BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Apex ARC-8 agressive fitment
proTUNING Freaks
      02-14-2019, 09:55 AM   #67
daniel.d.tran
Drives: 2013 BMW 335i
Originally Posted by Relax19 View Post
You can do 17's without issue if you have standard brakes. ie, no M Performance brakes.
I'm pretty hyped I just got a set of Arc-8's 18x9.5 et35 to replace my EC-7's 18x9 et31.
Nothing beats a meat flush look with concave wheels.
Yea I love that meat flush look, CONGRATS! Can you send some pics of the set up? Any camber required? I'm on standard brakes so it should work just fine Thanks!
      02-14-2019, 10:27 AM   #68
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
Originally Posted by daniel.d.tran View Post
Would 245/45 work?
Yes, much better!
      02-14-2019, 10:32 AM   #69
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Hey guys quick question... I'm currently running a staggered set of 400m's on 18X8 up front and 18X8.5 in the rear. They are wrapped in 225/45 DWS06's all arounnd (I was running them on my square set of 397's and didn't want to sell them yet).
My question is, can I run spacers on this setup to get a little bit more of an aggressive look? If so, what do you guys recommend?
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
      02-14-2019, 10:54 AM   #70
bmdubbayoo
Drives: LBBM/Aragon F85
19x9 ET20 (245/35s)
19x9.5 ET33 (275/30s)
      02-14-2019, 11:01 AM   #71
daniel.d.tran
Originally Posted by fhlh View Post
Pic?
Here's my fit. 18x9 et42 w 10mmF/12mmR spacers squared
Hey man great fitment! Are you running any cambers on these?
Thanks
      02-14-2019, 11:03 AM   #72
daniel.d.tran
What you're current offset now?
      02-14-2019, 11:21 AM   #73
XxThe_RemedyXx
967
18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 front / 18x8.5" ET47 rear
      02-14-2019, 11:31 AM   #74
XxThe_RemedyXx
967
Oh nice, same as mine (at least for now until I decide on which offset for the APEXes lol). I'm at 10mm front and 15mm rear.
Sweet! Are you running 225/45's all around as well? Do you have any pics?
Edit - I'm dumb.
      02-14-2019, 11:33 AM   #75
daniel.d.tran
https://photos.app.goo.gl/NT3VJZ4sRmTUXGMz5
      02-14-2019, 11:39 AM   #76
XxThe_RemedyXx
967
Look's great, thank you! I think 10mm and 15mm spacers will do it for me with my setup. The only thing I'd change are the rear tires from 225/45 to 255's at some point when the tires need to be changed.
      02-14-2019, 11:56 AM   #77
daniel.d.tran
I'm on OEM staggered 225/45 with 255/40. Good luck and let me see some pics once you ordered.
      02-14-2019, 11:57 AM   #78
XxThe_RemedyXx
967
Awesome. My rear 255's a a tiny bit stretched but not visible if you don't know what you're looking at.
      02-16-2019, 12:01 PM   #79
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
Originally Posted by WillSkill View Post
I plan to get the 18x8.5 et38 Apex Arc-8 in bronze from the recent group buy that opened. I got 235/40-18 MPSS's for the rims. I'm going for a square set-up and I'm wondering if there'll be any rubbing? also do you guys this set-up will sit flush?
I think you can do MPSS 255 with 8.5 from reading some threads. I do 245 RE71R's no issue with 18x8.5 ARC-8
      02-16-2019, 07:35 PM   #80
B58 parts
B58 parts's Avatar
Drives: '17 340ix 6MT
The 255s bulge on 8.5. I am probably going to sell my summer set. I'd really recommend 245 on 8.5. I will get some pics. 245 18x8.5 et38 with a couple spacers looks ok but isn't exactly dialed. I'm trying to calculate what 245 on 18x9 et30 would look like instead. I may even go 19s but probably not. It sucks not being able to try / test fit.
You won't have any rubbing with 235.
