11-09-2016, 06:29 PM | #67 |
459
Rep 234
final stage : Diagonal strut and stiffening plate
Here is the final stage : installing diagonal strut and stiffening plate. These parts were used for reinforcement of 4 series convertible body stiffness. When you can see 4 series convertible, there are 1 more V shape strut in front of intercooler intake. This V shape strut bridged to bottom torsion strut by stiffening plate. Total cost is $150.
It's not difficult work but just removing your front bumper and screw it. After installing this parts, drove a little ... It's like a E90 3 series body feeling. If you ever feel the car is not unstable, even when you drive strait on common express way, this work definitely can help the situation. So, All of previous struts seems to be properly worked with these parts. It's the last puzzle piece for E90 body feeling !! Last edited by Steve_Jr; 11-09-2016 at 06:37 PM.. |
dotjonnL19.50 |
11-09-2016, 08:40 PM | #68 |
20
Rep 159
Wonder if this will work on the sedan and xDrives...
Does the bottom of our cars come with the aluminum diagonal pieces behind the new brace? And does the plastic belly pan cover all this? I haven't had the chance to peak under my car yet. Last edited by dotjonnL; 11-10-2016 at 12:17 AM.. |
11-10-2016, 12:22 AM | #69 |
Rep 1,296
Thanks Steve_Jr!
Will try to do this next week as we have a slot in the workshop to install the LSD and rear stiffening plate, if we can get the parts by then. We skipped the two pairs of strengthening rods (extension struts tower + links), not being convinced of the benefit if these can't be screwed on to he body. |
11-10-2016, 12:35 AM | #70 |
Rep 1,296
http://www.realoem.com/bmw/enUS/show...diagId=51_8381
These are parts 18 "Structural reinforcement panel" (F33 only), 16 "Torsion bar, front" (F32 F33 only) So for Sedans you need a pair of "Torsion bar, front" 18 too, coupés only need the reinforcement panel. http://www.realoem.com/bmw/enUS/show...diagId=51_8380 black V is part 16 "Diagonal brace, lower" here (ref 51647294929) + 17 "adapter plate" that are specific to convertibles.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
11-10-2016, 12:48 AM | #71 |
20
Rep 159
Hmm I tried looking for it on the F33 435iX and it doesn't show up but for the non-xDrive it does.
I'm gonna assume the reinforcement plate will not work with xDrive models? Did some more digging, the part is available for the F23 M240iX, do you guys think it'll work on F3x? Last edited by dotjonnL; 11-10-2016 at 01:07 AM.. |
11-10-2016, 06:42 AM | #73 |
459
Rep 234
Hey Lancelot
I found bracket strut bridged into A-pillar ... It must be welded .. Any idea ? Parts no.6 below page : http://www.etkbmw.com/bmw/KO/search/...CE/41/41_2251/ |
11-11-2016, 08:03 AM | #75 |
459
Rep 234
Today I ordered parts no.6 : A pillar bracket .. Let see ...
11-12-2016, 09:23 AM | #76 | |
Rep 1,120
Drives: 2022 M8cs
11-12-2016, 11:52 AM | #77 |
Rep 1,296
If it's not welded it would be good news; and it's not bolted, we have no corresponding holes in the area afaik.
But if neither welded nor bolted, where would be the strengthening effect? |
11-12-2016, 12:49 PM | #78 |
Rep 1,120
Drives: 2022 M8cs
Sitting it as is, is absolutely useless. I guess we wait to see what Steve says when he receives the part.
11-15-2016, 03:09 AM | #79 |
459
Rep 234
Bcz there's a plenty of gap between the edge of strut and A-pillar. Now only rubber bushing bridged these two, so even no bolting this part on A-pillar, it looks effective to be strengthen up.
11-15-2016, 03:11 AM | #80 | |
459
Rep 234
Let's see the part first when it arrived ^^
11-15-2016, 11:39 AM | #81 |
Rep 1,296
Thanks for leading the way on this excellent upgrade.
Together with this other thread on the rear axle we have superb solutions http://f30.bimmerpost.com/forums/sho....php?t=1080995 |
11-16-2016, 07:53 AM | #82 | |
459
Rep 234
You know what .. I already tried to install this kind of stuff ... with genuine M4 parts only $20. But now this were removed.
In a case of 4 series coupe which has V style tension strut (33316797444) Additional stuff seems useless or even weaken its stiffness. Bcz 1. without this stuff (CPM or Genuine M4's one) , tension strength can be effectively, directly diffused through : each bridge -> core of V tension strut -> body itself 2. with this stuff (CPM or Genuine M4's one) , tension strength can be indirectly diffused through : each bridge -> core of V tension strut -> CPM or Genuine M4's one -> body. this means CPM or Genuine M4's one affected opposite direction. It worked like buffer or cushion ... Quote:
11-17-2016, 01:23 AM | #84 |
Rep 1,120
Drives: 2022 M8cs
How can it be effective to 'strengthen up' if it is not bolted to the frame? Sorry, it's just not clear
11-18-2016, 08:56 AM | #86 |
64
Rep 308
Long shot but does anyone know if it would be possible to fit just the alloy brace without changing the suspension guide supports? Even if a little bit of modification is needed on the alloy strut itself.
Anyone? |
11-19-2016, 12:20 AM | #87 | |
Rep 1,296
But please, don't - this bearing bears 25% of your car weight on its own, weakening it is looking for trouble. Dangerous trouble.
11-19-2016, 02:16 AM | #88 |
Rep 1,120
Drives: 2022 M8cs
Not a chance of any strengthening with that configuration Steve, but at least the rods are in place while something else Is figured out.
