BMW M3 Forum (E90 E92)
  TireRack
      02-19-2019, 08:33 AM   #67
l2iceman
25
Drives: e90 M3
I did read your post, so I understand what you're saying regarding the fronts at a 13 offset with 9.5, I'd be ok with Deep concave in the front, so a 9.5 + 22 seems to be popular, I'm going to see if a higher offset clears everything (like +25).
For the rears, I calculated 19x11 +30, which is close to your 33 offset. Looks like 30-33 offset should be fine in the rears in SDC.
      02-19-2019, 12:05 PM   #68
Iyzmi
Drives: E92 M3 6MT ESS625
Yep, if you're willing to drop to deep concave for the fronts then you can go to a +22.
I personally think SDC all around looks much better and wouldn't have even considered F14s if I couldn't do all SDC. These wheels lose almost all of their aesthetic appeal to me without the concavity.
      02-19-2019, 12:19 PM   #69
l2iceman
25
Drives: e90 M3
Yea but I had semi concave on my 370z fronts, as long as I have SDC rears, I don't mind deep in the fronts.
I wonder if 9.5+27 would be ok as well, it'll sit 5mm closer to the suspension. I just really hate a poked lookand want to minimize that lol
I'll do 19x11 +30-33 in the rears.
      02-19-2019, 12:21 PM   #70
Iyzmi
Forgestar will tell you what will/will not work when you go to place your order. Ask them about 9.5 +27 if that's what you want to go with.
      02-19-2019, 12:26 PM   #71
l2iceman
25
Drives: e90 M3
Ah ok, wasn't sure how well they knew each vehicle specifically, thanks!
      02-19-2019, 12:36 PM   #72
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
Square 19x10 et 20 SDC
Staggered 19x10 et 20 and 19x11 et 27
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      02-19-2019, 12:48 PM   #73
Iyzmi
Yeah, they're quite familiar with the E90 platform. I originally ordered 9.5 +22 SDC and they shot me down with the brake clearance issue.
Also note that a 11 +33 will have the same outer position as a 10 +20 so if you're looking at pics of 19x10 +20 square like the ones posted above, the rear will look the same as 11 +33.
      02-19-2019, 01:06 PM   #74
l2iceman
25
Drives: e90 M3
The above are coupes, so not sure how different the fitment would be, if at all, but it does look good!
I'll give forgestar a call on 19x9.5 deep concave for the fronts.
      02-19-2019, 01:08 PM   #75
Iyzmi
Not at all different.
      02-19-2019, 01:11 PM   #76
l2iceman
25
Drives: e90 M3
Oh perfect! I rear several posts saying the e90 had more clearance, so I got confused. Now I understand why there aewnt specific e90 fitment threads.
      02-19-2019, 01:11 PM   #77
kevin @ eas
Drives: 2015 BMW M4
Forgestar normally goes with a 19x9.5 et 13 if looking to go with a SDC 19x9.5
      02-19-2019, 01:13 PM   #78
l2iceman
25
Drives: e90 M3
Thanks Kevin, how about deep concave for the front in 9.5 width? Would +25 to 27 clear on the f14s, with 245 to 265 width tires?
As I mentioned above, a 27 offset would have the same outer clearance as the oem 220m wheels with a 15mm spacer in 245 width tires.
      02-19-2019, 01:31 PM   #79
kevin @ eas
Drives: 2015 BMW M4
Deep is no problem its only the super deep where you have to run a low offset. Deep has no issues with brake clearance.
      02-19-2019, 01:35 PM   #80
l2iceman
25
Drives: e90 M3
Perfect thanks everyone! Just have to decide on the colour now!
      03-06-2019, 04:29 AM   #81
m3gang
23
Drives: BMW E92 M3
A few shots of my newly installed F14s in semi-gloss gunmetal.
19x10 +20 SDC 275/30/19 PS4S
19x11 +33 SDC 305/30/19 PS4S
Is this on stock suspension? Is there any rubbing?
      03-06-2019, 04:32 AM   #82
m3gang
23
Drives: BMW E92 M3
Any of these on stock suspension or eibach lowering springs?
      03-06-2019, 10:58 AM   #83
Iyzmi
Stock suspension.
Minor rubbing at full lock up front due to my ESS intake pipe pushing up against the fender liner. Many others have reported no rubbing without this.
The rear has some very minor scuffing on the inside of the fender liner. It's so light that I didn't even notice until my tech pointed it out while swapping wheels for me.
      03-06-2019, 03:04 PM   #84
u2usual
u2usual's Avatar
60
Drives: E46 M3 & F80 M3
[IMG][/IMG]
265/30/19 and 295/30/19 PSS here.
19X10F and 19X11R
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
      03-06-2019, 03:44 PM   #85
Iyzmi
Originally Posted by u2usual View Post
[IMG][/IMG]
19X10F and 19X11R
No center caps?
      03-06-2019, 04:07 PM   #86
u2usual
u2usual's Avatar
60
[IMG][/IMG]
19X10F and 19X11R
No center caps?
They forgot to send them, should have them in a couple of days.
Romans 3:23
2002 BMW M3 Racecar
2017 BMW M3 F80
      03-18-2019, 09:15 PM   #87
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
I love my Forgestars, but their center cap design is the worst I've ever seen. They use a cheap rubber o-ring instead of clips (or an o-ring that's actually designed to handle any kind of heat). I've gone through 2 sets so far, stopped even caring, just run without them now.
      04-21-2019, 08:51 PM   #88
iAjking
iAjking's Avatar
Drives: E93 M3
Originally Posted by E92_TYLER View Post
The only reason i clicked on this thread lmao
Me too lol.. TOMCAT'S are IN THE AIR!
m3post
