      09-21-2018, 08:55 AM   #67
N55darksoul
N55darksoul's Avatar
78
Drives: 2012 - 135i
So is the agreed upon software/app Carly for the 135i? What about the Foxwell NT510?
I cant seem to find anything on the Foxwell webpage confirming the 135i ...
      09-21-2018, 09:40 AM   #68
gjm120
2185
Drives: 2013 128i, 2021 230i
Foxwell NT510 can register a new battery - very easy. It will not code a different type or Ah.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
      09-24-2018, 01:36 PM   #69
dvaz
39
Drives: 2015 E84 X1
Can i use an ENET cable instead of the K+DCAN USB Cable?
I already have an ENET cable that i use with ESYS.
VM link appears to be broken, can someone PM an alternate link?
Thank!
      10-23-2018, 08:45 AM   #70
bNks334
bNks334's Avatar
427
Drives: '11 135i (N55)
Originally Posted by SergeyB View Post
Thank you for valuable information.
I think I have and interesting question that I hope could be answered here.
My original battery type was AGM. Two years ago I replaced a battery at official dealer to the regular one (white case). I ensured that they did the registration. Everything worked fine like engine start.
However I had a feeling of battery under charge which proved itself recently (discharge warning) when I leaved radio on without running engine while cleaning interior and closing/opening the doors perhaps preventing car from entering sleep. This was not too long like about 30 minutes.
I decided to check battery status and discovered that my regular battery is registered as AGM (capacity is the same).
What could be done in this case?
1) Code the correct type in relevant modules (with or without VO)?
2) Code the correct type with higher capacity with registration?
Thank you!
1) yes, you should IDEALLY code the car to see the battery as AGM. AGM will most likely have slightly different charging profile which might help keep it charged better. You probably won't notice anything different though.
2) registration and coding are two completely different things. registering a battery tells the car a NEW battery is installed. Coding for the correct capacity (Amp Hours) has to do with how big the battery is. Is it 80AH or 110AH? 110AH will last longer with the car off and the door open. Our cars pull a lot of amps to run the various computers, radio, fans, lights, etc. 30 minutes with the car door open can easily discharge a battery. IF the car has a 100AH battery, but it's only coded for 80AH, you may never be getting the correct charge on it.
      10-23-2018, 11:10 AM   #71
gjm120
2185
After reading SergeyB'a post I think he has had a non-AGM in a car coded for AGM for 2 years.
Probably should code for the correct Ah and type now. What about registration? Should he register it now which will have the car charging it like a new battery, but, as he mentioned it's already getting a little weak?
      10-24-2018, 06:58 AM   #72
bbnks2
1213
Drives: 135i N55
No, you don't re-register an old battery. Coding changes don't require telling the car you bought a new battery...
      11-21-2018, 03:40 AM   #73
simp15d
Drives: 2013 135i LCI e82 N55
Question K DCan Not registering
I need help,
I have a 09/2013 135 e82 N55 DCT MSport Australian/Euro Spec whichmean I have DME MEVD1726. I've installed INPA, and all the software you can thing of for BMW but its seems as it's not registering my KDCan? is that because I need to flash the DME first before I can access the coding etc..? or did I just nstall by KDCAn driver incorrectly?
any direction or advice would be great as I also bought a OBDII bluetooth and that seems to read some ECU but not all.
thanks in advance if anyone can guide me... as i"m a NOOB
      11-21-2018, 09:45 AM   #74
gjm120
2185
Originally Posted by simp15d View Post
I need help,
Is your port and latency set correctly? Should be com1 and latency of 1. And depending on what std tools package you loaded, you may have to go in and set the interface to obd.
      12-02-2018, 11:18 PM   #75
simp15d
Hi GJM120,
Yes, I have set all those as per attached;
      12-03-2018, 01:04 PM   #76
gjm120
2185
Hi GJM120,
That looks correct.
You shouldn't have to flash any modules to connect with INPA or NCSExpert. Are you saying if you connect to the car and open INPA, the car isn't connecting?
If so, You probably have a driver issue or else a bad install of the software. I don't know if this valid for all, but, I had trouble connecting to my car until I disabled internet and my antivirus.
      12-07-2018, 01:45 AM   #77
simp15d
Hi GJM120,
thanks heaps, I may have all two cases; Driver, software install
I will try to switch off the internet and antivirus;
thanks heaps,
Now that I know I don't need to flash to use INPA and the other software I will exhaust all avenue to trouble shoot the software and recover my laptop and start new. If it's successful then I will start reviewing all the programming etc.. starting with installing the reverse camera.
thanks once again.