      02-27-2019, 04:05 PM   #81
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
Originally Posted by bmdubbayoo View Post
19x9 ET20 (245/35s)
Do you mean 19x8.5 ET20? Or maybe 19x9 ET28? Pretty sure APEX doesn't make a 19x9 +20 ARC-8...
      08-08-2019, 12:06 AM   #82
deuceperformance
Drives: 2015 BMW 335i 6spd
Originally Posted by Celoq23 View Post
My current set up, I love the look of these wheels. Perfect fitment
19x9 ET28 Front / 19x9.5 ET33 Rear
Tires: 235/35/19 Front / 265/30/19 Rear
Does the wheels poke at all? And do you think running 45s instead of 30/35 will still fit? Really looking to get these wheels but I see a lot of posts saying it won’t fit..
      08-09-2019, 08:16 PM   #83
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
Does the wheels poke at all? And do you think running 45s instead of 30/35 will still fit? Really looking to get these wheels but I see a lot of posts saying it won't fit..
These wheels 100% fit, clearly, as many are running them. For whatever reason many people on this forum only think a wheel "fits" if it's a super conservative fit/sunken in wheel well.
At any rate, are you planning to lower your car? If not, then they will poke a couple mm's but will ride perfectly fine depending on tire choice. I personally like an aggressive look so a couple mm of "poke" can look good if lowered and proper tire choice. Then again I'm the type of person that wouldn't buy wheels until lowering the car first.
Regardless, a 45 profile tire is very thick for a 19" wheel, I'd stick with 40 front / 35 rear if you want meaty setup.
Here's mine, pretty much identical but with 8.5 +20 225/40 up front (same "poke" because of +20 offset as 9 +28) and I have plenty of room but I have some natural camber from the coilovers.
[IMG]https://i.ibb.co/xD7cgBB/2-A25-FAA2-...C228-B7667.jpg[/IMG]
      08-10-2019, 12:31 PM   #84
deuceperformance
Yes I’m planning to run coilovers, but damn your car sits sooooo nice! You confirmed for me that I need to get them now haha. Thanks for the info!
      08-23-2019, 09:20 PM   #85
deuceperformance
I’m going to pull the trigger and get some arc8s. Do you think you would have room to run 245/35/19 in front and 265/35/19 in rear or will pull it be a tight fit?
      08-24-2019, 07:14 AM   #86
Alpine-F80
Alpine-F80's Avatar
Drives: 2017 M3
I'm going to pull the trigger and get some arc8s. Do you think you would have room to run 245/35/19 in front and 265/35/19 in rear or will pull it be a tight fit?
So it'll be tight depending on wheel size/offset/tire brand and how low you go. If you plan to go the 9.5" +33 / 9" +28 (or 8.5" +20) you should be OK in the rear, I'm 255/35 and have a decent amount of room.
The front though at that tire width and wheel offset I think you'll rub the bumper tab on big dips/bumps. I shaved part of mine off with a dremel to avoid rubbing on large dips/bumps at my current ride height.
You could always do the less aggressive front wheel offset (19x9 +38) and you should be OK with the wider tire up front, just no concave up front but still looks good with rear concave. I almost went that route myself.
      08-25-2019, 02:12 PM   #87
jmp6t
21
Drives: 2019 M4 ,2021 X3
Since this has been bumped recently Ill toss my question in here as well.
Looking at these wheels for my '15 F36. How wide can I go without any poke in the rear on stock m sport suspension. 18x9 or 18x9.5?
If 18x9.5 would fit what kind of offset would I lookin at?
      08-27-2019, 01:10 PM   #88
Expert@ApexWheels
Expert@ApexWheels's Avatar
3595
Drives: M3
The post below pretty much sums it up:
Although we haven't tested this setup ourselves, it is being used by many and we haven't seen any reports of rubbing. At stock ride height, it may look a bit too aggressive without negative camber dialed in.
If you don't plan on lowering the car, you can use the 18x8.5" ET35 front with 235/45-18 and 18x9" ET30 with 255/40-18 rear for a slightly more conservative fitment.
--Dylan
