04-13-2017, 08:12 AM | #67 |
98
Rep 149
No sir. Had the shop mount it to the underside of the trunk filler plate. I'm not ready to smell gasoline fumes in my garage.
04-13-2017, 08:29 AM | #68 |
98
Rep 149
Been a while! Dropped the car off at the shop at the beginning of March to get some work done. Part of the list was as follows:
- Swap transmission fluid with supplied Redline D6 - swap differential fluid with supplied Redline 75w90 - swap power steering fluid with supplied pentosin chf - change engine oil with supplied motul synthetic - install supplied Turner Motorsport rear subframe bushings - install supplied revshift transmission bushings - install supplied berk technology midpipes - modify and install hard motorsport rear trunk cover. Fabricate bracket to mount charcoal canister - review and advise condition of fuel filler neck in passenger rear wheel well. Replace? -> Tire rubbed on fuel filler neck and chewed away at it real bad. Didn't cause any spills tho. - blast engine bay with compressed air - fabrication of HVAC blower and AC hard-line block off plates on firewall - Fabrication of center exit axle back center exit exhaust. Exhaust to exit right below structural bumper. To be fabricated high enough to allow for future diffuser. - welding of 2" vertical extensions onto chassis brackets for rear wing uprights. Purpose is to install one more Clevis pin on each side - fabrication of removable block off plate for cowl area Took a stab at making my own front splitter out of 3/4" plywood. It came out decent. Coupled with the ebay front lip /w brake duct openings, it'll tie in nicely. Will post finalized pics when its done. Also had the car corner balanced and weighed. With an empty tank and no driver, it came in at 2937lbs. Not bad!
04-24-2017, 09:59 AM | #69 |
98
Rep 149
Battle ready.
Hoping to complete the shakedown sometime this week. The wrap job on this car is hurting so bad and is accentuated by the fail of the placement of the //M stripes on the hood. But at this point, I'm riding it out for the season as I'm out of wrap and tapped out in patience to redo it. Time to drive!
st-pierre13.50 |
04-26-2017, 12:51 PM | #70 | |
Boost
1355
Rep 3,697
Drives: 135i M-Sport
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
07-30-2017, 05:16 PM | #71 | ||
Boost
1355
Rep 3,697
08-01-2017, 10:15 AM | #72 | |
98
Rep 149
I also fabricated wire splitter stanchions to prevent the splitter from sagging at speed in front of the main brace. The splitter doesn't attach to the plastic bumper at all; its all chassis mounted. I'll try to snap some photos this weekend of the setup.
08-01-2017, 02:33 PM | #73 | ||
Boost
1355
Rep 3,697
Shoot me some pics if you don't mind.
08-02-2017, 08:12 AM | #74 | |
98
Rep 149
Tracking season makes for slow updates! Some noteable things: - Managed a 1:31.28 at Canadian Tire Motorsports park. That's on par with the IMSA Continental Tire ST class; part of their tour comes to my home track. There are large differences in chassis builds but the lap times are similar nonetheless. - Had an off at another local track last Wednesday and ripped the splitter off the chassis mounts. Damaged a radiator support bracket in addition to destroying the splitter. Ended up spending the following days hustling up a new splitter for a time attack event the following Sunday July 31. Some photos: - First one is me taking turn 4 at Canadian Tire Motorsports Park (CTMP) Grand Prix Track flat out at 190KM/h. Entry is WOT. Just after turn in, there is a hump then the track drops around 30 feet while turning left. The rear end gets light and shifts about 6-12" over. As long as you don't lift, the aero keeps the car planted the whole way through. Its pretty wild. - Second photo is at the CTMP Driver Development Track. Its much smaller and slower than the Grand Prix track. This was the Time Attack event; the Subaru behind me is 2 classes higher and ran me down about 3 turns later. Its wicked fast.
st-pierre13.50 |
08-02-2017, 10:44 AM | #75 | ||
Boost
1355
Rep 3,697
Hope the splitter, bumper etc are okay.
08-02-2017, 01:55 PM | #76 |
225
Rep 376
Turn 4 is my favorite.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid |
11-15-2017, 01:42 PM | #77 |
98
Rep 149
Still here!
Season has been over for me since September. Didn't take long for me to tear into it in preparation for 2018. Started off by thinning out the wiring harness some more at the PJB. Went a little too aggressive and now the car cranks for about 3 seconds before firing and the dash lights up like a Christmas tree. Troubleshooting electrical is going to be fun... Put this aside for now. In the mean time, I decided to go hella wide for next year. Enter Apex 19x11 PS7s. I went with 19s as I can only get 305 RE71Rs in 19". This will allow me to still run a street tire in the class I want to compete in next year. I'll be ordering fender flares soon.
st-pierre13.50 |
11-15-2017, 01:45 PM | #78 |
98
Rep 149
Oops. After I posted, I realized I did some other work...
For the sake of aero improvement, I went down to one oil cooler behind the kidney grill. The duct openings on the bumper will be covered off. Hard to say whether this single Setrab unit will keep me from going into limp mode. My hunch says I'll be fine but I'm just firing from the hip at this point.
11-15-2017, 05:34 PM | #79 |
Rep 672
Looking good! What fender flares are you going with? N5tuner rear like the Solo car?
11-15-2017, 07:21 PM | #80 | |
Boost
1355
Rep 3,697
11-16-2017, 03:02 PM | #81 | |
98
Rep 149
I'm working on something. Stay tuned.
11-16-2017, 06:31 PM | #82 | ||
Boost
1355
Rep 3,697
The OEM rear quarters seem like a nice option because they look better and I think you'd gain some resale value back although once the cage is in that's out the window lol
11-16-2017, 06:36 PM | #83 | |
Boost
1355
Rep 3,697
Have you run he car with a single core oil cooler in front of the radiator?
11-17-2017, 03:12 PM | #84 | |
98
Rep 149
Resale value is definitely not a consideration when you're in this deep. Things like "what can I take an angle grinder to for weight reduction" tend to take priority. Ha.
11-17-2017, 06:58 PM | #85 | ||
Boost
1355
Rep 3,697
11-20-2017, 07:49 AM | #87 | |
98
Rep 149
The top was mounted to the rad support (all openings at the top of the rad support were covered off to force air through the radiator) and on the rad shrouding /w 90* aluminum brackets.
11-20-2017, 09:06 AM | #88 | |
707
Rep 2,450
What size lines did you go with? |
