11-12-2018, 12:12 PM | #67 | ||
¯\_(ツ)_/¯
537
Rep 1,000
11-17-2018, 02:57 PM | #70 |
Rep 472
Hey has anyone had any issues with the reverse lights not working on the Depo LCI tail lights? I've had these installed for a week and just realized that my reverse lights don't turn on when in reverse! I contacted USR, but I'm hoping someone had a quick fix for this. Maybe switching the wiring harnesses?
11-18-2018, 02:06 AM | #71 | |
#gotboost
517
Rep 861
rcaso26331.00 |
11-19-2018, 11:25 AM | #74 |
#gotboost
517
Rep 861
NP buddy. I did the same thing when I had the IKON blacklines (their harnesses weren't labeled L or R)
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
11-27-2018, 11:57 AM | #75 |
Rep 31
Wire Tap
Instead of tapping the OEM plug cables, I tapped the green white wire going in the headlight assembly after the bricks . the tap wire was also green white and it worked
01-16-2019, 09:55 PM | #76 |
Masterchief
373
Rep 1,031
Any update on condensation for your depo taillights?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
01-16-2019, 10:10 PM | #77 | |
9
Rep 29
So the condensation went away. BUT WAIT. The condensation does come back every time there is a drastic temperature change. For example if it's 20 degrees in the morning and 60 degrees in the afternoon, there will be a large amount of condensation on the inside. But thankfully it does go away after a day or two. It's also possible that I'm the only one with this issue. But I would say that if you live in an area with a steady daily temperature you should have absolutely no problem. And even if you don't, the condensation goes away naturally, it just takes a day or two and it's no big deal at all. So far. Other than that I love the tail lights and couldn't be more pleased.
2013 F30 328i N20 | Alpine White | OEM 437M | BCRacing Coilovers | Muffler Delete | DEPO Headlights | Blackline Tail Lights | Debadged | F80 Style CF Mirrors | M-Sport Front |
01-16-2019, 10:33 PM | #78 | ||
Masterchief
373
Rep 1,031
Do you think it's due to poor quality and seals that hold the tail light together that causes it?
01-17-2019, 10:54 AM | #79 | |
Masterchief
373
Rep 1,031
01-17-2019, 12:27 PM | #80 | ||
Rep 472
yoon_209372.50 |
01-17-2019, 01:07 PM | #81 |
#gotboost
517
Rep 861
Lots of rain this week....no condensation!
Also using pre-LCI drip trays....no issues
yoon_209372.50 |
01-17-2019, 01:18 PM | #82 | |||
9
Rep 29
01-22-2019, 05:49 AM | #83 |
Rep 3
hi guys, i just spent the last 4 hours figuring out why both my turn signals and reverse lights are showing red instead of amber for signals and white for reverse. every other thing worked fine.
just got my depos from ebay. followed the step by step installation guide and still clueless on rectifying this. does anyone here have the wiring diagram of sorts? i connected the black and white wire from my car to the depos as instructed but signals and reverse lights still showing red can someone please help!!! thank u |
01-22-2019, 12:24 PM | #84 |
967
Rep 2,664
Installed these a few weeks ago and they've been pretty solid. No issues so far. I've been using the Pre-LCI drip trays as well. Using the posi-taps makes wiring super simple.
I also installed the LED reverse lights which make a tremendous difference.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
rcaso26331.00 |
01-22-2019, 12:30 PM | #85 | |
967
Rep 2,664
01-22-2019, 01:25 PM | #86 | |
Rep 472
01-22-2019, 05:43 PM | #87 |
Rep 3
01-22-2019, 06:04 PM | #88 |
Rep 3
update:
i just emailed fishcake on his depos and realized the ones i bought only came with the red led turn signals! now ill have to change them bulbs does anyone know what led bulbs are for the depos turn signals? i figured that the reverse bulb is H21W. is it safe to open up the depos for bulb changes??? |
