BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > N52 Rough Idle / Performance Issues
      07-12-2016, 07:58 AM   #67
inthehat
Drives: E92 325i SE Black
Hello All
same problem here 325i n52 2006 been living with it for a while now
car hesitates on acceleration and jerks when off the throttle unfortunately no error codes ever so garages say nothing wrong!!!
done so far
cleaned the solenoids and bench tested no improvement
replaced Vanos motor no improvement
revised Throttle Pedal and sensor from Newer model
I'm looking for more ideas before checking built in PCV valve. found you can buy the part rather than replace entre valve cover. Ebay 172189766625.
I get a puff of oil every now and then so wonder if related. anyone inspected theirs?
Last edited by inthehat; 07-14-2016 at 04:16 AM.. Reason: forgot extra replacement
      07-12-2016, 11:08 AM   #68
ZeroSum
ZeroSum's Avatar
31
Drives: E90 328i/MR2
Originally Posted by inthehat View Post
Hello All
done so far
This is what mine is doing
2008 Monaco Blue 328i Sedan / Charcoal Delete / K&N Drop In Filter / RM Intake Boot / AA Tune
1993 MR2
      07-16-2016, 03:09 PM   #69
alx.
alx.'s Avatar
41
Drives: F30 320iA M Sport
2006 e90 325i  [0.00]
This is weird, i have a MAF code thrown even though the CEL doesn't pop.
The maf is brand new from an e-bay seller, came in a brand new box VDO siemens, what gives? I shouldn't get an error thrown with a new maf.
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold
Bmw 3-er e90 325i '06 - Sold
Bmw 3-er e92 325xi '08 - Sold
      07-16-2016, 05:51 PM   #70
Three_thirty_I
Three_thirty_I's Avatar
South Africa
200
Drives: '05 E90 330i Manual
That is weird!! And you are using a normal paper air filter, not an oiled filter?
BMW E90 330i (M) '05 (His) | (Hers) BMW E46 320i f/l (M) '03
      07-16-2016, 10:18 PM   #71
tdavis42
tdavis42's Avatar
181
Drives: 08 E90 328i ZSP AT
2008 328i  [0.00]
Double check connections.
      07-17-2016, 01:56 PM   #72
alx.
alx.'s Avatar
41
Normal, i messaged the guys who sold me the maf and they said i can send it back but they are sure it's in perfect working condition. It was new after all. They mentioned to check 02 sensors and throttle body position sensor? I was aware the n52 didn't have a throttle body position sensor.
Will do, i forgot to mention even though i am 99% sure it has nothing to with it my intake boot that goes into the air filter box is broken so it doesn't connect with the filter box very well, picture below:
Where he pries it out in the picture mine is torn so it doesn't connect well with it, could that lead to a vacuum leak?
      07-17-2016, 06:12 PM   #73
jan31
jan31's Avatar
Drives: 2014 F32 428I Xdrive (N26)
To update everyone on the parts changed to fix the issue:
Coils - slight improvement, jerk/shake still there
Plugs - no improvement
Injectors - Slightly better start-up, minor improvement
Solenoids - fixed errors, slightly better in regards to the shake but still present
MAF - fixed jerks, misses in acceleration and shifting.
Overall i am happy the car is a beast again, thanks to everyone who contributed here.
Did you replaced the MAF or just cleaned?
      07-17-2016, 09:59 PM   #74
Three_thirty_I
South Africa
200
There's no problem it that part of the intake is damaged or leaking, it's from the MAF sensor to the intake manifold that cannot have any vacuum leaks, so after the air filter where the MAF is located, anything before that it not going to cause any issues since that is not yet measured.
      07-18-2016, 07:25 AM   #75
alx.
alx.'s Avatar
41
Replaced with brand new siemens VDO
I understand, i just reset the throttle adaptations using the steps here and it seems to run better(i wonder for how long). Also unplugged and plugged the maf back in
Car feels like a monster again, i doubt it's going to last long though.
      07-18-2016, 08:03 AM   #76
ZeroSum
ZeroSum's Avatar
31
Mine doesnt connect very well either. I wonder if its getting something like heatsoaked due to the leak....
1993 MR2
      07-18-2016, 12:40 PM   #77
alx.
alx.'s Avatar
41
To be fair i doubt it has anything to do with it. What have you changed so far? Is it throwing any codes?
      07-18-2016, 01:22 PM   #78
Three_thirty_I
South Africa
200
I must say, I have wondered about the possibility of heatsoak affecting the MAF, the air box gets really hot if the car is standing still, or has stood for a while. But, considering how much air gets breathed in when the engine is making power, chances are that it's not as bad as one would think.
      07-18-2016, 01:50 PM   #79
ZeroSum
ZeroSum's Avatar
31
No codes....New plugs, and coils, vcg and vc, cleaned the vanos and the maf.
1993 MR2
      07-21-2016, 05:34 AM   #80
alx.
alx.'s Avatar
41
Have you also checked the Eccentric shaft sensor for any oil residue? Also, i would recommend replacing the solenoids instead of cleaning them, they're pretty cheap.
      07-21-2016, 11:34 AM   #81
ZeroSum
ZeroSum's Avatar
31
I have been trying to stay away from the ESS.
1993 MR2
      07-28-2016, 03:29 PM   #82
alx.
alx.'s Avatar
41
Try taking it out, it's a 5 minute job to just unplug it and inspect for oil inside of the connector or the plug, if so you can either clean it with some compressed air/cotton swabs but you will need to replace the gasket. The ESS itself is pretty expensive.
      08-01-2016, 03:21 AM   #83
alx.
alx.'s Avatar
41
Rceived an airmass code....the MAF is brand new but at least we're getting somewhere.
What else could cause an airmass error? I also changed the two o2 sensors PRE-cat, should i also change the post cat ones? DISA valve?
      08-15-2016, 01:51 PM   #84
SSJTrunks523
Drives: '07 328xic '11.0 M3 DCT
Any solution to this? My N52B30 is doing pretty much exactly what you are describing. I have semi-given up on it being a vehicle that I can trust, and was assuming the motor was going (along with a whole 'nother list I don't want to get into), but if you get some luck, I'd love to know what happened!
2011.0 E92 M3 M-DCT ZCP ZTP ZPP Black Wrapped Jerez Black + 2007 E92 328xic 6MT
2007 YZF-R6 + 2001 Honda Shadow ACE
1989 RS Camaro - HO 350, Dynomax headers, flowmaster AT exhaust, 4.56 gears
2015 STI Launch Edition
      08-15-2016, 03:44 PM   #85
ZeroSum
ZeroSum's Avatar
31
Any update?
1993 MR2
      08-15-2016, 10:16 PM   #86
stewey
71
Drives: 2006 325i 6MT
I'm still trying to chase mine down. So far: ESS, plugs, coils, cleaned solenoids and check valves. No codes to speak of except for one MAF code 2000km ago, so I just ordered a new MAF.
If the MAF doesn't fix it I'll be taking it to the dealer or an indy.
      08-16-2016, 07:20 AM   #87
alx.
alx.'s Avatar
41
I've taken it to four different mechanics, the last one said it's an internal issue with the engine perhaps vanis/valvetronic. I'm pretty much considering selling the car as there are no good mechanics in Romania for Valvetronic or Vanos, everyone here has a diesel...pretty much given up hope
      08-16-2016, 03:35 PM   #88
alx.
alx.'s Avatar
41
Would the ECC cause 2D06 - Air Mass System? It had little to no oil when i checked it and i did change the gasket/ clean the connector and sensor with contact cleaner.
