      04-02-2017, 05:23 AM   #67
FLYN55
Drives: Rx7
https://m.facebook.com/story.php?sto...29267523757328
      04-02-2017, 05:29 AM   #68
FLYN55
Drives: Rx7
Originally Posted by martymil View Post
They don't make one for our cars
Yes they do I found it on their web page
      04-02-2017, 05:29 AM   #69
martymil
Australia
389
Drives: Garage is to big to list.
Yeah that was a one off and it wasn't made by plazmaman, it was one of their cores that Greg had fitted to a 135i
It was a terrible fitment, the bumper bar was all chopped so where the grills
      04-02-2017, 11:06 AM   #70
hot-j
98
Drives: 1M
Originally Posted by FLYN55 View Post
Hi Budd would you sell er charge pipe separate
Sold already....
      04-07-2017, 06:00 AM   #71
FLYN55
Drives: Rx7
Originally Posted by hot-j View Post
Sold already....
Dam lol. Thanks for replying back
      04-11-2017, 10:48 PM   #72
balloonsalesman
balloonsalesman's Avatar
48
Drives: 2011 1M BSM
The Wagner evo comp 2 preformed flawlessly at my last track day, temps never exceeded 100 f
The ic is the best you can get in terms of cooling in the stock location but in summer it does struggle
These cars where never designed to run the power we are getting out of these cars in the Australian heat
I'm looking into upgrading to the jd75/advan big Ic
Seen the results and they where very impressive
But jd75 will have to step in and let you guys know the results
Look at it this way you will never need to upgrade the Ic ever again on these cars
Wondering what your thoughts on the Wagner Evo 1 Performance are? its bar and plate, and uses the stock connections. Is it worth it? (No trimming, no cutting hoses.)
Or is the evo 2 competition with plumbing really the way to go?
      04-11-2017, 10:56 PM   #73
martymil
Australia
389
Unless your going to run stock boost don't waste your money
get a Evo comp 2 unless your going to upgrade your turbos then you going to need something bigger
      04-11-2017, 11:09 PM   #74
balloonsalesman
48
Drives: 2011 1M BSM
thanks for feedback. already running more boost with stock intercooler. time to upgrade
      04-12-2017, 08:49 AM   #75
HawkeyeGeoff
HawkeyeGeoff's Avatar
Drives: E90 335XI MSport, S2000
for when you want to block your WHOLE radiatior
      04-14-2017, 08:13 PM   #76
T1M
Australia
196
Drives: AW MY12 1M
You will still need to trim the lower air guide and a rib on the undertray to make the Performance 1 fit. Anyone who tells you otherwise hasn't fitted one themselves.
The Competition 2 Evo needs the rad support cut and also the lower guide/undertray rib cut. It's a bit of hack job on a 1M to do that. You can avoid the radiator support cutting if you space the cooler rearwards with custom brackets, but it's not a great fit.
Logs from a guy running a tune (20 peak/14 ish taper) on the performance 1 show peak intake temps of about 50*C after pulling through 1-2-3-4 and before 4th they aren't really moving much over 30. It seems fine for stock turbos running no more than 1 bar of boost at redline.
      04-14-2017, 08:36 PM   #77
martymil
Australia
389
With the evo comp 2 there is no bumper bar cutting at all, if you ever had the front end completely off the radiator support is separate to the front apron as the radiator sits on steel brackets and is held in place with two rubber grommet screws from the top, the only trimming you do is to the apron
I have fitted a number of these and the only mod you might have to do to the rib is using a heat gun to warm up and push it up if it hangs to low.
Cutting is for butchers
You have to relocate the front temp sensor cut the plastic that held it in place and trim the air guide or leave it out
Its quite involved to do it correctly but by no means a hack job if done right.
Great IC for stock turbos but struggles with upgraded ones or in high ambient temps.
      04-14-2017, 09:13 PM   #78
T1M
Australia
196
Drives: AW MY12 1M
I meant radiator support, not bumper support (I said it right once and wrong once).
Do you have pics of exactly what you cut?
      04-14-2017, 09:14 PM   #79
martymil
Australia
389
I'll be doing one next week or so I'll post up exactly what has to be cut with detailed pics
Radiator support doesn't get cut either your mistaking the apron for radiator support.
The radiator sits on two metal support brackets.
its all good, common mistake
      04-14-2017, 09:32 PM   #80
martymil
Australia
389
The bottom of this apron is the only part you cut and the sensor hole as it sits to low
      04-14-2017, 09:50 PM   #81
T1M
Australia
196
Drives: AW MY12 1M
So just cut here only? Does the undertray still fit neatly without bulging down?
      04-14-2017, 09:58 PM   #82
martymil
Australia
389
If you pull the bumper off it can be done neatly.
Install the tray and bolt it up, it will hang a bit low.
Leave the front three screws loose of the tray that bolt up to the rib
Now get a heat gun and heat the support rib but be careful not to heat up the bar and using a rag so you don't burn yourself push up to flatten the rib a bit
      04-14-2017, 10:02 PM   #83
martymil
Australia
389
Where I drawn around the sensor hole only cut the part underneath that hangs low
You see what I mean when you get to it
      04-15-2017, 08:54 AM   #84
balloonsalesman
48
Drives: 2011 1M BSM
So after mentioning that the Wagner Perf 1 does in fact require trimming, are there any IC's that do not require any trimming or cutting?
I'm not so keen on messing around with that on this car, too special to me, even if its hidden away behind the bumper and unnoticeable.
      04-15-2017, 08:56 AM   #85
martymil
Australia
389
A replacement apron is only 300 dollars I wouldn't worry about cutting it
It can be replaced in about an 1 hr
      04-15-2017, 05:27 PM   #86
martymil
Australia
389
There is no FMIC worth mentioning if your not going to cut, might as well stick with the stock unit
here is the only part you need to cut and its easily replaced
https://www.ecstuning.com/b-genuine-...t/51647193193/
      04-15-2017, 05:47 PM   #87
ShocknAwe
1Addict
ShocknAwe's Avatar
3243
Drives: E82 Mutt, M57 Truck
Contact for the JD75 intercooler?
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      04-15-2017, 05:49 PM   #88
martymil
Australia
389
His name is jd75 on these fourms
