with a razor. Ferrous shavings will be shiny and stick to a magnet (cranks, rods), babbitt will be metallic but non magnetic you can also crush it with a hammer (bearing material), and plastic will crush but not be shiny (timing chain guide). You should do this every time you check your oil, it's easy and free. You can google "aircraft oil filter inspection" for videos. Thankfully we don't have to cut our filter housings like most other cars, that's a pain and the tool dulls quickly and is hard to sharpen.
      06-28-2019, 01:11 PM   #69
F30Cooks
Drives: F80 Comp DCT | E46 330iT 6MT |
Model: 2013 328i Sport RWD
Mileage: 46k miles
Timing Chain Status: No problems
Oil Changes: every 5k miles since 46k, not sure about PO
Stop/Start Coded Status: Coded off by me. not sure about PO
Additional Details: None
      06-28-2019, 04:09 PM   #70
martini1305
Drives: BMW F30 320i MSport
Model: 320i 2012-Sept-12
Mileage: 60k miles, mostly motorway miles
Timing Chain Status: No problems. Checked today at dealers
Oil Changes: As per on board computer indicates.
Stop/Start Coded Status: Not coded but always off since 17k miles, not sure about PO.
      06-28-2019, 08:25 PM   #71
ohnoitsvinny
Drives: 2013 328i Xdrive
Model: 328i xDrive 2013 Prod. date 2/2013
Mileage: 71k miles, mostly motorway miles
Timing Chain Status: Faint sound and recommended to replace by local mechanic.
Oil Changes: Every 6-10k varying
Stop/Start Coded Status: Coded off at 11k. Not sure about PO
Plans: Trade in the car and forget about the issue.
      07-01-2019, 11:23 AM   #72
jsouth
jsouth's Avatar
Drives: 2013 328i
I dropped my car off for timing chain and guides, and oil pump chain replacement today. I can't change my vote in the poll, but I do plan to keep the car a long time. I like road trips, and don't want to be in the middle of nowhere far from home when the high-pitched whine shows up.
This should restore peace of mind and dependability.
      07-01-2019, 12:55 PM   #73
RMachuca3d
RMachuca3d's Avatar
725
Drives: F30 328i Msport
How much did they quote you and did you get a cost break down?
sspade2476.50
      07-01-2019, 04:10 PM   #74
jsouth
jsouth's Avatar
Drives: 2013 328i
With tax, a little shy of $3000 USD at an independent BMW shop. I don't live in a major metropolitan area, so there are few choices to drive prices down. I don't have time to do it myself.
I priced trading up to a post-2015 model, but that would cost $8,000 minimum. My car looks pretty new and is still comfortable, so this is the most cost-effective option.
Update:
See post 78 for complete and accurate breakdown after I picked it up.
      07-01-2019, 09:21 PM   #75
pierreye
Drives: F10 & G01
jsouth
Please check your timing chain rail once it's taken out. I'm curious if you have the same crack as mine although no whining timing chain sound.
      07-02-2019, 09:24 AM   #76
MilanF30
48
Drives: BMW F30 328i
Model: 2012 328i Sport RWD
Mileage: 107k km
Oil Changes: ~every 5-10k km
Additional Details:
I tried using small borescope, it's 5mm diameter and i was able to stick it pretty much everywhere
It can reach both left or right side, all the way down to oil pump chain... here's few images if anyone interested
Solidjake951.00
sspade2476.50
      07-03-2019, 05:01 PM   #77
jflow72
Drives: 2012 BWM 328i
Model: 2012 328i RWD
Mileage: 65k miles (Bought at 38k, BM3 since 40k)
Oil Changes: every 5k-6k miles since I owned it.
Stop/Start Coded Status: Coded off when I bought it.
Additional Details: Took it in twice to BMW to check the timing chain before my warranty was up due to 7 years. They kept it overnight to hear a cold start that last time. They said no issues.
