11-28-2014, 06:17 PM | #67 | |
Retired Curmudgeon
3000
Rep 4,075
PFC please.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
11-28-2014, 08:45 PM | #68 |
Rep 8,077
Drives: 11 E90 M3 Individual
Brembo is out because of the monoblock caliper. And the ridiculous cost of consumables.
If money were no object, I'd get PFC or AP Racing.
2018 F30 320iX Melbourne Red
11-29-2014, 01:38 PM | #69 | ||
Rep 439
11-29-2014, 01:56 PM | #70 |
Rep 9,034
At least we can take away that the ST Sport pad is a pretty good everyday and semi track pad. I would hope all the kids were designed with the OE master cylinder in mind.
Ideally, they kits would all run the same pad on the same time, but then people would say that kit X or Y was not designed to run with the chosen pad. This is just one piece of information when deciding what kit to buy. It's probably the best comparo so far between the major BBK's out there. Maybe i missed it, but can anyone comment on if they used the rear BBK too? .
11-29-2014, 07:11 PM | #71 |
Rep 8,077
I would like to know that too. In my mind...that would make a significant difference.
11-30-2014, 12:55 AM | #72 |
8300
19
Rep 573
11-30-2014, 01:18 AM | #73 |
8300
19
Rep 573
Also, let me restate something I mentioned before a bit more clearly:
The brembo kit they tested is for all practical purposes equivalent to the E46 380 kit with the thinner rotor and the M caliper. The reason probably is that this kit is the only TUV approved kit and does not require the "Einzelabnahme" from TUV like PFC and AP (the only kits that they mention need this). You can also figure this out from the pictures of the rotors that don't have the McLaren fasteners. Brembos still suck though. Just mentioning this detail for whomever thinks it is interesting. |
11-30-2014, 09:54 AM | #74 |
Rep 8,077
Just tears from brembo owners
11-30-2014, 02:45 PM | #77 |
11818
Rep 23,187
11-30-2014, 04:05 PM | #79 |
DSC Off!
307
Rep 718
11-30-2014, 06:12 PM | #80 |
Rep 8,077
I've got the ST60 kit on the front. Regret not getting the ST40 so that I can run much cheaper 17" wheels/tires AND use cheaper pads and rotor discs.
11-30-2014, 08:11 PM | #81 | |
DSC Off!
307
Rep 718
Anyone else think ST-40s are sufficient in the front?
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
11-30-2014, 09:25 PM | #82 | ||
Rep 5,482
At some point you need to get more air to the brake system or you are just shifting the heat soak from the brakes to the tires. Does no good to have extra heat capacity in the brakes if the tires grease up anyway. If it's enough brake for a viper which acieves anout 20mph higher terminal speeds, its enough for an m3
12-01-2014, 01:33 PM | #83 |
Rep 842
A couple of thoughts from an insider viewpoint:
Overall, I wouldn't go so far as to completely throw this evaluation under the bus, but I don't know how much valuable data actually lies within it. As far as I can tell we're looking at street big brake kits being tested for stopping distances under moderate usage conditions that don't even exceed the stock brake system's capacity. In such a case, feel and aesthetics will be the primary differences between kits, which are both subjective. |
12-01-2014, 01:58 PM | #84 |
Rep 3,633
Everyone here becomes hyper critical when they see results that they do not agree with simply put. I can change the pads in my stock brakes and make them great, but that wouldn't evaluate an "as bought" kit then would it? They did the right thing, and while we can improve upon individual components the data collected isn't bad.
12-02-2014, 09:26 PM | #85 | |
Dr. Octagon
261
Rep 1,919
Thank you jritt@essex for your well-written post.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
12-02-2014, 09:36 PM | #86 |
Rep 3,633
12-02-2014, 10:11 PM | #87 |
Rep 8,077
Lol
12-02-2014, 10:45 PM | #88 |
Rep 3,422
I do. ST-40 with race pads (RS29s for me) up front and a race or even hybrid (stoptech sp) rear pad on the stock caliper is more than most will need. Been a great setup for me. Start with this setup and upgrade the rear if you find insufficient.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
