BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can the oil thermostat cover gasket be purchased?
      02-17-2022, 01:20 PM   #67
E90lmao
28
Drives: 2001 e46 325i, 2008 e90 335i
Originally Posted by feuer View Post
Originally Posted by jadams161 View Post
Malo industries sells them too Fast shipping from Canada. The crank seal plate is amazing too.
Very nice! https://www.maloindustries.com/
I just ordered one I'll see how it works out! I'll update this post when I get it installed.
feuer4285.00
      02-20-2022, 03:08 PM   #68
david in germany
Drives: 118i, 335i and 328i
If anyone is interested. The difference between the felpro version and the o-ring.
https://www.reddit.com/r/E90/comment...&utm_term=link
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      02-21-2022, 07:50 AM   #69
mj6234
34
Drives: E92 335i
The one in the reddit post is only rated up to 100*C. I wouldnt use that for this application as we all know our oil runs over that. Seems like viton would be a much better material choice.
https://www.amazon.com/Mr-Ring-3X37-...18&sr=8-3&th=1
I would guess this standard o-ring would work as well.
https://www.amazon.com/220-Viton-Rin...ustrial&sr=1-1
Biginboca3786.50
      02-21-2022, 02:49 PM   #70
IllSic_Design
IllSic_Design's Avatar
2125
Drives: 12 E92 328i
you def want to use Viton o-rings on these cars
      02-27-2022, 01:00 PM   #71
david in germany
Yep, one week and it is already weeping.
      03-02-2022, 08:30 AM   #72
soulcrusher
Drives: BMW 335i
How'd it go? Is it just one seal?
Oh. 10$ shipping
      03-02-2022, 08:41 AM   #73
soulcrusher
Drives: BMW 335i
thanks for the posts!
      03-20-2022, 01:06 PM   #74
arnas
Lithuania
Drives: BMW 435xi F33
Hi guys,
I am also facing oil thermostat gasket leak and was doing some research on the internet. I found this post which was very helpful. So I started to look for Viton 43mm x 3mm o'ring. I was able to found that BMW make this o'ring as replacement part for K series motorcycles water pump I guess.
Replacement part is called "O-RING 43X3-N-FPM 85" and OEM part number is 07 11 9 905 382.
So I will try to order it at my local BMW dealer and hope that it will fit. I will update how it goes after installation.
Also, maybe anyone know if this gasket is the same for F series chassis?
      03-21-2022, 12:43 PM   #75
soulcrusher
Drives: BMW 335i
These viton o-rings are backordered. Have been backordered for a long period now, extending to May 2022.
Anyone here have spares they can send me?
Im in Miami, FL.
      03-23-2022, 02:56 AM   #76
gster109
gster109's Avatar
65
Drives: 2007 335i e90
Sold out, RIP.
By chance do you or anyone else here know if the thermostat gasket leak will mask itself as a oil cooler o ring sweating?? the drivers side one mainly. One single drop of oil.
feuer4285.00
      04-18-2022, 03:50 PM   #77
ichibanset
Drives: Alpine White 09 e90 335i
1 7/16 ID x 1 11/16 OD x 1/8 also fits.
2009 E90 335i
      12-31-2023, 04:28 PM   #78
mozmann
Drives: E60 530i
Any idea about the torque spec for the screws? I replaced the old one with the viton gasket, torqued the bolts to 16.5 Nm slowly, weeping at idle. I am afraid to over tighten and snap the screws...
      01-03-2024, 11:57 PM   #79
lowrydr310
Robot
2029
Drives: 2006 330i, 2007 E93 335i
Not sure but I replaced mine a few weeks ago and it is not leaking. You're more likely to strip the threads in the aluminum housing than snapping the screws. I just went based on feel; I have the torque specs for the oil filter housing and oil cooler thermostat bolts so I used them, but for the thermostat cover bolts I used a 1/4" drive ratchet with a short extension and the appropriate torx bit. It felt far less than 16Nm though. Did you go back and forth between the two bolts tightening each in sequence?
As of January 2024 I have four extra o-rings since the minimum order was 5 (for $16 including overnight shipping.) Happy to share if anyone needs one, no charge, just PM me.
      01-29-2024, 12:09 AM   #80
PMT_BOI
Drives: E92 335i (N55)
2011 BMW 335  [0.00]
Hey guys Im a new bmw owner
and I just replaced OFHG on my e92 335i (n55) I made the mistake of opening the thermostat lid so now I have a leak there
My question is probably a dumb one... but do I drain fluids again to replace this gasket???
I just put fluids in as well as bled coolant and primed the engine
      03-07-2024, 07:28 AM   #81
Malo_Industries
CNC Machined BMW Parts
Malo_Industries's Avatar
9
Drives: BMW 135i
2008 BMW 135i  [0.00]
Sorry guys, I keep a little more inventory of these now.
If, I ever run out again it should only be for 3 weeks max
https://www.maloindustries.com/produ...thermostat-lid
      04-11-2024, 06:22 PM   #82
Stubbie Blue
Drives: 2012 135i Coupe
I did the 2 OFHGs on my 2012 135i N55, but after a few months I saw a buildup of grime from the oil cooler thermostat cap.
So I got some FKM fluoro-rubber O-rings from AliExpress.
https://www.aliexpress.us/item/3256806543028225.html
OD 43mm, ID 37mm, CS 3mm.
I got 5 for $1.83.
[UPDATE] These AliExpress O-rings started to weep again after 2 months. Luckily I found that Elring now makes the octagon shaped gasket, part number 074.860.
I didn't know what the torque spec was for the T30 bolts for the thermostat cap, so I did 10 Nm or 89 inch-lb.
I went on a test drive with some full throttle runs and the oil temp got to 240F, and it seems fine with no leaks. I will update this later if it does leak.
Appreciate 3
      06-07-2024, 12:08 PM   #83
Stubbie Blue
I got 5 for $1.83.
Appreciate 3
      06-10-2024, 10:29 AM   #84
Wolf 335
Wolf 335's Avatar
2561
Drives: 2007 E92 335i
Octagonal gasket is in stock at FCP Euro. Rockauto also has it but it is out of stock at the moment.
Stubbie Blue thanks for the update and for finding out the Erling part!
https://www.fcpeuro.com/products/bmw...elring-074-860
I'm still runing a round Viton o-ring and no issues.
      06-20-2024, 12:12 AM   #85
whyzee125
Drives: Dinan stage 2 335i
11517514941 appears to be a genuine BMW part number for this!
      06-24-2024, 01:53 PM   #86
Wolf 335
Wolf 335's Avatar
2561
ECS Tuning lists that part number as a square gasket. Not the one in question.
Also discontinued.
whyzee1251986.00
      10-03-2024, 01:22 AM   #87
e90_Razzor
e90_Razzor's Avatar
Drives: bmw 328i 2010
Attachment 3476707
Hi.
I just ordered Viton o-ring 3x37 https://a.co/d/3QXsvAf Was it a good buy?
Which one did you buy?