      07-04-2019, 09:40 AM   #78
jsouth
jsouth's Avatar
Drives: 2013 328i
jsouth
My guides had no cracks. Both chains were silky smooth. I probably would have had no failure but I didn't want to gamble. We take road trips for vacations and I couldn't afford to be away and have either a failure or the noise indicating imminent failure.
The bill was $598.09 US for parts:
  • Vacuum pump seal
  • Cam adjuster seal
  • Front Crankshaft seal
  • Crankshaft pulley bolt
  • Oil pan gasket
  • Valve cover gasket
  • Timing chain, guide, and tensioner
  • Oil pump chain, guide, tensioner, and sprocket
And 18 hours labor at $115 US per hour (total of $2070 labor)
For a grand total with tax of $2717.43 US
Appreciate 4
Dylantm50.00
sspade2476.50
      07-05-2019, 12:12 PM   #79
trentr98
Drives: 2013 328i X-Drive Sport
Model: MY 2013 328i xDrive. 11/2012 build date
Mileage: 65k
Timing Chain Status: No issues
Oil Changes: Carfax shows mostly 6-7k intervals but one of 15k, all at BMW dealership
Start/Stop Coded Status: Not coded but I always turn it off immediately
Additional Details: Purchased with about 60k with full records privately. Only engine related issue the car has ever had was the thermostat (covered under extended warranty)
      07-09-2019, 04:04 PM   #80
Mike_BMW
Drives: 2014 320iX Luxury
This video is interesting, not sure what to make of it.
2014 F30 320iX SE/Luxury: Current daily driver.
2008 E60 520d M-Sport: Retired April 2019
2004 E46 318i Compact SE: Retired June 2012
      07-10-2019, 02:13 AM   #81
jan31
jan31's Avatar
Drives: 2014 F32 428I Xdrive (N26)
Model: 2014 428xdrive
Build: December 2013
Mileage: 79k
Oil Changes: Every 5k miles since 42k
Stop/Start Status: Coded off at 42k
      07-10-2019, 01:49 PM   #82
jsouth
jsouth's Avatar
Drives: 2013 328i
Not true. Failure rate seems to be about 5% or less. It's a risk, but it's not a "your engine will absolutely grenade" issue.
Billfitz8316.00
Dylantm50.00
      07-11-2019, 12:46 AM   #83
RMachuca3d
RMachuca3d's Avatar
725
That kid is just baiting for views.
      07-13-2019, 12:29 AM   #84
bentheredonethat
Drives: 2014 BMW 328i
Model: 2014 328i RWD (N26)
Build: Not sure, I will look it up
Current Mileage: 92k
Timing Chain Status: Replaced short block along with guide and chain at 77k miles.
Oil Changes: Every 5k miles since 45k
Stop/Start Status: Manually turn it off every time.
Additional Details: I took it to dealership for a whining noise and they found metal shavings in oil and said engine needed replacement. Later I found out it was because the timing chain guide broke and caused problems. BMW and extended warranty replaced short block, chains/guide, and turbo under good will and I haven’t had problems since.
      07-16-2019, 12:16 PM   #85
LaNcE01
LaNcE01's Avatar
23
Drives: LR2,328i,GLC220d,LibertyGT
Build: OCT 2012
Mileage: 693xx Kms
Oil Changes: Every 10kms, before then not sure what the previous owner did
Stop/Start Status: turned off each time from 56k kms
no issues just yet but its making me paranoid!!
      07-16-2019, 06:38 PM   #86
JoeyMcMahon101
Drives: 2013 BMW 328i xDrive
Alright everyone, I'm almost at 122k on my 2013 f30 n26. The higher the mileage the more likely it won't happen to you, it won't happen to most people. And it's an expensive job, it may never break on you guys.
sspade2476.50
      07-16-2019, 06:41 PM   #87
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Any mods/tune?
      07-16-2019, 06:42 PM   #88
JoeyMcMahon101
Do not, I repeat DO NOT tune them. They can't handle it, also not all timing chain and guides were affected. Only a handful. But don't tune it... numerous shops warned me, if you do, then do the chain and guides.