Cheers,
Daniel
      12-08-2018, 10:03 AM   #78
gjm120
2185
Hi GJM120,
thanks heaps,
thanks once again.
Cheers,
Daniel
Good luck. I haven't done it, but, there have been quite a few reverse camera installs on the forums so you should be able to find some guidance.
The install is finicky to say the least. Also, a bad cable can cause it not to work properly. I have the Bimmergeeks std tools package and using their cable. Oddly enough I have more difficulty with INPA than NCS Expert. That may be only due to the fact that so much of INPA is in German (which I don't speak).
And don't forget to turn your antivirus back on when reconnecting to the internet.
      03-06-2019, 07:52 PM   #79
tree233
15
Drives: 2006 130i hotrod
I ended up using Carly to code my battery again. Even though the lowest setting I found in the CAS module was 80ah AGM, Carly provided a 36ah AGM option. After using Carly to code my new battery, INPA does indeed confirm (see appendix D) the charging system is using a 36ah AGM charging map, or at least INPA recognizes that’s what Carly set it to.
Hi bNks334 , thanks for the great DIY!
I'm hoping to code the 36ah option without needing to buy Carly.
Are you able to share what value Carly put in the CAS module?
And did it update the VO? If so can you please confirm what the VO code is?
Thanks in advance!
      03-23-2019, 12:41 PM   #80
imodipods
Drives: BMW 135i
I was planning to pick up this Bosch battery from Pep Boys.
HTML Code:
https://www.pepboys.com/bosch-premium-battery/product/672418/2012/BMW/135%20Series/6-2979%203.0L%20DOHC?quantity=1
It says on the site that the capacity is 107 Ah, so I'm guessing I should code to 110 Ah. But it doesn't look like there's a 110Ah profile in the VO (Option 5). Should I just code it to 90Ah?
Thanks!
      04-23-2019, 03:34 PM   #81
crowtrobot
366
Drives: 2008 M3
Thanks in advance!
Wondering the same. I just purchased an Optima D35 which is 48aH. It looks like there may be a BATT_AGM_40AH VO option, but I wanted to know if anyone has tried this before doing it myself. I may just suck it up and buy a Carly license to take care of it...
      09-03-2019, 08:54 PM   #82
Erik-AA
19
Drives: 2018 BMW i3s rex
I replaced my battery and tried to reset it using a Foxwell NT510 scan tool. It did not work. Can anybody help me? here are some details:
- The tool works fine for other things like reading codes and resetting CBS.
- It goes through the process fine, then fails at the last step, with a message like "could not write to DME"
- It gives a help screen that suggests the problem might be "engine running" or "terminal 15 not on". But I've tried it with the engine running and not running.
- Mine is a stick shift car. When I put the key fob in, the windows and most things work, but a few things like the accessory port (was "cigarette lighter") do not. Does this mean terminal 15 is on or off? If off, how do I turn it on without starting the engine?
Thanks for any help you can give me!
      10-17-2019, 08:42 AM   #83
bNks334
bNks334's Avatar
427
Bump - updated the OP. I had some missing coding steps.
houtan707.00
      10-17-2019, 10:48 AM   #84
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Just a heads up, the *********** link is not working after the required text is deleted: https://spool [DELETE THIS] street.com/forums/resources/bmw-coding-guide-setup.13/
      10-17-2019, 11:35 AM   #85
bNks334
bNks334's Avatar
427
thank you. I would hope people can google it though lol. The links are constantly changing as is the virtual machine setup.
      10-17-2019, 11:47 AM   #86
Dackelone
European Editor
Dackelone's Avatar
Germany
10637
Drives: N54 e82
Just a side note... many apps like Carly can also code for a new or different battery. Just FYI guys.
      10-17-2019, 12:58 PM   #87
bNks334
bNks334's Avatar
427
Yes, Carly has expanded their capabilities quite a bit since Protool came out and gave them some competition. I still like the idea of messing with NCSEXpert and WinKFP. Gives you a much better idea of how all this works than just clicking buttons in protool that you don't understand.
      10-17-2019, 01:05 PM   #88
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
agree. it also doesn't hurt that NCSEXpert and WinKFP are free
agm, battery, code, register, replacement
